How to reset tire pressure sensors?
Discussion in 'Wheels & Tires' started by Alt0174, Feb 16, 2025.
  1. Feb 16, 2025 at 4:33 PM
    Alt0174
    Alt0174 [OP] New Member
    Virginia
    2021 Limited
    Chromerectomy
    Anyone know how to reset the tire pressure sensors? I noticed that they were reading the wrong tire location and tried to reset it using the instructions in the manual. Set the ignition to "on", pressed the button until the light blinked 3 times, then drove for 45 minutes above 25 MPH, but it still isn't reading. I've done this a couple of times now and nothing. What am I doing wrong?
    2021 Limited
  2. Feb 16, 2025 at 4:49 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Just drive normally for a while. Don’t just drive at 25 mph. If it doesn’t register then just turn the truck off. As long as the sensor isn’t blinking it’s still calibrating. Redoing the procedure over and over won’t help.
  3. Feb 16, 2025 at 4:55 PM
    Alt0174
    Virginia
    2021 Limited
    Chromerectomy
    Yeah, I tried just that on my way home from work Thursday. When I drove the truck Friday it still wasn't reading.
  4. Feb 16, 2025 at 4:58 PM
    Danman34
    Danman34 New Member
    Danny
    Like most electronics, unplug and plug back in. In this case. Disconnect the negative terminal on the battery. Turn on the headlight switch to drain any capacitive power. Wait 5-10 mins and hook it back up and try the procedure again.
    Alt0174[QUOTED][OP] likes this.
  5. Feb 16, 2025 at 5:18 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    2021 DC SR5 4x4 (guess the color)
    Just let it do its thing. Last time I reset my TPMS (a couple weeks ago) it took 3 days to register. I occasionally get a TPMS warning message.
    I assume the E load Wildpeaks are messing with the signal, or one of the batteries is weak
    Alt0174[OP] likes this.
  6. Feb 16, 2025 at 5:31 PM
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    On one occasion it took three days to register. The fastest was a 30 min. drive on the interstate going 70 mph.
  7. Feb 16, 2025 at 5:37 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Mine usually says recalibrating when it’s doing its thing. Same steps as you, however my tpms light is also on since its from switching my tires. I have to wait 1 min after turn “on” for the tpms to stop blinking.
  8. Feb 16, 2025 at 5:39 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    Unfortunately, I found that removing disconnecting the battery (even overnight) will not cancel the TPMS registration procedure.
    I don’t understand why it’s so problematic with Tundras. My 4Runnner always connects quickly
  9. Feb 16, 2025 at 5:42 PM
    Danman34
    Danman34 New Member
    Danny
    Yea. I’ve never had an issue with my tundra. Reset takes no more than 5-10 minutes.
  10. Feb 16, 2025 at 5:44 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Alternatively drive to discount tire or similar and they have a tool that reads each sensor and manual plugs into the truck via obd2. Sometimes between my rigs one just won’t ever take the tire swap/tpms reset process.
  11. Feb 16, 2025 at 5:47 PM
    Alt0174
    Virginia
    2021 Limited
    Chromerectomy
    Thank you, I'll try this one tomorrow!
  12. Feb 17, 2025 at 5:45 AM
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    U know when u disconnect that cable u need to ground that cable to drain residual charge from system
  13. Feb 17, 2025 at 6:14 AM
    The 20/21 is a pita when it comes to TPMS. That's why I bought an Autel TS508.
