Help with purchase decision
Discussion in '3rd Gen Tundras (2022+)' started by Reubenski, Feb 26, 2025.
  1. Feb 26, 2025 at 6:54 PM
    Reubenski
    Reubenski [OP] New Member
    2025 Limited CM, TRD Off-road package, 3" lift
    I've owned Toyota trucks for the past 16 years. My current truck is 2016 SR5 with 207K on it. I'm looking at trading it in. Found this 2025 SR5 with TRD Off-road and the Toyota TRD factory 3" lift. It's got 75 miles on it and it's been bought and traded in. This is the service report.
    What do you think?
    customer states while driving their vehicle has a flicking abs forward collison and tractioncontrol light onPERFORMED HEALTH CHECK AND NO CODES ARE PRESENT. TEST DROVE VEHICLEAND WARNING LIGHTS ARE FLASHING. CHECKED ROB HISTORY AND FOUND X CODESFOR STEERING ANGLE SENSOR OUT OF SPEC. WILL RECOMMEND REPLACING THESTEERING ANGLE SENSOR. CANNOT CHECK DATA LIST AS LIGHTS TURN ON .
    art# - Quantity - Description - Price8924B-0A010 - 1 - SENSOR, STEERIG W/LO - $468.05B:410101 - DIFFERENTIAL CARRIER ASSEMBLY - $373.17(Labor)B:410101 - DIFFERENTIAL CARRIER ASSEMBLY - $373.17(Labor)TAS RECOMMENDS REPLACING THE REAR DIFF ASSEMBLY.AFTER STEERING ANGLE SENSOR REPLACEMENT ISSUE WAS STILL PRESENT.CREATED A TAS CASE AND FOLLOWING THEIR PROCEDURE DISCOVERED THATWHEN THE REAR DIFF IS UNPLUGGED LIGHTS WILL NO LONGER FLASH. TASRECOMMENDS REPLACING THE REAR DIFF ASSEMBLY. REPLACED THE REAR DIFF PERTAS AND TEST DROVE VEHICLE AND LIGTS ARE NO LONGER FLASHING.
    So looks like they replaced the rear diff after 75 miles.
  2. Feb 26, 2025 at 6:58 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    What do you think? :)
  3. Feb 26, 2025 at 7:13 PM
    bailey bulldog
    bailey bulldog New Member
    How much are they asking?
  4. Feb 26, 2025 at 7:16 PM
    Reubenski
    $51K
    TRD Off Road pkg, SR5 Conv PKG, BSB mirror, Heated SW, spray in BL, TRD add on 3" lift
    Raven67 likes this.
  5. Feb 26, 2025 at 7:21 PM
    bailey bulldog
    See if they would CPO it and I don't think that's a bad deal personally?
    Reubenski[OP] likes this.
  6. Feb 26, 2025 at 7:25 PM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    Seems like a good deal. Trading a vehicle in after only 75 miles is interesting. Keep the 2016 if able.
  7. Feb 26, 2025 at 9:26 PM
    ElJefe77
    ElJefe77 New Member
    22 SR5 Premium
    Doesn’t seem like a terrible deal if you’re okay with no leather/heated/power seats and the small display.
  8. Feb 26, 2025 at 11:53 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I wonder if you could find out who the previous owner was and ask them. It could have been a buy back, lemon lawed or a 7 day money back guarantee thing with buyers remorse…….but certainly the service history would have me a little nervous if the reason was that they couldn’t figure out a problem that occurred in the first 75 miles!!!!
  9. Feb 27, 2025 at 2:07 AM
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    Unless your looking for a special kind of project I would look away and go else wear.
    Just my .02
    caboj likes this.
  10. Feb 27, 2025 at 3:57 AM
    22OffRoad
    22OffRoad New Member
    2016 SR5 CM 4x4 TSS
    King Off Road Shocks, 33"s
    I owned a 22 Tundra for about a year before trading in for my 2016. The 3rd gen. powertrain is excellent, ride quality and headlights are way better, and all the technology is great. But I had to deal with a number of squeaks/rattles I couldn't get rid of and had my 8" infotainment system replaced due to electrical issues.
    If you can get a full or extended warranty on this truck it might not be a bad deal, but I would expect to find more problems during your first year of ownership, which means time with it in the shop.
    caboj likes this.
  11. Feb 27, 2025 at 5:01 AM
    Reubenski
    I end up buying another truck. A 2025 Limited with TRD Off Road package, the 3" lift. Thanks for the help guys
  12. Feb 27, 2025 at 5:03 AM
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    That a boy, glad to hear this:thumbsup:
    I honestly didn't think it would of ended well if you pulled the trigger on the other one.
    Reubenski[QUOTED][OP] likes this.
