My Go Rhino RB20 hardware…
Discussion in '3rd Gen Tundras (2022+)' started by Ero2, Feb 21, 2025.
  1. Feb 21, 2025 at 11:19 AM
    Ero2
    Ero2 [OP] New Member
    Am I insane, or does the hardware seem to hang lower than other examples you’ve seen? Or is my truck too low and once it’s leveled/lifted I’ll like them better? lol. Hard to believe it bothers me so much, but it does, enough to send them back maybe.
    Only other ones I really like is the cast aluminum TRD ones so far, but not sure they stick out enough to protect from door dings like these do?
    mrfreeman likes this.
  2. Feb 21, 2025 at 12:25 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Looks about the same as any truck with side steps/bars. It may be more noticeable on the RBs since they are flat and thin.
    The oval bar design side steps still have about the same hang where they mount on the bars....just the bars hide the mounts better.
  3. Feb 21, 2025 at 2:57 PM
    Wtundra2023
    Wtundra2023 Bad Weld Aficionado
    2023 Limited Tundra, 2014 Limited Sequoia
    My Go Rhinos look the same. Its normal.
  4. Feb 21, 2025 at 3:23 PM
    MAC25Tundra
    MAC25Tundra New Member
    2025 Limited Crew Max 4x4
    Here are mine for reference. Looks normal to me. I’ve gotten used to the mounting hardware, but the first mount does catch a ton of snow.
    Sisu87TRDOR likes this.
  5. Feb 21, 2025 at 9:08 PM
    Derfla
    Derfla MUDBATH PRO
    2025 TRD PRO
    I’ve got the slims on and agree that they do sit lower than they should be. I think once you get a lift, it won’t look as low.
  6. Feb 22, 2025 at 12:18 AM
    Observer
    Observer New Member
    have the same as you. Yes the brackets do show but as said most other do to. I really like mine. I have the slims.
  7. Feb 22, 2025 at 2:45 AM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    I have the slims. And yes, the brackets bug me too. Sometimes the way it sits, it’s not a noticeable. I’m slowly getting used to it. I think they could’ve made them a thicker gauge material and slimmer if that makes any sense, so the brackets don’t hang down so far. IMG_6677.jpg
  8. Feb 22, 2025 at 5:31 AM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield, AMP power boards
    I tried a set of these when I first got my Tundra but sent them back the next day. They mounted easily and looked good but they are so high they put your ass up at roof level so it is almost impossible to get in.
  9. Feb 22, 2025 at 7:24 AM
    plinyyounger
    plinyyounger New Member
    Ken
    Idaho
    2025 Tundra limited
    3-2 lift, KO3’s, Fuel wheels, tint.
    Yes the brackets hang very low. I looked at these too but you are not wrong they are low, it’s why I bought a step with different mounting.
    caboj likes this.
  10. Feb 22, 2025 at 8:34 AM
    Tundra@AZ
    Tundra@AZ New Member
    2021 MG Tundra
    Similar take, they just looked lower to me and i decided to hold off on steps
  11. Feb 22, 2025 at 10:05 AM
    Ero2
    Anyone go from the RB20s to the cast aluminum? Real truck has graciously offered to return them. Just gotta get a ton of bubble wrap and get them going I guess. Was hoping the hardware didn’t hang as low as it looked in photos but it doesn’t seem to be growing on me, lol.
  12. Feb 22, 2025 at 9:00 PM
    Ero2
    Ever a worry you're going to get caught up on something because of how they hang? Guess that's truly my concern. If I'm driving over something in a field, or on a trail, are these, due to the hardware, any more likey to get you caught on something vs the TRD ones that are flat across the bottom? Maybe I'm just beyond overthinking it.
  13. Feb 23, 2025 at 12:08 AM
    MAC25Tundra
    For my use case it’s not a concern and I’ve never given it a second thought. If you want something that tucks up tight and has a low profile mount, I’d recommend sliders.
    2014 Black tundra and Observer like this.
  14. Feb 23, 2025 at 5:58 PM
    osu1978
    osu1978 New Member
    RB20's hang low like many other models. The Go Rhino Dominator D6 are tucked up underneath and much more hidden.
