3rd Gen rear seat sub box
Discussion in 'Audio & Video' started by WindChillToyo, Feb 18, 2025.
  1. Feb 18, 2025 at 8:30 AM
    WindChillToyo
    WindChillToyo [OP] New Member
    Jeff
    2025 White Tundra Limited
    Power steps, custom wheels.
  2. Feb 18, 2025 at 8:57 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Not my truck.
    WindChillToyo[OP] likes this.
  3. Feb 18, 2025 at 9:00 AM
    WindChillToyo
    Jeff
    Excellent! Thank you for that. I was curious how it would look! :bananadance:
  4. Feb 18, 2025 at 9:02 AM
    ScottieBones
    ScottieBones New Member
    NC
    2025 Limited 4x4 TRD OR
    Interesting. If you run sealed (skip the chimney port), I wonder if the paneling behind seats can be put back on
  5. Feb 18, 2025 at 9:04 AM
    WindChillToyo
    Jeff
    Im thinking the same thing. I am planning on running sealed box. I ordered shallow mount Audio Controls 10s for this.
  6. Feb 18, 2025 at 9:44 AM
    eddiefromcali
    Eddie
    100% Stock
    Just know that this box does tilt up the seat bottom a bit in order to get clearance for the subs.
  7. Feb 18, 2025 at 9:46 AM
    WindChillToyo
    Jeff
    That should be ok for passengers right?
  8. Feb 18, 2025 at 9:52 AM
    eddiefromcali
    Eddie
    100% Stock
    IDK, guess it depends on your passengers. Its only 3/4"...not much but maybe a bigger passenger would feel it more than a kid.
  9. Feb 18, 2025 at 9:54 AM
    WindChillToyo
    Jeff
    ok. Doesn't sound bad for that of a difference. Only big concern is in the past I had problems with aftermarket subs and dealing with Active Noise Cancellation crap. I hope I don't run into that issue. Its a pain to chase after!
  10. Feb 18, 2025 at 9:58 AM
    eddiefromcali
    Eddie
    100% Stock
    I turned off ANC via carista. No issues on these trucks with JBL...even less for non-JBL trucks. I went with a Rockville sealed dual 10 box. My Hertz subs dont touch the seat bottom, no need to raise it
  11. Feb 18, 2025 at 10:02 AM
    WindChillToyo
    Jeff
    Okay cool. I'll check that out. So I did the jump and purchased the fox acoustic box, with audio control amp, audio control micro epicenter line converter and audio shallow mount 10s. I've always been a bass head. The JBL mids and highs are pretty good since I installed the Sonicbeat mini amp. Definitely woke them up.
    eddiefromcali likes this.
  12. Feb 18, 2025 at 10:08 AM
    eddiefromcali
    Eddie
    100% Stock
    Similar setup as mine. I also went with AC products other than subs. Epic 1500 amp, epicenter and lc2i pro.
  13. Feb 18, 2025 at 10:10 AM
    WindChillToyo
    Jeff
    Audio Control definitely makes quality stuff!!
  14. Feb 18, 2025 at 10:32 AM
    WindChillToyo
    Jeff
    For your LC2, where did you tap into for your signal? Did you use the JBL sub wires or door speakers? I'm just trying to understand where I should get my signal from.
  15. Feb 18, 2025 at 10:34 AM
    eddiefromcali
    Eddie
    100% Stock
    Used the TakoTunes harness. They tap into rear door and sub signal to sum them, gives you a wider range and you can just set your xover accordingly. Their harness taps into the amp under the driver seat. That's where my lc2ip is at as well.
  16. Feb 18, 2025 at 10:51 AM
    WindChillToyo
    Jeff
    Which one did you get? They are trying to sell me this complete unit for $650!
  17. Feb 18, 2025 at 11:06 AM
    eddiefromcali
    Eddie
    100% Stock
    2022+ JBL EQUIPPED Tundra BUDGET FRIENDLY Add a subwoofer Harness package – Modified signal (POST-JBL amp signal)
    https://tinyurl.com/kv6h3tub
  18. Feb 18, 2025 at 11:07 AM
    WindChillToyo
    Jeff
    Okay. I was making sure. Thanks!!
