  1. Feb 23, 2025 at 3:23 PM
    1794TX
    Steven
    N.TX
    '20 1794
    Just read the description on their web site (I hadn't before writing my earlier question). Squinting as I write this, as it stands a signficant risk of being a stupid question... Once you start your truck, if you turn the kill switch off, I'm presuming the truck stays on. It just interrupts the starter, correct?
  2. Feb 23, 2025 at 4:18 PM
    Gainer
    Gainer New Member
    Columbus, OH
    2018 SR w/8' Bed
    Leveling kit, TRD wheels, remote start, Hellwig helper springs, TRD Rear sway bar. TRD Rear shocks, Dirty Deed 10" exhaust, S&B Cold Air intake
    Anybody know of a 2 pole switch that will pop into this opening?
    I ordered one off Amazon that said it fit... it didn't
  3. Feb 23, 2025 at 4:34 PM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Just pulled this out of the shoulder of one of my new tires.:mad:
    woods and bulldog93 like this.
  4. Feb 23, 2025 at 4:49 PM
  5. Feb 23, 2025 at 5:51 PM
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    Put in 4H today!
    Wallygator, woods, Henry1jg and 14 others like this.
  6. Feb 23, 2025 at 6:00 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    sbxx312, HulkSmurf14 and bulldog93 like this.
  7. Feb 23, 2025 at 6:05 PM
    mfelton18
    mfelton18 New Member
    South Central Texas
    2014 Magnetic Grey SR5 4x4 crewmax
    Changed spark plugs and reset a mouse/rat trap on the engine cover.
    BreyTundy, BR73, schleinj and 3 others like this.
  8. Feb 23, 2025 at 6:21 PM
    AirOnBoard....you want the Toyota small switches.
  9. Feb 23, 2025 at 6:27 PM
    TheMagicMan5280
    TheMagicMan5280 Member
    20’ Cement
    Got the rear bumper mounted and chopped some bed side off and also mounted a couple of lights.
    [​IMG] [​IMG]
  10. Feb 23, 2025 at 6:37 PM
    00h2itr
    00h2itr New Member
    Carolina's
    21 Limited CM TRD-OR
    What front bumper is that?
  11. Feb 23, 2025 at 6:45 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Badass cut! It looks ready now!
    woods and Tripleconpanna like this.
  12. Feb 23, 2025 at 9:24 PM
    Quicksand_Tundra
    Quicksand_Tundra New Member
    Jon
    2019 Quicksand Tundra CM 4x4
    -Color keyed grill & bumper -Diode Dynamic SAE LED Foglights -Headlight Revolution LED Light upgrade -SCS SR8 18x9 with 295/70/18 Toyo Open Country AT3 -Go Rhino Dominator D6 Steps -TRD OEM Intake & Dual exhaust -Bilstein 6112 front and 5160 in rear -JL Audio C2 6.5" speakers upgrade powered by JL Audio RD 400/4 amp -Pair of AudioFrog GS25 speakers front dash -10” Kicker Hideaway subwoofer under driver seat -All doors covered with Soundskins deadening mat (inside/outside) -Front window tinted at 35% -Paint protection film full front -30” Rigid Industries SAE light bar -Body Mount Chop -Diode Dynamics SS2 (red) setup for brake light & turn signal -Katzskin Custom leather upgrade (Black/Bamboo) -Amber led running lights (Hood bulge) -AJT Design: Black vent rings, steering wheel trim, shift gate trim, emblem overlay -AJT Design: Quicksand door handle cover -Carbon fiber wrap (silver part on door panel) -Air Design tailgate applique (Line-X in smooth gloss finish) -Air Design tailgate spoiler (Line-X in smooth gloss finish) -Smittybilt beaver step (Line-X) -Valhalla Cat Shield (Line-X) -Coachbuilder Shackles kit +2 -Coachbuilder Strut/Coilover shim (0.5" for driver side) -Sumosprings (rear bumpstop) -Meso Custom Led front and rear cab lights -Teton shop shift knob -TRD Seat belt shoulder pad -Husky floor liner front/back -LED courtesy door/step light -LED bed light kit w/ outside switch
    I have always liked the look of a chase rack on a truck. It makes the truck look more like an off road racing kinda truck. Yet, there are many out there available for the 2.5 Gen Tundras from Go Rhino, Backrack, to universal ones on Amazon even a Trailhunter replica. But there is one chase rack I have seen, not available or made for the Tundra. The Stealth Chase Rack from ADD; Addictive Desert Design. I even called up the company to ask if there can be a custom one made which i was willing to pay. He simply said, “at the moment, the Tundra is not on the list for that product. Only Chevy, Ford, and Dodge right now.”
    I said screw it. Took some measurements of the Tundra’s bed. Compared it to the other three trucks. The Chevy/GMC rack was the closest one slightly wider. With this, at least I have room to custom fit it rather than be short. Pulled the trigger and bought it, not knowing what I might run into.
    Product arrived and realize the side panel has a welded piece that must go into the pocket stake up front for the Chevy model. This wasn’t gonna work for the Tundra so I cut it off. Once cut, the side panel actually lined up to the bed rails so bolt on was a breeze. With the side panel bolts loose, the top piece slit in perfectly. After some adjustment, all bolts torque down and snugged.
    Here it is:
    Adjust it to sit flush with the bed.
    Like how it contours the shape of the truck.
    Top piece sits at cab height.
    Does not block third brake light.
    New bracket helps sit the SS2 light 1” higher for better visibility. (Works as a turn, reverse, and brake light)
    More outdoor pictures to come…..
  13. Feb 23, 2025 at 10:58 PM
    tundra23535
    tundra23535 New Member
    Henry1jg and bulldog93 like this.
  14. Feb 24, 2025 at 2:48 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    Awesome you made it work. Send them your pics lol
    HulkSmurf14 likes this.
  15. Feb 24, 2025 at 4:25 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Playing with the idea of doing this to the cab (minus the roof, that seems like a PIA ) curious about your thoughts after living with it for a few.
  16. Feb 24, 2025 at 5:39 AM
    Tundra Dude 45
    Tundra Dude 45 New Member
    Eric
    2019 SR 4.6L DC 4X4
    8” BAMuffler, TRD airflow accelerator, front window tint/windshield sun stripe, debadged tailgate 4x4 emblem, trimmed mud flaps, antenna removed stainless screw added, TRD rear sway bar, AFE high flow air filter.
    I rotated my tires. I miss having access to a lift.
  17. Feb 24, 2025 at 5:43 AM
    00h2itr
    00h2itr New Member
    Carolina's
    Only had time to do the rear wall this weekend. Gonna take a personal day or 2 off work this week to do the 4 doors (inside and out) and then I'll really have feedback.
    I'd suggest you make sure you have ample time, go slow and be detail oriented. While I did get a roller that came highly recommended, I hardly used it due to the surface not being flat, nor easy to get to. What I found worked best was a rag over my finger. This protected it from any cuts from the aluminum. I'd also suggest you determine a 'pattern'. What I mean by that is the surface your putting the sound deadening on isn't flat, and the material has to conform to it. So I went with top left to bottom right, working across the top first. I'd stick the top left to where it was going to go, then work across the top of the single panel of material, pushing down to form the area. The reason for this is that on a flat surface it'll simply lay down, but with so many variations in the surface, the sheets right side won't end up where you want it. So I'd peel the backing down about an inch, stick the top left corner where I want it, work across that top inch of exposed material, pushing down and forming it. Once I got it all the way across, then I'd peel down another couple of inches, work down that panel of material until I got to the bottom of it. Then on the next sheet of material, I'd do the same thing, overlying the first by about 1/4 inch or so and repeat.
    Hope that makes sense, if not LMK and I'll try to explain better/get images. It's not at all hard to do, just tedious and time consuming is all.
    Edit to add, I'm also only doing the back wall, and doors. Skipping the pillars, floor and roof.
    HulkSmurf14, 1UP[QUOTED] and jmdaniel like this.
  18. Feb 24, 2025 at 6:19 AM
    ultraman29
    ultraman29 New Member
    Katy Tx
    2021 White TRD sports
    Finally got it done with multiple stages since time is limited.
    1. Changed coils from TRD PRO fox stock to Eibach.
    2. Installed 1.5 shackles from Apex off road at the back to level.
    3. Installed the rock warrior wheels and KMC center cap with TRD covering.
    4. Added washers for shims for the front bumper and removed the front splash guard.
  19. Feb 24, 2025 at 7:18 AM
    jmdaniel
    jmdaniel Spending too much time here...
    Leander, TX
    2018 Tundra CrewMax SR5, 1977 FJ40
    DSI Conversion, including 6" ProComp lift, Fuel Assault Rims, ProComp tires, SunTek protective film, BAK Revolver X2 tonneau cover, Bedrug bedmat, OEM Audio+ Reference 500Q
    Been there. Great improvement.
