Transmission fluid swap
Discussion in '3rd Gen Tundras (2022+)' started by Dozer466, Feb 13, 2025.
  1. Feb 16, 2025 at 11:43 AM
    Dozer466
    Dozer466 [OP] New Member
    2022 Tundra TRD Pro
    Westcott 3/1, 37" Toyo's, Smartcap
    I drove about 20 miles between each drain and fill. My thermostat is also pinned open.
    303Gen3[QUOTED] likes this.
  2. Feb 16, 2025 at 11:45 AM
    I thought there was a removable dip tube so you could get it all out?
  3. Feb 16, 2025 at 11:53 AM
    JDAZ
    JDAZ New Member
    It doesn't all come out. There is still at 2+ qts in the pan. I got almost 7qts total when I drained my pan and then removed it
    KNABORES[QUOTED] likes this.
  4. Feb 16, 2025 at 11:54 AM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    Valvoline is good too. I did a complete exchange when I had my 15 Tacoma that used WS.
  5. Feb 16, 2025 at 12:59 PM
    Tom976
    Tom976 New Member
    Tom
    OEM Toyota WS is about 12.50 to 14.00 a quart. (theres your baseline)
    AISIN, ATF0WS Arguably the only closest things to OEM. Paid on Rock 7.50 a quart.
    (some people feel only oem for longevity, others like the instant savings of MaxLife (forum reviews can vary on they feel it works))
    I went with AISIN, they are the manufacturer of the transmission. They know what it likes.
    $25.92 bucks for Maxlife (Just checked Ama....) (1 gallon container)
    30 for AISIN, ATF0WS (4 bottles @ 7.50 each) Rock does charge to ship.
    54 for Toyota OEM WS (figure 13.50 per quart x 4)
    What I dont trust with MaxLife is that it covers specs from all over the place.
    Dexton 2,3.... Honda, Toyoto, Mercedes, BMW....
    How can one lubricant cover all of them? Does it cure cancer too?
    Dont get me wrong, stuck on the side of the road and need to fill it?
    No problem. If at home doing maintenance? Not going to cheap out for only a few bucks.
  6. Feb 16, 2025 at 2:04 PM
    bailey bulldog
    bailey bulldog New Member
    What about undoing the transcooler line?
  7. Feb 16, 2025 at 2:43 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Way easier. Pin the t stat, pull a cooler line and turn the truck on to pump 2 or 3qts out. Dump same amount back in. Do that 3 or 4 times and you're set.
    Tom976, JDAZ and KNABORES like this.
  8. Feb 16, 2025 at 4:18 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Holy moly. That looks like it’s been in for 200k miles.
  9. Feb 16, 2025 at 6:07 PM
    JohnF4x4
    JohnF4x4 New Member
    US
    2025 Platinum
    Is there any data for those oils where one can see the difference?
    My uneducated and ignorant understanding, it does not "cover" all of them, it is just the requirements for the ATF are so close to each other that by adding a couple of more additives they "cover" many manufacturer's requirements. Probably i'm wrong, but it is just my thought, so just putting it out.
    BTW, my 2008 4runner uses this ATF for 244,000 miles and never complained, knock on the wood.
  10. Feb 16, 2025 at 6:35 PM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
  11. Feb 16, 2025 at 8:44 PM
    JDAZ
    JDAZ New Member
    This is the way
  12. Feb 17, 2025 at 7:58 PM
    Retroboy1989
    Northern Utah
  13. Feb 18, 2025 at 1:34 AM
    eddiefromcali
    Eddie
    100% Stock
    Did a 2.5gal pump and dump change. Oem fluid looked just like OPs. I'll probabky do another 6 quarts in 1 or 2k miles.
    All I did was pull the lower hose from the t stat and pumped out 3qts, added 3, pump 3, add 3. Color definitely improved but still on the darker side.
    MVRCA likes this.
  14. Feb 18, 2025 at 6:56 AM
    Retroboy1989
    Northern Utah
    Miles? What brand of fluid?
  15. Feb 18, 2025 at 7:02 AM
    eddiefromcali
    Eddie
    100% Stock
    37k. Amsoil
