2019 Tundra fueling issue
Discussion in '2.5 Gen Tundras (2014-2021)' started by Red River Rancher, Dec 23, 2024.
  1. Dec 23, 2024 at 8:05 AM
    Red River Rancher
    Red River Rancher [OP] New Member
    Pat
    2019 Tan Toyota Tundra
    I have a 2019 Tundra with a 38 gallon fuel tank. Over the past few years had lots of issues refueling when tank was 1/2 empty. Very slow fueling and gas pump would kick off constantly even at very slow refueling rates. In last year gas now comes shooting out of the filler tube onto the ground. Had charcoal canister replaced twice, once by me and then 2nd by Toyota dealership two weeks ago. Toyota service rep said it had to be charcoal canister based on their computer scan and that somehow the two vent lines were plugged up with dust. After $1100 in service cost I ran the truck to empty, went to gas station and ended up with the exact same issue with refueling. So I assume it is not a charcoal canister problem unless the new one failed after two weeks. Refueling issue is not as bad once the tank is about 2/3 full. Any suggestion or ideas? Truck has 101,000 miles on it.
  2. Dec 23, 2024 at 8:26 AM
    I'm wondering if it could be the anti-siphon or anti-rollover valve. @250000yota might be able to provide some input.
  3. Dec 23, 2024 at 9:11 AM
    250000yota
    250000yota New Member
    Russ
    Berthoud, CO
    White 2015 SR5 Crewmax
    S&B intake, Dirty Deeds 8", Airlift airbags with Daystar contact cups, LED's everywhere including Diode Dynamics stealth front LED bar, Baja Design Squadron II's on CBI ditch light brackets, completed Diode Dynamics interior LED's. Full RCI skids with cat guards and sliders, Transfer flow 46 gallon tank. Radflo 2.5 IFP coilovers, Coachbuilder shackles, TRD rear sway bar. 295/70R18 Nitto RG's. Dobinson snorkel, softopper.
    I'd be concerned with the rollover valve as well. Not on my Tundra, but on my T100 I fought this exact issue for years. I'd have to have the gas nozzle half way out of the filler with it on one of the slower settings to fill the tank. I finally bit the bullet and replaced the rollover valve. The only thing I'm not certain of is whether it's part of the tank itself or not. I still have my 26 gallon tank in the shed, I'll go take a look at it when I get a chance. Might not be today, but I'll look.
    Rdrcr and ColoradoTJ like this.
  4. Dec 23, 2024 at 10:00 AM
    2020_Tundra
    2020_Tundra New Member
    2020 MGM Platinum
    ColoradoTJ and Tunrod like this.
  5. Dec 23, 2024 at 3:17 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Sounds like it’s the flap in the fuel filling hose that’s stuck closed and it is causing the pump to shut off suddenly alongside with slow fueling.
  6. Feb 17, 2025 at 7:09 PM
    Red River Rancher
    Pat
    As an update I am on the third charcoal canister and a new ECM and still have the same problem. Whenever Toyota replaces the charcoal canister, they fill up tank and say they have no issues doing so. After I drive it to 1/4 tank full and try to refuel, gasoline comes shooting out the filler tube and onto the ground after 1.5 to 2 gallons of gas pumped at slowest speed. Truck now back a dealership and they are sending codes to Toyota but still have not fixed the issue. Said they dropped the fuel tank this time but have not told me what they found but the truck still in shop so must not be repaired. When I remove gas cap to refuel the entire fuel storage system is under pressure and and the pressure is released when I remove cap. No idea what is causing that but seems to be a side effect of what is going on. This pressure has been present since I have had the issue with refueling and gas spilling out the filler tube. Will update if and when they figure out what the problems are.
    BrandonL812 likes this.
  7. Feb 18, 2025 at 1:56 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Read above and research rollover valve. Try the search function on this forum. Many people have had same issue.
