Engine failure update
Discussion in '3rd Gen Tundras (2022+)' started by GBTUNDRA25, Feb 20, 2025.
  1. Feb 20, 2025 at 2:44 PM
    GBTUNDRA25
    GBTUNDRA25 [OP] New Member
    2025 blueprint Crewmax Limited
    Hello everyone,
    just got word that Toyota has approved to teardown the engine and replace cylinder head on bank 2. Parts are on order but no idea of time for arrival. so sit and wait. I will update as this progresses. Only 4 months old.
  2. Feb 20, 2025 at 3:10 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    AZBoatHauler likes this.
  3. Feb 20, 2025 at 3:14 PM
    AZBoatHauler
    So.Arizona
    3 year old trucks running fine getting long blocks and brand new trucks broke down being torn apart…
    ColoradoTJ, oddhours and Tunrod like this.
  4. Feb 20, 2025 at 3:18 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Welcome from LV ... can you provide a debrief of symptoms your truck was having?
  5. Feb 20, 2025 at 3:20 PM
    So it must be a cylinder head issue and not the crankshaft bearing issue from the recall?
    I know you probably don't have any more information, so we will sit and wait like you have to.
    Very disappointing to hear.
  6. Feb 20, 2025 at 5:14 PM
    GBTUNDRA25
    Hi everyone,
    Symptoms before this happened. Went to an appointment early Tuesday morning got there a little early Saturday with the truck idling for about 5 minutes started to idle a little rough didn't think much of it. Came back out and started it up then it flashed 6 error codes and would not release the parking brake.it was stuck. Had it towed to the dealer.
