UCA install issues.
Discussion in 'Suspension' started by Pilotjoe123, Feb 6, 2025.
  1. Feb 6, 2025 at 10:28 AM
    Pilotjoe123
    Pilotjoe123 [OP] New Member
    Joe
    2019 Tundra Sport red
    I’ve recently installed jba upper control arms and the inside fitment is too tight. It’s requiring a pry bar to spread the arms to install. I called them and they said it’s normal for tundras to have different sized bolt tubes. They said I need to just grind the tubes until they fit. Has anyone come across this probably with other companies of does jba just have a design problem?
  2. Feb 6, 2025 at 10:40 AM
    AND
    AND New Member
    Washington, PNW
    Sounds like BS, you shouldnt hve to grind them to fit, you should also have space to fit washers and bushings.
    Posy pictures of the issue
  3. Feb 6, 2025 at 10:42 AM
    Pilotjoe123
    Joe
    IMG_8391.png They’re in but absolutely smashed.
  4. Feb 6, 2025 at 10:49 AM
    AND
    AND New Member
    Washington, PNW
  5. Feb 6, 2025 at 10:55 AM
    Pilotjoe123
    Joe
    I called both them and camburg and shouldn’t be grinding. Hopefully they done screw me on a return.
    AND[QUOTED] likes this.
  6. Feb 6, 2025 at 11:25 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    I've has three sets of JBA's and never had an issue installing them. The last set on my Tundra I had to line them up just right to get them on, it was a little tight but they fit and worked fine. If they are in, I would just grease them up and not worry.
    equin likes this.
  7. Feb 17, 2025 at 6:27 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    The passenger side on mine was kind of a pain to line up and get that bolt in. I had my son use an aluminum bat to pry the rearward bushing up just enough to line it up correctly and tap that bolt through (it wouldn't slide in like the driver side). Either way, both sides were the right size and didn't need to be pried apart. There was still enough of a gap to easily fit when I test fit them, even with the washers on.
  8. Feb 17, 2025 at 9:05 PM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    My Icons went in fine no issues on my gen3
