15 DC Build/fix crosspost
Discussion in '2.5 Gen Tundras (2014-2021)' started by basavage, Feb 18, 2025.
  1. Feb 18, 2025 at 4:49 AM
    basavage
    basavage [OP] New Member
    Bailey
    NC
    2015 white double cab Tundra
    I have a 2015 DC with tuff country 4” lift, 33” Falken AT3s and “stock” 20” wheels. I’ll add a pic of current look.
    If you look at my post history I still have that bad shock lol. I’ve also got a bad wheel that throws off everything and is destroying my tires.
    I’m looking at fixing these suspension/wheel issues all at once. I don’t think swapping suspension now and wheels/tires in the following 6 months would be okay due to shake from that bad wheel. Would it mess up replaced suspension or should I stick with replacing it all at once?
    I’m also curious if there’s better ways to go about getting what I need for what I’m trying to achieve. (I’m poor)
    This is what my plan is:
    2” drop kit from sos performance with front and rear bilsteins (to replace all current shocks)
    17” Black Rhino Arsenals (black and tan)
    33” Falken ATs again
    Do I need the drop kit to achieve a 2f/4r drop? My local shop said only shocks…
    I know it’s a big difference going from 4” lift to 2” drop but I want it for my dogs. Would those wheels/tires still work? I’m also very set on those particular wheels.
    sorry for so many questions I need to get this sorted out the most efficient and economical way. Thanks guys!
  2. Feb 18, 2025 at 7:33 AM
    reneaux
    reneaux I've been around
    2017 SR5 CM 4x4
    Post a picture of your front lift setup from inside the wheel well behind your front tires to help us understand what you're trying to do. I think what you are asking is you want to lower it from where it sits now by 2"? So instead of a 4" lift you would have 2" of lift? Or are you asking to actually drop the truck 2" which would be 6" difference from where you are now?
    HulkSmurf14 likes this.
  3. Feb 19, 2025 at 4:36 AM
    basavage
    Bailey
    NC
    @reneaux im going for the latter, so a 2” drop from stock, totaling 6” from current height. I’m heading to work so later today I can grab some pictures of underneath/behind wheels
  4. Feb 21, 2025 at 6:56 AM
    reneaux
    2017 SR5 CM 4x4
    No need for pictures, I am of no use for input on this one. But to answer your question, just shocks wont achieve what you are wanting to do.
    Try these links...Good luck!
    https://www.tundras.com/threads/lowering-kit-suggestions.62522/
    https://www.tundras.com/threads/anybody-lower-their-tundra.57799/
    https://sosperformance.com/products/2-front-slash-4-rear-lowering-kit-fits-2007-16-tundra-tr2051
    basavage[QUOTED][OP] likes this.
  5. Feb 21, 2025 at 10:33 AM
    basavage
    Bailey
    NC
    Appreciate it @reneaux
    I was planning on that drop kit and I figured just shocks was a lie lol
