2022 Tundra 1794 Series Headliner
Discussion in '3rd Gen Tundras (2022+)' started by RickyRadar, Feb 23, 2025.
  1. Feb 23, 2025 at 7:22 AM
    RickyRadar
    RickyRadar [OP] New Member
    Rick
    2022 Mesquite Brown 1794 Series Tundra
    Tonneau bed cover
    I bought my truck new in March 0f 2022. I have a little over 17,000 miles on it all of which are highway miles. I don't abuse it. The headliner is coming down/off. It has separated by about 2 inches in the front. I can push it back up and it clicks and holds for a couple of seconds, but then it falls back down. I reported it to the dealer in November2024. They said they had to report it to Toyota to find out what to do about it. I'm waiting, but my patience is wearing thin.
  2. Feb 23, 2025 at 7:32 AM
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
    The headliner is actually held up by velcro. But its that hard plastic type that "clicks" together. unless you've already tried, use a bit more force pushing up on the headliner. they're spaced pretty far apart in my opinion and in about 2" pieces. assuming you have the pano roof, work your way around the edge of the pano roof. hopefully this helps.
  3. Feb 23, 2025 at 7:45 AM
    RickyRadar
    Rick
    Tonneau bed cover
    Thank you. Poor design in my opinion
    brhodea likes this.
  4. Feb 23, 2025 at 7:50 AM
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
    Agreed, I had to pull my headliner twice. 1st was for figuring out how to wire my Leer cap 3rd brake light to the cab 3rd brake light. 2nd was to actually do the wiring. I guess it has its pro's and con's.
  5. Feb 24, 2025 at 1:16 PM
    SUMMIT
    SUMMIT New Member
    2024 Tundra Platinum MGM
    Had the same issue with mine, and they warrantied it. No issues since.
    TheSS712 likes this.
