  1. Feb 24, 2025 at 8:50 AM
    Florida AF
    Logan
    North Florida
    Kids ruin all the aesthetics....
    But... we got most of the cabinet locks installed and this arrived today. Now she already gave me the door knob ones but that shit is waiting until he can reach.
  2. Feb 25, 2025 at 7:57 AM
    Florida AF
    Logan
    North Florida
    This picture cracked me up... mostly because I hate stripping caulk and then laying a thick caulk line...
    but we found water where water doesnt belong... hold your breathe people... the flippers on this house did not seal the shower door correctly...
    So the inside is done and I will redo the outside later...
  3. Feb 25, 2025 at 8:52 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Mine looks similar, I put a vented cap on top of mine, like a flue cap. When it rains good the pipe would weep. None of the joints were glued as it’s just venting. Took a while to figure out where the water was coming from.
    woods[QUOTED] likes this.
  4. Feb 25, 2025 at 9:20 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    I'll keep an eye on that! Thanks! We did our mother inlaws the other day too, she was at 158 pCL/i or whatever, dropped to .3 in 48 hours. These things are phenomenal. Let alone the CO2 removal if you are in your basement alot, and the big reduction in humidity.
  5. Feb 28, 2025 at 1:39 PM
    Florida AF
    Logan
    North Florida
    Wore myself out... but made some headway on the last of the trees in the way and started chopping wood..
  6. Mar 1, 2025 at 9:35 AM
    Tundra family
    Tundra family New Member
    Rebuilding the pool cleaner with an upgraded body and gearset.
  7. Mar 1, 2025 at 10:17 AM
    Tundra family
    Wish I had known I was going to need to replace this before I put 200 lb of salt in the old one:mad:
  8. Mar 1, 2025 at 10:23 AM
    trucksareforgirls2
    trucksareforgirls2 New Member
    Northeast USA
    2020 Voodoo Blue TRD Off-Road
    Mine just crapped the bed too and started leaking! How much did that one set you back? Is it heavy? just wondering if I can get away with buying a cheaper one at Home Depot and then just hiring a plumber to connect it?
    -T
    TaquitoBandito and woods like this.
  9. Mar 1, 2025 at 11:34 AM
    Florida AF
    Logan
    North Florida
    This is the issue I have too... Plumbers here want 2k. I am sure theres is better, but I am tired of spending money right now. I think an Hd one will do just fine.
  10. Mar 1, 2025 at 11:37 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    They don't need to be fancy, its a real simple thing they do. We used a 20 year old one in my mother in laws when we built her house a few years ago, neighbor had one in his garage left over. Worked great for 3 years, then started leaking. Was a simple kink in the drain hose. Now we should have another 20 years.
    They have convinced us we need the fanciest most connected crap. We just need simple that works.
    TaquitoBandito likes this.
  11. Mar 1, 2025 at 11:47 AM
    Florida AF
    Logan
    North Florida
  12. Mar 1, 2025 at 11:55 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    I put one of these (different company but exactly the same) on a cabin we bought across the road that needed softnening and was sediment heavy, well water. It, along with a 5 micron filter, had the water sparkling and tasty. I like these because they are "set and forget" no salt added. You just need to replace them every 10 years or so. I would think once you get it set, it is just a simple swap and relatively cheap at $70 a year. What does salt cost a year? Got to be close, I probably use 3 bags every 1-2 months.
    edit: This is where I got ours. https://www.springwellwater.com/
  13. Mar 1, 2025 at 11:58 AM
    Tundra family
    Home Depot special for the win! It was about $500. As far as installation it's pretty straightforward if you're just replacing and not plumbing in a new system. You can get YouTube certification for this one.
  14. Mar 1, 2025 at 12:05 PM
    Florida AF
    Logan
    North Florida
    Which model or close to it? The site contains multiple to include salt based systems.
    Nice! I will look, I like that price tag a lot more than the one I was looking at.
  15. Mar 1, 2025 at 12:10 PM
    Tundra family
  16. Mar 1, 2025 at 12:10 PM
    trucksareforgirls2
    Northeast USA
    Is it wicked heavy to lift? Just curious if it's something I could go get on my own, or if I would need a helper. I am a weakling!
    -T
  17. Mar 1, 2025 at 12:12 PM
    Tundra family
    It's not so bad. 2 of us to load it and a dolly to get from the garage to the laundry room. Probably 150 lbs or so with all the weight on the bottom
  18. Mar 1, 2025 at 12:13 PM
    trucksareforgirls2
    Northeast USA
    Ok. thank you for all the info!! Would you mind posting pictures of the piped in areas after the install? I just want to get an idea if any changes would need to be made. My current one that is broken looks like it was installed in the 80s when the house was built.
    -t
  19. Mar 1, 2025 at 12:14 PM
    Tundra family
    Sure thing, plan on knocking it out tomorrow afternoon
  20. Mar 1, 2025 at 2:36 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Oof
    $2k would’ve been a dream last month. I had to put in an arsenic filter plus a softener. Just the media in the arsenic filter was over $4k.
  21. Mar 1, 2025 at 4:13 PM
    Florida AF
    Logan
    North Florida
    Yeah, I am still pissed on what I spent for the chlorine system I have. Especially knowing next is a softener.
  22. Mar 1, 2025 at 4:14 PM
    Florida AF
    Logan
    North Florida
    Alright home people... Any ideas on what this is:
    TaquitoBandito and T-Rex266 like this.
  23. Mar 1, 2025 at 4:20 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Cat scratch fever
  24. Mar 1, 2025 at 4:32 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Cats have retractable claws and a track that is usually wider than it is long. Those tracks in the sand look canine.
    the tree itself looks pretty well picked apart by bugs and birds.
  25. Mar 1, 2025 at 5:16 PM
    U need some trail cameras back there.
  26. Mar 1, 2025 at 6:01 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    Do you enemies that require an arsenic filter?
    OldGuy03 and TaquitoBandito like this.
  27. Mar 1, 2025 at 6:06 PM
    JMB
    Chesapeake, VA
    You have panthers down there I think. Looks like a large cat was using your tree as a scratching post.
  28. Mar 1, 2025 at 6:22 PM
    Outbound
    Aaron
    Northern Alberta
    Obviously a chupacabra.
  29. Mar 1, 2025 at 6:29 PM
    Tundra family
  30. Mar 1, 2025 at 6:52 PM
    Florida AF
    Logan
    North Florida
    Leading vote is Panther....
    We think they could not be related... Bear on one and cat on the other.... TBD
    Batteries changed and angle adjusted... More will be bought this weekend.
    Leading thought..
    Well... obviously...
    That is one theory...
