Transmission fluid swap
Discussion in '3rd Gen Tundras (2022+)' started by Dozer466, Feb 13, 2025.
  1. Feb 16, 2025 at 11:43 AM
    Dozer466
    Dozer466 [OP] New Member
    2022 Tundra TRD Pro
    Westcott 3/1, 37" Toyo's, Smartcap
    I drove about 20 miles between each drain and fill. My thermostat is also pinned open.
    303Gen3[QUOTED] likes this.
  2. Feb 16, 2025 at 11:45 AM
    I thought there was a removable dip tube so you could get it all out?
  3. Feb 16, 2025 at 11:53 AM
    JDAZ
    JDAZ New Member
    NJ
    2022 Lunar Rock TRD Limited
    Chrome Delete, TRD Pro Grill with BD light bar & OEM switch Beatsonic Amp Undercover armor flex cover
    It doesn't all come out. There is still at 2+ qts in the pan. I got almost 7qts total when I drained my pan and then removed it
    KNABORES[QUOTED] likes this.
  4. Feb 16, 2025 at 11:54 AM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    Valvoline is good too. I did a complete exchange when I had my 15 Tacoma that used WS.
  5. Feb 16, 2025 at 12:59 PM
    Tom976
    Tom976 New Member
    Tom
    OEM Toyota WS is about 12.50 to 14.00 a quart. (theres your baseline)
    AISIN, ATF0WS Arguably the only closest things to OEM. Paid on Rock 7.50 a quart.
    (some people feel only oem for longevity, others like the instant savings of MaxLife (forum reviews can vary on they feel it works))
    I went with AISIN, they are the manufacturer of the transmission. They know what it likes.
    $25.92 bucks for Maxlife (Just checked Ama....) (1 gallon container)
    30 for AISIN, ATF0WS (4 bottles @ 7.50 each) Rock does charge to ship.
    54 for Toyota OEM WS (figure 13.50 per quart x 4)
    What I dont trust with MaxLife is that it covers specs from all over the place.
    Dexton 2,3.... Honda, Toyoto, Mercedes, BMW....
    How can one lubricant cover all of them? Does it cure cancer too?
    Dont get me wrong, stuck on the side of the road and need to fill it?
    No problem. If at home doing maintenance? Not going to cheap out for only a few bucks.
  6. Feb 16, 2025 at 2:04 PM
    bailey bulldog
    bailey bulldog New Member
    What about undoing the transcooler line?
  7. Feb 16, 2025 at 2:43 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Way easier. Pin the t stat, pull a cooler line and turn the truck on to pump 2 or 3qts out. Dump same amount back in. Do that 3 or 4 times and you're set.
    raylo, Tom976, JDAZ and 1 other person like this.
  8. Feb 16, 2025 at 4:18 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Holy moly. That looks like it’s been in for 200k miles.
  9. Feb 16, 2025 at 6:07 PM
    JohnF4x4
    JohnF4x4 New Member
    US
    2025 Platinum Windchill Pearl with AVS
    Is there any data for those oils where one can see the difference?
    My uneducated and ignorant understanding, it does not "cover" all of them, it is just the requirements for the ATF are so close to each other that by adding a couple of more additives they "cover" many manufacturer's requirements. Probably i'm wrong, but it is just my thought, so just putting it out.
    BTW, my 2008 4runner uses this ATF for 244,000 miles and never complained, knock on the wood.
  10. Feb 16, 2025 at 6:35 PM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
  11. Feb 16, 2025 at 8:44 PM
    JDAZ
    JDAZ New Member
    NJ
    This is the way
  12. Feb 17, 2025 at 7:58 PM
    Retroboy1989
    Northern Utah
  13. Feb 18, 2025 at 1:34 AM
    eddiefromcali
    Eddie
    100% Stock
    Did a 2.5gal pump and dump change. Oem fluid looked just like OPs. I'll probabky do another 6 quarts in 1 or 2k miles.
    All I did was pull the lower hose from the t stat and pumped out 3qts, added 3, pump 3, add 3. Color definitely improved but still on the darker side.
    MVRCA likes this.
  14. Feb 18, 2025 at 6:56 AM
    Retroboy1989
    Northern Utah
    Miles? What brand of fluid?
  15. Feb 18, 2025 at 7:02 AM
    eddiefromcali
    Eddie
    100% Stock
    37k. Amsoil
  16. May 25, 2025 at 8:37 AM
    MikroT
    MikroT New Member
    Dom
    2024 Tundra Hybrid
    Any further details on this - Does it matter which hose I pull off - the line closer to the pin? How long do I keep the truck on to pump 2-3 quarts.
