2016 tundra traction control and ABS light just came on.
Discussion in 'General Tundra Discussion' started by Steelyhead, Feb 12, 2025.
  1. Feb 12, 2025 at 5:00 PM
    Steelyhead
    Steelyhead [OP] 2016 Tundra TRD
    America
    16 Tundra TRD/03 Limited TRD
    2016 tundra traction control and ABS light just came on. I was backing up my snowy driveway and my traction control and abs lights came on. Has this happened to any of you? What’s the fix? Any pointers ? Thanks
  2. Feb 12, 2025 at 5:21 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Wheel speed sensor is the most common cause of this condition.
    If the light persists after cleaning the undercarriage check the wiring.
  3. Feb 12, 2025 at 6:18 PM
    Steelyhead
    America
    Where is it?
  4. Feb 12, 2025 at 6:34 PM
    mountainpete
  5. Feb 12, 2025 at 6:57 PM
    Steelyhead
    America
    Where
  6. Feb 12, 2025 at 6:57 PM
    Steelyhead
    America
    Thanks guys !!!!
  7. Feb 25, 2025 at 11:07 AM
    mzim
    mzim New Member
    Max
    Waterloo, Iowa
    2015 Tundra DC Silver Sky
    275/65/20 Goodyear Wrangler Duratracs (May2024) Full ARH long tube system Bilstein 6112 Front +2.7" Bilstein 5160 Rear & Icon 1.5 AAL & +2.0 Shackles Fender Flares 1D6 White Knuckle sliders TRD Grille Morimoto LED Headlights with LED DRL/sequential amber switchback turns Rigid Fogs with Square TRD Bezel 4x LED bed lamps wired in OV Tune base load with iterations coming Tech12Volt remote with 2 way fobs and range extender antenna 4.88s with Auburn TRD skid plate Koyo radiator - FAILED REINSTALLED OEM Tyger tri-fold bed cover Bed mat from Boss 4x4 Front bumper spacers 0.5 inch by Boss 4x4 Pop n Lock tailgate wired in Black badging all around Classico Faux Leather Seat Covers Rough Country Floormats Halo 9 HU Underseat kicker sub JRT upgraded speakers
    FYI only - I washed the salt off my undercarriage in very cold temps of single digits. A couple days later, I pulled into a snowy parking lot and put the brakes on only to get all the flashing lights you had. I stopped the truck, restarted and drove a little and the lights stopped. It happened again the next day but quit again. Then we got a significant warmup and the ABS light, etc never came back on. I'm only assuming that something got froze up around the ABS sensors on the hubs when I sprayed it down in the cold. I looked up new sensors and they were a bit over 40.00 for all 4 and the are easy to change. But never got that far. Just FYI here. You mentioned snow and I thought I'd share.
    mountainpete likes this.
