Front hitch mount for dirt bike.
Discussion in '2.5 Gen Tundras (2014-2021)' started by OhanaTundra, Feb 19, 2025.
  1. Feb 19, 2025 at 9:46 AM
    OhanaTundra
    OhanaTundra [OP] New Member
    Ohana
    2008 Tundra
    I’m building a setup to live in the bed, with a topper, and want to be able to bring my drz. I’ve used a hitch carrier on the back, but that would make it difficult to get in and out. What do you guys think about mounting a hitch on the front? What it put to much stress on the front end? The bike weighs 350lbs, and the ARB bumper weighs 375lbs. I was also considering weather I should try and find a product that bolts on, or have a welder weld it onto the bumper or somewhere else? What suspension modifications would I need? Thanks for any advice. Also one of the pics is me getting stuck last week lol.
    Y0TA PR0 likes this.
  2. Feb 19, 2025 at 10:56 AM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
  3. Feb 19, 2025 at 10:58 AM
    OhanaTundra
    Ohana
    2008 Tundra
    Thanks for the link, I already know that the bumper weighs 375lbs, I’m just not sure if another 350lbs would hurt suspension and other stuff, and what kind of upgrades I would need.
  4. Feb 19, 2025 at 11:07 AM
    SharkDog
    SharkDog New Member
    Denver
    2006 Gray DC Tundra SR5
    Dobinson Twin Tubes. Stock.
    Nothing here is apples to apples, but…
    I have a front hitch that I used to carry a husky 701 on my first gen. I didn’t have any other added weight up front. I thought it worked great. This was with fairly firm bilstein 6112’s up front.
    Only issue for me was that my headlights were largely blocked which bounced a lot of light off the bike into my eyes and let little through. So it really was only a daytime set up.
  5. Feb 19, 2025 at 11:07 AM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    Only way to know if you would hurt anything is to check the weight on the front axle and compare it to the GAWR on the door jamb. Realistically the weight shouldn't be an issue. The front ends on these trucks are pretty stout. You might wear your front wheel bearings and tires a little faster.
    As for supporting mods, you will likely need upgraded front springs to prevent the front end from sagging and hitting the bumpstops constantly. Of course this would make the front ride rather poorly when the DRZ is not there. A small trailer might be a better option if you can swing that.
    RobertD likes this.
  6. Feb 19, 2025 at 12:09 PM
    CasperTheFriendlyTundra
    CasperTheFriendlyTundra New Member
    Ita not just the extra weight of your bike that you have to think about. It's the extra leverage its going to have it mounted out in front of the bumper.
    KNABORES likes this.
  7. Feb 19, 2025 at 3:13 PM
    yakeng
    yakeng 3URFE Apologist
    We installed a front hitch to move around a boat trailer easier in a tight spot that had less than 6" clearance, but as far as driving around with an extra 350+ lbs, I wouldn't do it. It's going to accelerate the wear on your front end suspension. Also, check your state laws (and ones you are traveling through) as it might not be legal to throw a bike in the front for a variety of reasons, such as obscuring the plates, lights, vision, etc.
    Tunrod likes this.
  8. Feb 19, 2025 at 3:23 PM
    littlebus01
    littlebus01 New Member
    Tobias
    21 trd off-road
    Iron Man lift, still-cai, list goes on
    How much does a plow weigh 350???
  9. Feb 21, 2025 at 8:58 AM
    seydou
    seydou Distinguished Member
    I wouldn't do it without upgrading the suspension. The extra weight of the bike and carrier will be out much further with the added width of the ARB, making its impact even greater as another poster stated.
    In addition to blocking the lights, the bike will also block air flow to the radiator.
    rdiddy5 likes this.
  10. Feb 21, 2025 at 9:45 AM
    rdiddy5
    rdiddy5 New Member
    Arizona
    2018 Crewmax 1794 4x4
    You can upgrade your front springs to a heavy duty load.
  11. Feb 21, 2025 at 11:44 AM
    Lifer
    Lifer New Member
    Vince
    2000 Ltd 4x4 2008 SR5 4x4 LB 2021 SR 4x4 LB
    Fab tech on the 2000
    I have one on my 2000 and used a Versahauler for the bike years ago. I would carry an ATV in the bed and pull a 24 foot Mallard trailer.
