Transmission Shift Performance
Discussion in '3rd Gen Tundras (2022+)' started by Retroboy1989, Feb 17, 2025.
  1. Feb 17, 2025 at 4:15 PM
    Retroboy1989
    Retroboy1989 [OP] 'Course it's 4x4!
    Northern Utah
    Have any of you noticed peculiar shifting in gears 2-6? it's almost like it shifts then a split second layer the gear locks in solid.
    Another way to describe it, the rpms drop like a normal shift, but then a split second later they drop slightly more accompanied by the feel of a firm gear shift.
    Not sure if this is normal or if I should be worried. 900 miles on a 2025 gas Tundra.
    Edit:
    Does the TC lock in lower gears on this truck?
    It only behaves the way I am describing under light to moderate throttle. Under heavy throttle it shifts like I would expect.
  2. Feb 18, 2025 at 5:44 AM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    I’m no expert but the Tundra has to adapt to your driving style. It may seem funky in the beginning but should smooth out as you rack up the miles. This is my first ten speed and I can hardly feel the shifts. I’ve got 10K miles.
    Retroboy1989[OP] likes this.
  3. Feb 21, 2025 at 2:16 PM
    Retroboy1989
    Northern Utah
    ARB1977 likes this.
