How many miles on your FFV equipped 2.5 gen?
Discussion in '2.5 Gen Tundras (2014-2021)' started by jim727386, Feb 23, 2025.
  1. Feb 23, 2025 at 7:13 AM
    jim727386
    jim727386 [OP] New Member
    Looking to get into a Tundra, but cost is a factor. I noticed the FFV are less desireable, but not sure how much that should scare one away.
    For example. Looking at a 2018 SR5 Crewmax 4x4 with 45,000 miles. One owner. $29,500.
    Deal or no deal?
  2. Feb 23, 2025 at 7:20 AM
    250000yota
    250000yota New Member
    Russ
    Berthoud, CO
    White 2015 SR5 Crewmax
    S&B intake, Dirty Deeds 8", Airlift airbags with Daystar contact cups, LED's everywhere including Diode Dynamics stealth front LED bar, Baja Design Squadron II's on CBI ditch light brackets, completed Diode Dynamics interior LED's. Full RCI skids with cat guards and sliders, Transfer flow 46 gallon tank. Radflo 2.5 IFP coilovers, Coachbuilder shackles, TRD rear sway bar. 295/70R18 Nitto RG's. Dobinson snorkel, softopper.
    I’d do it. I’ve got 221,300 on my ‘15 flexfuel. The reason people don’t like them is because of the alcohol density stability issue. The computer gets the alcohol percentage wrong since it calculates it instead of actually having a sensor. Once the computer gets the percentage much above 50% it has trouble starting in cold weather. There was a service bulletin for reflashing and replacing the fuel pump, which I had done but it’s not very effective. The best way to keep the percentage from going crazy is to limit hard acceleration for the first 7-10 miles after refueling. That’s when the ECU does its calculations off of various sensors to determine the alcohol density. When it does get out of hand on my truck, I just bought a cheap Amazon scanner and watch the density percentage on my Scangauge III and I perform the reset.
  3. Feb 23, 2025 at 7:21 AM
    centex
    centex New Member
    That’s about what I paid for mine with that mileage and year when I bought it 3 years ago. Currently at 76k miles and counting.
    jim727386[QUOTED][OP] likes this.
  4. Feb 23, 2025 at 7:21 AM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    My 2010 flex fuel has 270k on it.
    There is a potential for the system to get out of wack thinking the ethanol level is higher than it actually is. It would require the right scanner hooked up to reset it. It's not that big of a deal.
    jim727386[OP] likes this.
  5. Feb 23, 2025 at 7:51 AM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    Florida AF and jim727386[OP] like this.
  6. Feb 23, 2025 at 8:21 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    167K on my ‘15 with no problems whatsoever. Been rock solid reliable.
  7. Feb 23, 2025 at 8:35 AM
    Rotorwash
    Rotorwash New Member
    Robert
    2018 Tundra Crewmax 4x4 MGM
    Talon Cat Shields
    133,000 on my 2018 and zero issues!
  8. Feb 23, 2025 at 9:55 AM
    Tileguy
    Tileguy New Member
    Birmingham, Alabama
    2011 Toyota Tundra
    I have a 2011 and 2013 5.7 both flex fuel. Combined they have 845,000 miles. No issues with either, both on original motor and transmission. Will buy another one if either is these die, if that ever happens. Hope that helps
    equin, jim727386[OP] and AZBoatHauler like this.
  9. Feb 23, 2025 at 10:04 AM
    Tundra1988
    Tundra1988 New Member
    Cody
    17 Trd Pro White CrewMax
    295/70/18 Tires
    2017 trd pro with 130K here and has been SOLID. No pump issues in South Louisiana. Always heard Flexlfuels have larger possibly better injectors. I also had a 2011 rock warrior flex fuel as well years prior and no issues with it. I use to be hesitant but not anymore.
  10. Feb 24, 2025 at 5:54 AM
    DCRB4X4
    DCRB4X4 New Member
    BLACK 2015 DCRB SR5 4X4
    5100's front, spacer rear
    2015 at 182,000 miles. Reset fuel density once myself.
  11. Feb 24, 2025 at 7:46 AM
    jim727386
    Thanks. With a scanner? Or by other means?
  12. Feb 24, 2025 at 8:57 AM
    reneaux
    reneaux I've been around
    2017 SR5 CM 4x4
    2014 FFV and now 2017 FFV, 122k on the current truck. Reset the fuel density twice, has been over 6 months to a year and I am still sitting at zero % after the last reset. Experienced the extended crank and poor acceleration which is how I identified the problem before using a scan tool to read the percentage. Reset to zero using techstream.
  13. Feb 24, 2025 at 9:11 AM
    Bluecobra
    Bluecobra New Member
    2014 Tundra
    I have a 2014 with 83k on it and I have never had any problem. *knocks on wood* Mine is supercharged with long tube headers, no issues.
  14. Feb 24, 2025 at 9:40 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    5.7 Flex with 196k, no issues.
    jim727386[OP], AZBoatHauler and equin like this.
  15. Feb 28, 2025 at 4:57 AM
    DCRB4X4
    DCRB4X4 New Member
    Scan Tool
  16. Feb 28, 2025 at 6:07 AM
    Jaywhy
    Jaywhy New Member
    Jeff
    2016 SW TRD Pro CM
    Just rolled 140k on my trd pro. No fuel related issues though I've never used flex fuel it. Have had other issues(timing chain tensioner, coolant valley plate leak)which can be seen on the car care nut YouTube video. Even with that repair bill, still have no regrets about buying this truck and I'm gonna drive it til it dies.
    Brownsfanhere and jim727386[OP] like this.
  17. Feb 28, 2025 at 11:34 AM
    jsjensen73
    jsjensen73 New Member
    Justin
    Iowa
    2017 Quicksand Tundra
    Heated Seats
    Can you remove the FFV alcohol check with an OTT tune? Make it a regular gas only.
  18. Feb 28, 2025 at 11:42 AM
    centex
    centex New Member
  19. Feb 28, 2025 at 12:37 PM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    18 with 105k, no issues other than having to reset the alcohol density thing every now and then. I usually get the itch to upgrade but the issues on the new ones make me too nervous. I’m keeping mine for at least another 100.
  20. Feb 28, 2025 at 12:48 PM
    Brownsfanhere
    Brownsfanhere New Member
    2015 Crew Max
    15 flex with 80k and only issue was a leaky water pump. No fuel issues at all. 87 octane it’s whole life
  21. Feb 28, 2025 at 4:56 PM
    20manny1996
    20manny1996 New Member
    Manuel (Manny)
    2017 Limited Super White CrewMax
    17 with 55K on it. Have had the alcohol density issue just once & reset it myself this past winter. Otherwise been solid.
  22. Feb 28, 2025 at 5:02 PM
    Tundra@AZ
    Tundra@AZ New Member
    2021 MG Tundra
    I had a 2016 FFV had no issues, only reason I got rid of it is I got a great offer and upgraded to a 2021 crew max
