What is this sound coming from the front of the engine?
Discussion in '1st Gen Tundras (2000-2006)' started by poormxdad, Feb 9, 2025.
  1. Feb 9, 2025 at 3:14 PM
    poormxdad
    poormxdad [OP] New Member
    2012 Tundra Grade Four Door 4.6 4WD/ 2007 Sequoia SR5 Leather
    Gentlemen,
    I just picked up a 2007 Sequoia. The body, paint, and interior are in better shape than I could have imagined. She does have some issues, however.
    I've attached a very short .mp4 of a squealing sound coming from the front of the engine. I believe it's the fan bearing. The sound changes with engine speed, not mph.
    Any thoughts would be greatly appreciated.
    Thanks,
  2. Feb 9, 2025 at 3:54 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Sirfive likes this.
  3. Feb 9, 2025 at 4:15 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Pull the serp belt & spin each pulley. Was the a/c on? Does the noise change if the a/c is on?
    BubbaW likes this.
  4. Feb 9, 2025 at 4:47 PM
    Sounds like a pulley. Does it only happen when cold?
    Turn off the engine. Pull off the serpentine belt. Start the engine. Does it go away?
    If yes, turn off the truck. Go to the front of the engine. Spin EACH pulley by hand. Are any tough to spin? Are any noisy? If yes, can you show us which ones are making noise in a video or photo or whatever, we can help.
    There is a TSB for the tensioner pulley squealing specifically, but … can’t recall if your year is included without looking at the TSB again.
    Jack McCarthy likes this.
  5. Feb 17, 2025 at 5:44 PM
    poormxdad
    I haven't had much time to play with it. I was either traveling, or the weather didn't cooperate. I have not had the opportunity to remove the serpentine belt, and probably won't until next weekend.
    However, I was able to run it for several minutes today. The sound is definitely more pronounced on the passenger side. It sounds like it's coming from the power steering pump. The sound doesn't change much when the steering wheel is turned. It also doesn't change much when the a/c is turned on, given that the rpm does increase.
  6. Feb 17, 2025 at 6:16 PM
    It's quite possible the alternator pulley is giving up the ghost. It's happened to others. That's going to go out long before the PS pump or its pulley.
  7. Feb 23, 2025 at 12:04 PM
    poormxdad
    Alrighty then... I pulled the serpentine belt and started her up. The sound was gone. The idler pulley was too easy to spin, like a skateboard wheel. The other pulleys seemed fine. I thought I'd conquered it, but with the belt back on and a new idler pulley, the sound returned.
  8. Feb 23, 2025 at 12:38 PM
    Downside: Problem not solved.
    Upside: You know 100% it’s something on the serp belt route.
    When you spin the pulleys, did you also check them for play?
    There’s a pulley on the fan bracket known for getting wobbly, did you check it also? And the alternator pulley?
  9. Feb 23, 2025 at 12:41 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Just went through this with my Land Cruiser...check the tensioner/pully. I was able to mitigate the problem by exercising the tensioner back and forth, but I know it's only a temporary fix at best. I ordered a new tensionser (~ $100), but I have to remove a lot of stuff to install it. I put it on the parts shelf next to my timing belt kit so I can do it all at once.
  10. Feb 23, 2025 at 3:06 PM
    poormxdad
    I decided to replace the tensioner pulley as it was relatively easy, and not particularly expensive. Problem solved. However, I do believe both the idler and tensioner pulley bearings were bad.
    Thanks much everyone for your inputs.
    Now, I just need to replace my supply of bandaids...
  11. Feb 23, 2025 at 5:39 PM
    My favorite byproduct from working on the truck.
    I forgot how many sharp little plastic bits you get into just changing valve cover gaskets. When I gave @Dakillacore a pair of extra hands to do his recently, was a bad idea to make tacos with fresh lime and chile :rofl:
    My skin is clearly getting thinner with age. I didn't start noticing it until my 40s.
