Harrop Supercharged Guys I Need Your Help
Discussion in 'Performance and Tuning' started by eZKimChi, Jan 16, 2025.
  1. Jan 16, 2025 at 2:03 PM
    eZKimChi
    eZKimChi [OP] New Member
    Hey guys,
    I’m a bit stumped diagnosing this progressively worsening issue on my Harrop supercharged truck and am open to hearing what y’all think.
    My LX570 was Harrop supercharged 2 years ago and never had any issues with the coolant circuit for the supercharger, its always kept a rock steady level and never needed to be filled.
    About 8 months ago I noticed that the truck was driving a little off and my IAT’s were a bit higher than normal so after checking everything else I discovered that the S/C coolant reservoir was bone dry… I filled it up, idled the truck and kept topping it off until the coolant was level. Odd that coolant just disappeared and no sign of leaks anywhere…
    Next oil change roughly 4 months later I checked the reservoir and yet again it was bone dry… wtf? Filled up again but this time I noticed that the intercooler pump barely worked, but by the time the system was full of coolant it started to circulate as normal.
    Now a couple days ago I rechecked and behold… bone dry reservoir yet again…. I refilled the system and after tapping the pump with a hammer it slowly came back to life.
    I’ve removed the skid plates and checked every square inch of the engine block and every single hose but there is no exterior leak anywhere. I’m assuming the Intercoolers inside the Harrop supercharger may be leaking? Have any of y’all had to replace those intercooler blocks before? What could have caused this to happen?
  2. Jan 16, 2025 at 2:06 PM
    AZTundra
    Paul
    Phoenix, AZ
    Terndrerrr and nobodyintexas like this.
  3. Jan 16, 2025 at 2:17 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I loose fluid. About an ounce a month
    I can tell it’s my reservoir cap
    it just doesn’t seal all that well
    and its damn hot in houston
    AZTundra likes this.
  4. Jan 16, 2025 at 2:42 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Sounds like intercooler bricks are leaking. We had a slight cracked unit in the old man’s supercharged FJ. Same type scenario. Pulled it apart brick had a crack in it.
    HulkSmurf14 and Saltyhero13 like this.
  5. Jan 16, 2025 at 5:36 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Some of the bricks leak. I would reach out to Harrop for a remedy after you let them know what is occurring. Harrop had an account on these forums but I don't think they monitor it frequently. They are fairly quick to respond via email.
    HulkSmurf14, AZTundra and snivilous like this.
  6. Jan 24, 2025 at 8:30 PM
    Abell207
    Abell207 New Member
    Anthony
    Maine
    2020 Army Green TRD PRO
    Mine has been installed for almost 2 years now, I haven’t had any fluid loss.
  7. Jan 25, 2025 at 8:05 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Installed 11/2020, no leaks on mine either.
    ZPhilip likes this.
  8. Feb 19, 2025 at 3:01 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Any updates on this? Did you ever check to see if you have staining on your reservoir if the cap is venting off coolant? Just checked mine and the level dropped slightly since I checked last but I see staining on the reservoir from the cap venting. The reservoir cap vents at 16psi by design. If the cap is faulty it could be venting prematurely. You should check this too @nobodyintexas if you were experiencing some coolant loss. May be time for a new cap at a minimum. I could see it explaining some coolant loss but probably not a huge amount.
    nobodyintexas and reywcms like this.
  9. Feb 19, 2025 at 3:15 PM
    Abell207
    Abell207 New Member
    Anthony
    Maine
    No staining on mine.
  10. Feb 19, 2025 at 3:40 PM
    Bluecobra
    Bluecobra New Member
    2014 Tundra
    Mine was leaking slightly when I first installed. I made a gasket for the cap and that solved it.
    HulkSmurf14 and nobodyintexas like this.
  11. Feb 20, 2025 at 3:36 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    yup. might be the culprit.
    I have always suspected the cap sealing as being the problem.
    I always have the dribbles on the side of the reservoir.
    if it was leaking coolant into the motor, I would:
    Throw codes
    have weird exhaust
    misfire?
    I have none of those.
    now....where/how does one source a new cap?
    30 degrees out this morning. see the schmeg around the cap?
    reywcms and Silver17[QUOTED] like this.
  12. Feb 20, 2025 at 3:38 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Please add some color to this comment.
    just a simple rubber grommet on the underside of the cap?
  13. Feb 20, 2025 at 4:33 AM
    Silver17
    Eastern PA
    That’s looks like it could do it. Here you go!
    https://www.ebay.com/itm/1940248002...WB8y48YSDG&var=&widget_ver=artemis&media=COPY
  14. Feb 20, 2025 at 6:32 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
  15. Feb 20, 2025 at 7:23 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    I'd pressure test the cap and system and see if you can find a slow leak. No leaks so far in 2 years on mine.
    If your pump is acting up, it could cause uneven heating and expansion and cause it to vent prematurely as well. Look into replacing the pump too.
  16. Feb 20, 2025 at 7:41 AM
    Bluecobra
    2014 Tundra
    I used some thick rubber that I cut into a circle. Probably 1/32 thick.
    nobodyintexas[QUOTED] likes this.
  17. Mar 10, 2025 at 5:41 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Saltyhero13 and Silver17[QUOTED] like this.
  18. Mar 10, 2025 at 9:25 PM
    blackmax666
    blackmax666 New Member
  19. Mar 10, 2025 at 9:32 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Welcome to the forum. But...its the intercooler reservoir cap.
