Turbo Charging A Tundra!
Discussion in '2.5 Gen Builds (2014-2021)' started by bflooks, Nov 15, 2022.
  1. Feb 17, 2025 at 2:38 PM
    #1741
    centex
    centex New Member
    Did some little stuff today. Removed the trans heating lines. Opened up a lot of room. Mounted my distro block for switched 12v and got that tied in. Moved the meth tank and lines and wires over to the passenger side. Tomorrow and this week the plan is to install the Rago plate and get the cables connected and hopefully finish the wiring and plumbing. Goal is to do the exhaust, turbo, and injectors this weekend and get it fully going.
  2. Feb 17, 2025 at 2:44 PM
    #1742
    TurboKits
    TurboKits New Member
    Heck yeah, cranking!!
    e30cabrio likes this.
  3. Feb 17, 2025 at 2:51 PM
    #1743
    centex
    centex New Member
    Trying to. Weather is supposed to start sucking tomorrow through Friday so I’m going to be limited on what I can do. Thankfully wiring can be done with the garage door closed but it’s still a pia.
    TurboKits and Black@Blue19 like this.
  4. Feb 18, 2025 at 4:59 AM
    #1744
    TurboKits
    Yeah, we got a bad storm, 4-6", then sleet on top, then pouring rain for an hour or 2 and then 15* as the storm pulled out and pulled the cold air in. Some of the back roads are still .25" thick ice!
  5. Feb 18, 2025 at 5:02 AM
    #1745
    bflooks
    bflooks [OP] New Member
    Metrowest MA
    That flash freeze was no joke. My circle is still ice skate ready. Glad it didn't accumulate on the trees and power lines like they were talking.
  6. Feb 18, 2025 at 5:09 AM
    #1746
    TurboKits
    Yeah, we got lucky on the power-side of it, but our whole driveway and road is solid ice. Thick too!
    bflooks[QUOTED][OP] likes this.
  7. Feb 18, 2025 at 5:27 AM
    #1747
    centex
    centex New Member
    Our weather is just drunk.
    M3Tundra-JK and TurboKits like this.
  8. Feb 18, 2025 at 5:30 AM
    #1748
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    That's quite the swing... currently 4°F with -4°F windchill here right now, but going back up to mid 20's for highs in a couple days.
    bflooks[OP] likes this.
  9. Feb 18, 2025 at 6:14 AM
    #1749
    bflooks
    Metrowest MA
    Yeah, that 54* day looks lovely. 70's and 80* would feel like a sauna after our consistent mid-20s to mid-30s winter we've been having. Acclimation is a thing, especially for husky guys. Much like the transmission warming puck on the 2019+ Tundra, we function better when temps are low.
    TurboKits, centex[QUOTED] and Jego like this.
  10. Feb 18, 2025 at 10:12 AM
    #1750
    bflooks
    Metrowest MA
    Got my PML transmission pan yesterday. After having a brief moment of panic, good news for @TurboKits and anyone else who purchased the PML transmission pan.
    Deep end of the PML pan is closest to the turbo crossover pipe. At 5.75"'ish deep, it wasn't likely to fit. However! The PML pan is only 3" deep at the face and has a 2.5" backwards slope as it drops the remaining 2.75" to full depth. So, it WILL clear the crossover pipe and the flex joint. It'll be close, so choose your heat shield of choice for that section of the crossover pipe, but the deeper pan will physically fit. That's based on actual measurements, but not physical installation (I can't do that without a running vehicle to set fluid levels and such).
    If anyone gets to the physical install before me, please post up the confirmation.
    I'm considering either the DEI heat mat, the AC Performance one listed at the bottom of this page (the Amazon knock off of the DEI mat), or the DEI Pipe Shield (assuming it won't wear the flex joint): Amazon.com: Design Engineering 010450 Titanium Pipe Shield 6" x 1' Exhaust Heat Shield : Automotive
    TurboKits likes this.
  11. Feb 18, 2025 at 12:43 PM
    #1751
    centex
    centex New Member
    Why must I over complicate a single gauge? Just about done. Once I get from kid pick up I’ll terminate and mount and it should hopefully fire off. Then on to finish the water meth redo.
  12. Feb 18, 2025 at 12:52 PM
    #1752
    TurboKits
    Phew, great info!
  13. Feb 18, 2025 at 2:00 PM
    #1753
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, DIY Traction Bars, Tuning by snivspeedshop.com
    Geez. I'm still waiting for my pan...
  14. Feb 18, 2025 at 2:05 PM
    #1754
    centex
    centex New Member
    Meth controller in place. Ran out of time to finish the meth system so hopefully tomorrow or Thursday. Depends how froggy I feel with this nasty weather.
