Clock and Radio no power 2012 Tundra
Discussion in 'Audio & Video' started by todd95, Jul 19, 2023.
  1. Jul 19, 2023 at 2:41 PM
    todd95
    todd95 [OP] New Member
    Todd
    I just replaced my AC compressor, evaporator and condenser. Wow what a job..
    To do the Evaporator you have to take the whole dash apart. Well I thought we nailed it but we have no power to radio or clock on the dash. I have looked at all the fuses and swapped things out to make sure .... And they are all good. I have check all the grounds under the dash. And I am still at a loss. It work just great before. Any suggestions please.
    My ACC fuse under the drivers side is good but doesnt seem to be getting much electricity when I put the volt meter in it. All the windows, lights, and other things are working.
  2. Jul 19, 2023 at 3:02 PM
    2mchfun
    First, why would you need to replace the evaporator at such a young age? Was it leaking? Secondly, all I can think is that maybe you missed a plug. There are full wire diagrams on the forum. Go to forums button, garage heading, then electrical sub heading. From there find the diagrams and let the fun begin. I'd sure double check all the fuses first, both under the hood and under the dash. Good luck!
    BTW, Welcome to the forum from OKC!
  3. Jul 19, 2023 at 7:43 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    Define not much electricity to the ACC fuse.
    Can you post more of what exactly is working vs what is not?
    I know the accessory meter (center dash screen with clock and temp) and the radio have a similar sized connector. I have seen people get the two mixed up and plugged into the wrong spot before.
    Check power to fuses would be where I would start. Need a good multimeter obviously.
    2mchfun likes this.
  4. Mar 1, 2024 at 10:08 AM
    Sneaky_Rascal
    Sneaky_Rascal New Member
    2008 Crewmax Limited.
    I'm having the same issue, after fixing my ac. OP, did you end up figuring it out?
    Dags0825 and carolinasauto like this.
  5. Mar 4, 2024 at 7:27 AM
    Truedreco
    Truedreco New Member
    2012 Black Tundra Crewmax TSS
    Wondering if anyone ever figured this out. I just got my 2012 tundra truck back from dealer after a wiring harness job (squirrel damage) and now radio/clock/temp not working. Fuses look good.
  6. Aug 7, 2024 at 2:45 PM
    carolinasauto
    carolinasauto New Member
    Tundra
    Has anyone figured out the radio and clock not working Issue? after having to remove dash and all to replace heater core and EVAP Core....
    Dags0825 likes this.
  7. Feb 9, 2025 at 7:59 AM
    Dags0825
    Dags0825 New Member
    Daniel
    2007 Silver Tundra SR5
    Has anyone figured this out by any chance. I just removed my dash to swap out the heater core and after putting it back together I don’t have power to my radio, clock, or blower motor.
  8. Feb 17, 2025 at 5:01 PM
    Dags0825
    Dags0825 New Member
    Daniel
    After reading a bunch online I ended up figuring out it is a connector behind the fuse box on the drivers side. I attached a picture below to this post so everyone can see it and hopefully help someone. As for my AC blower problem it ended being a defective motor that kept popping the fuse on the fusible which was a pain to take out but after putting in my original part and swapping the fusible for the third time everything finally works
