General Supercharger Thread
  1. Feb 20, 2025 at 9:20 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I set up one tune with every aip code deleted. There are both physical and electrical based codes. Because there us a 5 volt constant and the drivers communicate to the ecu you need the Hewitt to get the signal and voltage to other components.
    I also forgot about the ecu sending out pulses between the pump and valves...
    e30cabrio and koditten like this.
  2. Feb 21, 2025 at 10:36 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    PSB 1 passenger bank, ECB-1 driver, on the gauge the ECB jumps from 7.5-22.5 just like the ECF-1 I just returned to them. They insist that means it is not calibrated, OK so why does HPT see it????
    :p
    https://vimeo.com/1059087423?share=copy
    It says LM but it is the ECB.
    HulkSmurf14 likes this.
  3. Feb 21, 2025 at 2:43 PM
    e30cabrio
    Sniv is the Man!! Somehow the ECU "changed" it's OS. The solution was a new file based on a new read. Truck feels great on a traffic filled drive.
    Thank you Snivilous!!
    M3Tundra-JK, Wynnded, ARES35 and 6 others like this.
  4. Feb 21, 2025 at 2:57 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Whelp got the dreaded crank no start happening. I’ve been firing the rig up weekly to keep it charged etc no issues. We had a cold spell then some random misfires now no start. I’ve got a crank sensor coming, new plugs ( even though we replaced those and coilpacks recently) and we will see. I Just swapped in a new fpdm just incase.
    Codes random miss fire
    Miss fire on cylinder 5
    Mdl likes this.
  5. Feb 21, 2025 at 2:58 PM
    e30cabrio
    Booo, we need a dislike button!
    Hope it's simple!
  6. Feb 21, 2025 at 3:02 PM
    centex
    centex New Member
    That a common thing or something? I had a weird incident Super Bowl night where I hit the remote start and it coughed and then just kept cranking. Was weird. No codes and has been fine ever since.
  7. Feb 21, 2025 at 3:14 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    From what I’ve been reading it’s a random common problem with equally random fixes lol
    Mdl likes this.
  8. Feb 21, 2025 at 3:24 PM
    centex
    centex New Member
    Those are my favorite haha.
    reywcms likes this.
  9. Feb 21, 2025 at 4:29 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    yeah we got cold here too which seem to kill my batteries, this one only lasted under 2 years. but i haven't got any weird starts or firings.
    i just get a backfire here and there driving because of the larger exhaust lol
  10. Feb 21, 2025 at 4:52 PM
    Abell207
    Abell207 New Member
    Anthony
    Maine
    2020 Army Green TRD PRO
    -10 degrees a few days in Maine and had zero issues starting.. “knock on wood.”
    snivilous[OP], e30cabrio and Mdl like this.
  11. Feb 22, 2025 at 8:33 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Just order the built engine now.
    nags, HulkSmurf14, bflooks and 4 others like this.
  12. Feb 22, 2025 at 8:56 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    lol I was thinking this
  13. Feb 22, 2025 at 10:06 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Not sure what the timeline will ultimately be, but I'm tracking to be at the longer end of the 1-2 month window. Just throwing that out there for your planning purposes. With the 6.8l stroker kit being out of stock it could be even longer for you. :)
    HulkSmurf14 and reywcms[QUOTED] like this.
  14. Feb 22, 2025 at 10:37 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Down the road. Redoing all the suspension this year. But update locating an oem unit difficult Now apparently backorder no eta found 1 of 3 available in the country in SoCal and buddy went to pick it up for me.
  15. Feb 22, 2025 at 10:42 AM
    bflooks
    bflooks New Member
    Metrowest MA
    I can't remember. Did you have a core charge as well or were you keeping your existing for a future build/reman?
  16. Feb 22, 2025 at 10:47 AM
    e30cabrio
    I did this last night. (did not place an order, Wife would kill me)
    nags and M3Tundra-JK like this.
  17. Feb 22, 2025 at 10:52 AM
    bflooks
    bflooks New Member
    Metrowest MA
    what did you go with? "just" the 6.8l stroker or something else? i'm struggling to see the exact specs you chose.
  18. Feb 22, 2025 at 10:55 AM
    e30cabrio
    That's the 6L version, the choice is on the left, so first item/Yes are the choices, it's a weird system.
    reywcms and bflooks like this.
  19. Feb 22, 2025 at 11:36 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I bought another trans as a spare and I’ll send one in for core unless it’s a hassle than I’ll keep both
  20. Feb 22, 2025 at 12:07 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I may need a core to send in for a rebuild...been looking for a spent transmission.
  21. Feb 22, 2025 at 12:50 PM
    bflooks
    bflooks New Member
    Metrowest MA
    One hell of an expensive "loaner program" but... :)
    e30cabrio and Mdl[QUOTED] like this.
  22. Feb 22, 2025 at 1:01 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Let me know
  23. Feb 22, 2025 at 1:02 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Well of course there would be some money involved. Or I got some nice 535cc injectors to trade. :rolleyes:
    e30cabrio and reywcms like this.
  24. Feb 22, 2025 at 1:36 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I'm still working on the details but thanks!
    e30cabrio likes this.
  25. Feb 22, 2025 at 1:39 PM
    e30cabrio
    I have a 143k fully functional Torque Converter if a core before disassembly is needed.
    Mdl likes this.
  26. Feb 22, 2025 at 1:43 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Anyone traveling from LAX to Portland/ Seattle that wants to transport a cat?
    It'll be picked up in a supercharged Tundra...keeping on topic.
    Edit: I just told my sister to come up for a visit and bring it with her. It's a cool Bengal/Savanah.
  27. Feb 22, 2025 at 1:58 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Ha!
    Mdl likes this.
  28. Feb 22, 2025 at 7:24 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Finally received my PML pan...guess I was last in line or forgotten.:D
    Will get it installed with some Dex3 and see how runs. Got the monsoon rain going on...
    armyoffoo, HulkSmurf14 and e30cabrio like this.
  29. Feb 22, 2025 at 7:30 PM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    Why exactly are you switching to a different ATF when installing a larger pan?
    Mdl and HulkSmurf14 like this.
  30. Feb 22, 2025 at 7:40 PM
    HulkSmurf14
    2014 Tundra Limited
    The thicker DexIII helps let the clutches grip harder...nuance is just a drain and refill more often/once a year...
    nasher75, reywcms, bflooks and 2 others like this.