  17. May 25, 2025 at 10:56 AM
    JohnF4x4
    JohnF4x4 New Member
    US
    What advantages of pulling the hose vs. opening the drain plug?
  18. May 25, 2025 at 11:15 AM
    eddiefromcali
    Eddie
    100% Stock
    Which hose doesn't really matter, as long as you pin the tstat open. I used the bottom hose as that is the OUT line. Just takes a couple of seconds...I was using my remote start, but having someone in the truck would be safer.
    Pan doesn't drain everything. I wanted to do a big exchange in one go...pan drop or drain just gets rid of 4 or so quarts.
    raylo likes this.
  19. May 25, 2025 at 12:32 PM
    JohnF4x4
    JohnF4x4 New Member
    US
    Drain plug drains exactly the same ~3 quarts every time as the hose pull. Do it 3-4 times exactly as hose pull and you are GTG. When you drop the pan you empty 4 quarts the max. So, pretty much the same, not 100%.
    But watewer, different jerks for different folks ;)
  20. May 27, 2025 at 8:44 PM
    #50
    Retroboy1989
    Northern Utah
    I'm all about the annual drain and fill. It keeps fresh additives coming in and keeps the fluid a nice color.
    This year I will replace the magnafine filter I added to the return line after my aftermarket cooler. I'm expecting the trans fluid to be a bit darker this year as it went through trans break-in.
  21. May 28, 2025 at 9:54 AM
    #51
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield, AMP power boards
    That's how I did my Tacoma when I had a real remote start. If and when I get around to this job on the Tundra I'll need a helper. BTW, the OP's fluid was seriously ugly. When I did my Tacoma at 100,000 miles the OEM WS that I drained out looked brand new.
  22. May 28, 2025 at 10:08 AM
    #52
    pursuit2550
    pursuit2550 New Member
    So after 100k your oil was cherry bright red? No discoloration at all? If you put your oil and a brand new quart of WS in a glass cup, you couldn't tell them apart?
  23. May 28, 2025 at 10:10 AM
    #53
    eddiefromcali
    Eddie
    100% Stock
    mine looked like OP's as well. Probably some initial break in material
  24. May 28, 2025 at 4:58 PM
    #54
    JDAZ
    JDAZ New Member
    NJ
    Clear a few things up in this thread. Draining the pan is not the same as pulling a cooler hose off. If you empty the pan and fill the pan, as soon as you start the truck, the old fluid returning to the pan from the cooler mixes with the new fluid. So the idea here is to pull off the correct cooler hose and divert it into a container so no mixing occurs. So the best way to do the fluid exchange is to drain the pan as much as possible, fill the pan with the amount drained out, remove the return hose, and do 3 qts at a time. After 11 or 12 qts, you should have cherry red fluid as the oil is pushed through in a serial fashion and very little mixing occurs. I did a write up on changing the filter and exchanging the fluid. I hope these comments and my write up can help someone but if you are doing the drain and fills and that's what you are comfortable doing, please keep doing them.
    TXBrit and Tundrastruck91 like this.
  25. Jun 3, 2025 at 9:59 PM
    #55
    TerraOnMyTundra
    TerraOnMyTundra New Member
    Personally I'm a fan of.....
    Draining pan/vac hosing pan. Refilling what you took out + enough weep out fill plug. Run vehicle. Pin open tstat, using the cooler lines to pump old fluid out, and new fluid at the same time, at the same rate.
    That way you have pretty fresh fluid.
    You could also just pump fresh fluid in and and old fluid out until it runs clear, but that usually requires a bit extra fluid, more expensive.
  26. Jun 3, 2025 at 10:08 PM
    #56
    Retroboy1989
    Northern Utah
    The cooling/lubricating circuits are separate from the main high pressure and torque converter fluid routes.
    You will always have mixing of old and new as fluid doesn't not flow in series, there are different, parallel circuits. This means much of the fluid suspended in the valve body, TC, clutch actuators, etc will be sent back to the pan, not the cooling lines.
    That said, I can see your best shot at replacing all the fluid is pan first, then cooling lines.
    My preference is to start at low mileage doing the pan annually. No cooler lines for this bandito.
    Mr Rick likes this.
  27. Jun 23, 2025 at 9:10 AM
    #57
    Xcumminsguy
    Xcumminsguy New Member
    NY
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
    Is there an inspection cover and a way to access the converter to drain it? I did a tranny fluid drain and replace in my wife's Highlander a few yrs back and drained the converter as well.