  15. Feb 20, 2025 at 10:16 AM
    #1755
    centex
    centex New Member
    Weather is still colder than heck but at least the sun is out. Going to work on the meth pump and wiring after lunch. Not sure if I’ll get the actual turbo on this weekend as the weather is supposed to be nasty again but we’ll see.
  16. Feb 20, 2025 at 10:30 AM
    #1756
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    Nice, the gauge on that mount looks great! Looks like it was a long meeting... haha:rofl:
    centex[QUOTED] and bflooks[OP] like this.
  17. Feb 20, 2025 at 12:48 PM
    #1757
    centex
    centex New Member
    I need an adult.
    I want to mount the pump here.
    Is that going to be to close to the exhaust? It’s essentially the same spot the manual says on the driver side, but it’s the passenger side.
    Jego likes this.
  18. Feb 20, 2025 at 12:49 PM
    #1758
    centex
    centex New Member
    Ya we are getting ready to roll out phase two of an upcoming ERP so we were on a 2hr walk through call today to get people up to speed. I helped do the UAT testing so I was more there for refresher than anything.
    Jego[QUOTED] and TurboKits like this.
  19. Feb 20, 2025 at 1:02 PM
    #1759
    TurboKits
    Make sure you dry mock the downpipe and exhaust piping before adding anything in that area. There is no reason it can't be further back towards the bed too, then it's a non issue if you are putting it on the passenger side.
    Jego and bflooks[OP] like this.
  20. Feb 20, 2025 at 1:14 PM
    #1760
    centex
    centex New Member
    Ya but the frame isn’t boxed so then it’s having to get creative on that so was trying to be lazy.
    Have I mentioned how much I hate wiring?
    Does it matter which wire on the solenoid is tied to the controller and which one is tied to switched 12?
  21. Feb 20, 2025 at 1:37 PM
    #1761
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Is there any concern the pump being exposed to the environment, salt/debri? I know you don't have room in engine bay but that was the reason I mounted mine passenger side rear fender by my ecu.
    Jego likes this.
  22. Feb 20, 2025 at 1:54 PM
    #1762
    TurboKits
    It should not, it's a pass-through Power Open, No Power Closed, just like a fuel injector.
    Jego and centex[QUOTED] like this.
  23. Feb 20, 2025 at 1:54 PM
    #1763
    centex
    centex New Member
    No salt here in Texas and I don’t off road this truck so not a major concern. Instructions have it mounted down there.
    Got a pic of where yours is mounted?
    Jego and TurboKits like this.
  24. Feb 20, 2025 at 1:55 PM
    #1764
    TurboKits
    I've had mine under the truck for years, no issues. But I supposed good cleaning maintenance and protection are a solid plan.
    Mdl[QUOTED] and Jego like this.
  25. Feb 20, 2025 at 2:55 PM
    #1765
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I forgot where you are located and if @TurboKits runs it there with their wintery salt roads then it good. Just was thinking out loud.
    HulkSmurf14, Jego and TurboKits like this.
  26. Feb 20, 2025 at 3:33 PM
    #1766
    TurboKits
    Good info!
  27. Feb 20, 2025 at 3:39 PM
    #1767
    centex
    centex New Member
    6hrs of wiring and I’m fried. I hate that crap. Meth system is 90%. Just need to mount the pump and wire it and then buy a switch for the arming. After that, turbo time.
    Jego, AZTundra, Mdl and 2 others like this.
  28. Feb 20, 2025 at 6:59 PM
    #1768
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    No, it doesn't matter. The solenoid has no polarity.
  29. Feb 20, 2025 at 7:24 PM
    #1769
    centex
    centex New Member
    AEM needs to update their docs because it says to connect to the negative wire.
    Have I mentioned I hate wiring? I get way to in my head and over complicate things. Plus it sucks to run and make look good. Only 4 more terminations though and I’m done.
  30. Feb 20, 2025 at 7:50 PM
    #1770
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    I noted that too. Basically the important thing to know is that the controller provides the negative(-) when active therefore the switched wire must be the 12v (+).
    I totally understand your frustration with the wiring setup. There is a lot to do. In my case is like a therapy:smack: :rofl:. I like to spent time on that but really takes time, a lot of time. It can get complicated specially when you have other important responsibilities. I welded all connections, used heat tubbing, flex split wire conduit, plus recorded everything. Also I made my own harness because the harness that came with the kit was not long enough to reach the tank sensor and the pump installed in the side of the bed.
    My recommendation is to take your time, be patient, don't rush it, try to do it the best you can, if there is something you are not 100% sure ask for it, enjoy the process and share :yay: :muscleflexing:
