Fan pulley bracket bad?
Discussion in '1st Gen Tundras (2000-2006)' started by L1k3aSir, Mar 1, 2025.
  1. Mar 1, 2025 at 6:50 PM
    L1k3aSir
    L1k3aSir [OP] New Member
    2004 Tundra Stepside
    Good evening all,
    I was driving my truck last weekend and while driving, and at idle, I began to hear a grinding screeching sound from my engine compartment. At no time did I get a CEL nor did my truck overheat.
    I opened the hood and I did notice the fan pulley wobbling. Having looked into things, I'm thinking the bracket is going bad but I'm also thinking, and hoping against the water pump being the culprit as well.
    The water pump and timing belt was replaced approx 50k miles ago?
    Any thoughts or insights would be greatly appreciated.
  2. Mar 1, 2025 at 7:42 PM
    It's likely the pulley bracket if you're seeing the fan wobble. You're about the 4th person in the last year that's had the exact same problem. You can also hear that bearing on the bracket eating shit, it sounds dry as hell.
    Note it's a PITFA to get the fan off the clutch for some folks (nuts stuck), and some folks change the clutch while in there. I think there's a process for removing the nuts that's easier but not remembering.
    Anyway, Aisin brand is the OEM manufacturer of the clutch bracket. Their part number is FBT002 and it's around $110. I don't recommend buying on scAmazon, fleaBay or Walmart, these days you never know if you're getting authentic product. They do ZERO validation of ANY product they get in, and even product shipped from their warehouses lacks any validation.
    Weagle and L1k3aSir[OP] like this.
  3. Mar 2, 2025 at 4:41 AM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    The water pump is totally isolated from the fan on these trucks. Water pump runs off of the timing belt, whereas the fan runs off of the serpentine belt
    I can't imagine somebody replacing the timing belt without replacing the water pump, but who knows. What they were most likely to skip is replacing that fan bracket/pulley
    ATBAV8 and shifty` like this.
