Noise during gentle acceleration
Discussion in '2.5 Gen Tundras (2014-2021)' started by SWsr5, Feb 14, 2025.
  1. Feb 14, 2025 at 1:24 PM
    SWsr5
    SWsr5 [OP] New Member
    2021 Cement TRD-OR DC
    Strange noise under gentle acceleration. It almost sounds like a loose chain on a bicycle, it’s difficult to describe, but it’s definitely coming from the front end/engine bay of the truck. I hear it mostly when I’m driving along at a consistent speed and then begin to gently accelerate, but not enough to drop a gear.
    I’ve attached an audio file of the noise, during which I was gently accelerating up to 50mph (on level ground and rwd) and probably in 4th or 5th gear. Truck is a 2021 4x4. Any ideas?
  2. Feb 18, 2025 at 10:49 AM
    clownkillerloaf
    clownkillerloaf New Member
    Logan
    '21 SR 5.7
    listened w/ headphones cranked up, sounds like a perfectly healthy 5.7. Then again, I probly dont hear it from mine bc no mufflers :anonymous: next oil change swap to 5w30, bet the clicking quiets down. Its a noisy engine
  3. Feb 20, 2025 at 3:52 PM
    dundunDUN
    dundunDUN New Member
    2016 Tundra SR5 CrewMax
    I hear it. Sounds maybe like a heat shield on a cat vibrating or something that resonates when you get to that speed. Check under the truck and tap around to see if anything’s loose.
