First Gen Lower Ball Joint(LBJ) Failures
Discussion in '1st Gen Tundras (2000-2006)' started by FirstGenVol, May 1, 2024.
  1. Feb 17, 2025 at 4:02 AM
    #571
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Depends what bolts you use. Most the OEMs are only good for one use. ARP bolts can be used multiple times.LINK
    That test doesn't always tell you they're bad. Replace every 100k with OEM and roll on.
    BroHon and KNABORES like this.
  2. Feb 17, 2025 at 6:04 AM
    #572
    Honestly, it's a wear part. Just use OEM parts and replace proactively at 100k-125k miles and you should be fine. I spent more on my aftermarket radio, which isn't even that fancy, than I did on LBJ and new hardware.
  3. Feb 17, 2025 at 6:26 AM
    #573
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    nope. I just treat it like a wear item. After my designated miles. The LBJ and bolts get replaced. Sooner than recommended if your use your truck for more than daily driving.
    I'm going with about 80-90k for mine since I use it to launch my kayaks off lake beds and hit potholes, ect.....
  4. Feb 17, 2025 at 6:31 AM
    #574
    Solid Snake
    Solid Snake The Anciet of Mu Mu
    West TN
    2006 AC 4x4 V8
    Yup. Last summer, I had 87,000 miles (and 17 years) on my LBJs. I didn't bother checking for wear or play. I just replaced them. It was great peace of mind, especially since I had a 2500 mile road trip coming up.
  5. Feb 17, 2025 at 6:32 AM
    #575
    FishNinja
    Lee
    06DC2wd
    and they're not bad "off the beaten trail backups" so just chuck'em in a box and keep them in the truck.
    BroHon likes this.
  6. Feb 17, 2025 at 6:46 AM
    #576
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    I'll just pop the ball joint instead, then.
  7. Feb 17, 2025 at 6:03 PM
    #577
    Yup, exactly what I did. Got a spare, in a pinch. If I ever get the call from a 1GT homey saying they need one, I got 'em covered.
    FrenchToasty and KNABORES like this.
  8. Feb 17, 2025 at 6:33 PM
    #578
    FirstGenVol [OP] Recovering mangler
    Same here. My old ones are in that tool box behind the seat. Although it's about to get evicted. Need a smaller tool box.
    FrenchToasty, shifty` and Filthyphil like this.
  9. Feb 23, 2025 at 8:57 AM
    #579
    I would never keep my old rusty crusty LBJs unless it was for forensic purposes.
  10. Feb 23, 2025 at 10:00 AM
    #580
    I mean, you say that but in a pinch, it beats having to let a flatbed drag your truck across the asphalt when you could instead just swap out the LBJ right there and drive away, and be golden for a few days while you wait for new OEM to come in. Also handy for trail spares.
  11. Feb 23, 2025 at 10:05 AM
    #581
    That’s under the understanding that I’ll detect when it’s about to give and slow down to respectable speeds where it won’t do much damage beyond the LBJs. Chances are the frame and other front end components are fcuked.
    Anyway. I’ve got AAA so they can drag it onto a flat bed and get it home. If I get a replacement frame, I’ll think otherwise.
    shifty`[QUOTED] likes this.
  12. Feb 24, 2025 at 6:45 AM
    #582
    FishNinja
    Lee
    06DC2wd
    LOL wut?
    So if you're out on the trail you'd expect triple A to get a flat bed out there? Instead of just undoing 4 bolts and a castle nut and limping g your way back to civilization?
    am I reading something wrong? Lol
  13. Feb 24, 2025 at 7:38 AM
    #583
    I’ll do dirt roads but not trails in my current stock configuration.
  14. Feb 24, 2025 at 8:27 AM
    #584
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Have you tried to use AAA lately? The last time I needed them it took 6 HOURS for them to respond!
  15. Feb 24, 2025 at 8:57 AM
    #585
    I had to use them last year and it was a 2 hr wait. I’m hoping that it hasn’t gotten worse since that time.
    Filthyphil and w666[QUOTED] like this.
  16. Feb 27, 2025 at 12:09 PM
    #586
    No vehicle is safe
  17. Feb 27, 2025 at 8:58 PM
    #587
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    Oh F, I have one of these too.... :cheers:
  18. Feb 28, 2025 at 6:36 AM
    #588
    It was trying to eject those horrid Rockstar wheels
  19. Feb 28, 2025 at 6:56 AM
    #589
    GipsyKxng
    GipsyKxng New Member
    2005 AC 2wd limited
    I saw an older Nissan Titan with the wheel at an intersection. I didn't pull my phone out fast enough to take a picture.
  20. Feb 28, 2025 at 10:46 AM
    #590
    What blows my mind is when someone puts on a donut spare and forgets to put the lug nuts back on it.
    You can literally watch in slow motion as they drive down the road while the wheel wobbles side to side until it comes off the hub. I’ve seen it twice in my life.
  21. Mar 1, 2025 at 4:44 AM
    #591
    bfunke
    bfunke Tundra Curmudgeon
    About a year ago I was diving behind a FGT whose LBJ let loose on a curve causing his truck to land on its side. Driver was OK but his Tundra was destroyed.
  22. Mar 26, 2025 at 12:32 PM
    #592
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
  23. Mar 26, 2025 at 12:41 PM
    #593
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I would normally say someone needs to scoop this up for that price. But I'd bet the frame is pretty bad being in Eagle River WI.
  24. Mar 26, 2025 at 1:52 PM
    #594
    Look how much rust is on the front bumper and above the rear wheel. She's a goner.
  25. Mar 26, 2025 at 2:24 PM
    #595
    Sirfive
    Sirfive Working on pavement
    ‘02 Limited AC TRD
    Bassani cat-back
    Those tires, it was earned. I bet he’s stuffing those white rimmed sunglasses in his pockets in the pic.
    BroHon and OldGuy03 like this.
  26. Mar 26, 2025 at 3:12 PM
    #596
    Fragman
    Fragman New Member
    2006 Tundra DC SR5 2WD V8
    Had to chuckle......
    ETA - I know the seller was not intentionally saying that, just made me chuckle.
    OldGuy03 and BroHon like this.
  27. Mar 30, 2025 at 4:13 PM
    #597
    Nakedgun
    Nakedgun New Member
    Southwest
    2005 RCLB V8 4x4
    At 91K this will be coming up soon for me, glad I looked at the 1st gen threads today (been watching 3rd gen, mainly).
  28. Mar 30, 2025 at 4:25 PM
    #598
    Him?? Check again.
  29. Apr 2, 2025 at 4:33 AM
    #599
  30. Apr 2, 2025 at 6:24 AM
    #600
    The Black Mamba
    Snek
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I straight up had to zoom in to make sure that wasn't a Texas plate