  20. Feb 24, 2025 at 7:29 AM
    00h2itr
    00h2itr New Member
    Carolina's
    What made you decide to cover the panel which would require cutting the sound deadening later on to service the rear window? I debated back and forth on the merits of leaving it just as you did, but opted for the inner wall, then the panel itself to simplify the ease down the road. I do plan on keeping this pig a while. Not sure one way is right, or wrong. Just curious your personal feedback.
    Can't wait to get the doors done this week too! And get this tedious project behind me.
    jmdaniel likes this.
  21. Feb 24, 2025 at 7:40 AM
    jmdaniel
    Leander, TX
    Same for me, and the results were amazing.
    I tried to embed a YouTube video, but gave up, as the forum kept blocking it. Here is the link. Taps 1 and 3 are on a door with no deadening, 2 and 4 on a deadened door.
    https://www.youtube.com/shorts/LpJoo1Tgc7A
    Tundrastruck91 likes this.
  22. Feb 24, 2025 at 7:46 AM
    00h2itr
    00h2itr New Member
    Carolina's
    I'd say that's quite a difference! Did you do the 'inner' aka door skin part as well as the shell where all of the panel mounting clips go? What about the window opening where the moisture barrier goes?
    I'm debating on the moisture barrier part. My panels from Kilmat are smaller in size than I'd anticipated or saw on the Taco Tunes YT video, I'm not sure one full panel will cover that hole. So should I stick 2-3 together and cover the hole? Or just do the shell part, leave that open from sound deadening, and then reinstall the moisture barrier?
    jmdaniel[QUOTED] likes this.
  23. Feb 24, 2025 at 7:53 AM
    jmdaniel
    Leander, TX
    I never use that rear window. I have some stickers on it that I don't want to scrape off, have a rear facing security camera mounted, and, living in Texas, I rarely have any windows down. And I'll be keeping my pig for awhile as well. One of the reasons I did the deadening was that I installed an OEM Audio+ setup in my Tundra, so wanted the music to be even better.
    00h2itr[QUOTED] likes this.
  24. Feb 24, 2025 at 7:55 AM
    00h2itr
    00h2itr New Member
    Carolina's
    Same here, James with tech12volts. JBL DSP amp upgrade, as well as James's sub/box. I'm not looking for huge gains, just a little bit. If the road noise goes down a few db's as well, great!
  25. Feb 24, 2025 at 8:05 AM
    jmdaniel
    Leander, TX
    I went with Noico, not Kilmat. Basically the same stuff, for less money. Here are some pics of the doors.
    This shows the stock Toyota "deadening". Don't laugh. Okay, go ahead and laugh. Not only is it tiny, not even all of it was stuck to the door.
    Door was deadened by applying material inside the door, (like that massive piece Toyota put on...), as well as this placement where the moisture barrier had been.
    Front driver's door, ready to slap the panel back on. That is still the stock Toyota door speaker, I put the OEM Audio+ stuff in about a month later.
  26. Feb 24, 2025 at 8:07 AM
    jmdaniel
    Leander, TX
    Well, I didn't use a gauge, but my ears were happy. I helped a buddy do the deadening on his Taco, which he wanted to take care of as soon as he saw the door thump video.
  27. Feb 24, 2025 at 8:22 AM
    singletrack_dad
    singletrack_dad New Member
    Ty
    2014 TRD OR CM
    Plasti dipped my wheels black & glossifier layer over that. And installed 5100’s at top setting. Truck has 1” rear maxtrac shackles & about 2” front 5100 lift. Love how she’s sitting. 315/70/17
    Jego, OHwendTrd, UTAHRTK and 14 others like this.
  28. Feb 24, 2025 at 8:22 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    How are you able to purchase? It doesn't let me without being in an Aussie providence.
  29. Feb 24, 2025 at 8:29 AM
    00h2itr
    00h2itr New Member
    Carolina's
    I'd previously seen that deadening that Toyota added and also laughed. That's nothing. Did you end up peeling it off or applying right over it?
    And thanks for the pics of the panels of material and how you applied over the hole for servicing the window track/regulator.
    jmdaniel[QUOTED] and bulldog93 like this.
  30. Feb 24, 2025 at 10:19 AM
    Fergie
    Fergie New Member
    After completing the project above, I finally got around to making a janky filler for the hole that the camera left. Plenty of silicone adhesive sealant, and it hasnt budged in a few weeks.
    I also got the box for the 2 stage regulator mounted under the truck. Inexpensive HF box, and installed some rivnuts to the bed, and I'll be able to access the regulator and connection if I need to replace any of them. All off the shelf stuff, so should be able to source parts from any ol hardware store.
    mgm16trdpro, bulldog93 and BR73 like this.
