2013 Tundra starting issue
Discussion in '2nd Gen Tundras (2007-2013)' started by Fulldraw777, Feb 25, 2025.
  1. Feb 25, 2025 at 4:05 AM
    Fulldraw777
    Fulldraw777 [OP] New Member
    BC
    2013 Tundra
    Morning. Looking for a little insight into a starting issue that has arisen. When you turn the key to initiate start, it takes a couple of seconds to initiate the start. Ign.switch issue? Starter? Or worse:):(... Thoughts? Thanks to all.
  2. Feb 25, 2025 at 6:10 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Just for giggles - what is the sitting (overnight) battery voltage?
  3. Feb 25, 2025 at 7:53 AM
    Fulldraw777
    BC
    2013 Tundra
    Interesting thought, battery is only a couple months old so I never thought to look at that really. I'll test and circle back. Thanks.
  4. Feb 26, 2025 at 4:41 PM
    Rathesun
    Rathesun New Member
    Alaska
    2013 Tundra Double-cab 5.7L engine
    Does the delay happen on a cold start, such as if the truck being parked for a few hours or overnight, then started in the morning?
    Does the same 2-second delay happens on a second start? For example, start it and let it idle for about a minute or two, then start it again and see if there is a delay.
    I can only assume that the fuel pump would need about a second to pressurize the fuel if the truck has been parked overnight, although during a normal condition the fuel pressure rarely drops down by much when engine is not running, unless there is a fuel pressure leak somewhere.
  5. Feb 26, 2025 at 9:01 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Is the immobilizer light turning off? Or staying lit? Does it click? Is it flexfuel?
    Consider batteries sit on a shelf for a while before being installed in any car. Excessive heat and cold can kill them quicker. Additionally what are the CCA on battery?
  6. Feb 28, 2025 at 9:01 PM
    lr172
    lr172 New Member
    07 DC
    +1
    also my guess
  7. Mar 1, 2025 at 7:58 AM
    LiquidHeat
    LiquidHeat New Member
    2012 DC 4.6
    Nah you got a bad ground.
    95 percent of electrical issues on modern vehicles can be traced back to a bad ground.
