1794 Driver's Seat - Need to confirm bottom cushion cover
Discussion in '2.5 Gen Tundras (2014-2021)' started by Maxxam, Feb 18, 2025.
  1. Feb 18, 2025 at 7:44 PM
    Maxxam
    Maxxam [OP] New Member
    Hi All,
    I have a 2021 1794 and would like to replace the drivers side bottom cushion cover with the OEM cover. I've looked at the various online dealer websites for the heated & ventilated cover (in leather/suede) in the proper color but not sure if have seen the correct choice. The closest description for color has been 'Sand'. I don't think this is the correct description for the funky western grade color leather/suede used in the 1794. Can anyone confirm the correct part number?
    Thanks in advance!
    HulkSmurf14 likes this.
  2. Feb 19, 2025 at 6:56 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I don't think it's sand, in the 1794 editions, more of a saddle color, typically. Can you request typical photos of what they are calling "sand?"
    Maxxam[OP] and 1lowlife like this.
  3. Feb 19, 2025 at 10:01 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I don't think it is sand either.
    Call a dealer and give them your VIN; they can give you the correct part number.
    I think this is what you are looking for, call a dealer and verify with your VIN.
    If this is correct, your interior color code is E2
    2018-2021 Toyota Tundra Cushion Cover 71072-0C503-E2 | Sparks Parts
    Passenger seat.
    2018-2021 Toyota Tundra Cushion Cover 71071-0C822-E2 | Sparks Parts
    If you do purchase from Sparks: use the TUNDRAS.COM promo code for 5% off the subtotal.
    That is better than their 25% off shipping.
  4. Feb 19, 2025 at 12:16 PM
    Maxxam
    Thanks a bunch! Not sure why brown did not show up when I was looking at all the color choices but that appears to be the correct part.
    1lowlife[QUOTED] likes this.
  5. Feb 19, 2025 at 12:53 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    It wasn't showing up for me either.
    The passenger and rear seats came up in that color.
    I ended up taking the driver's black ventilated leather part # and replacing the E2 code on the end..:eek2:
    Then for some reason, it came up..:cool:
    When you order make sure to include your VIN.
    I could be wrong..
    *Maxxam* and rdiddy5 like this.
  6. Feb 19, 2025 at 2:54 PM
    *Maxxam*
    *Maxxam* New Member
    Good detective work! :thumbsup: Yep, I used my VIN and it is a match.
  7. Feb 19, 2025 at 5:08 PM
    Sunman54
    Sunman54 New Member
    What is involved with replacing the seat cushion for the driver's seat? My 2015 Tundra LTD needs that same cushion replaced? thanks
  8. Feb 19, 2025 at 6:05 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Remove the seat, take it apart and get yourself a 6 pack and some hog ring pliers. From there you just open up the hog rings pull the cover off the foam, stretch the replacement piece over it, and hog ring it back on. That’s about a 3 beer job. The other three for assembling the seat and putting back in the truck.
    *Maxxam* likes this.
  9. Feb 19, 2025 at 9:05 PM
    *Maxxam*
    *Maxxam* New Member
    My truck only has 15k miles on it but the dude that owned it before me drug his wide load across the seat edge under full gravity. It's not bad (just creased) but the rest of the truck is too nice and I am too particular. I'll do the job myself - I'm not going to replace the foam but I was thinking of using spray adhesive and gluing down some 1/2 (or slightly thinner) good quality foam on the two bottom side bolsters to beef them up a bit and add more tush support. I prefer to not have to take it to an upholstery shop but if anyone has professional advise on how to make the best DYI of it while apart I am all ears!
  10. Feb 19, 2025 at 10:07 PM
    Durk2
    Durk2 New Member
    Colin
    Montana
    2017 SR5
    Looking at replacing some foam as well as covers for my truck so I figured this would be a good place to ask. Sorry if it’s a thread jack.
    first, is the seat frame and foam the same for different trims? Best I can tell it is but I figured I’d ask if anyone has personal experience.
    Second, if the seats do interchange, can I put limited/1794/platinum seat covers on my SR5?
    Am I just over thinking thinking this? Would it be easier to just swap in a whole seat from salvage or something aftermarket?
    TIA
