Led bulb for headlights?
Discussion in 'Lighting' started by Tundra701, Oct 15, 2017.
  1. Oct 15, 2017 at 10:00 AM
    Tundra701
    Tundra701 [OP] New Member
    Tundra trd off road sr5 doble cab
    Does anybody is been installing led bulbs for headlights .. any ebay kind and just plug and play ?
    040Tundra likes this.
  2. Oct 15, 2017 at 10:18 AM
    Seen few on here and in person praise Hikari LEDs
  3. Oct 15, 2017 at 10:23 AM
    AxelsHumanDad
    AxelsHumanDad Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    Stay away from the cheap ones. From what I've read the cheapies have terrible beam scatter. I had it narrowed down to two choices, both quite spendy for light bulbs. This week I came across a deal here in the forum for the Philips X-treme Ultinon bulbs and jumped. I just got them installed, I'll check them out this evening.
    Pudge and Viper3G like this.
  4. Oct 15, 2017 at 2:00 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    You wont be disappointed. Huge difference. I did the same.
    OP, here ya go: https://www.amazon.com/gp/product/B013DHXKK8/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1
  5. Oct 15, 2017 at 3:00 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I bought the Hikari ones for my 2016 CM and they are frickin’ bright. Almost too bright but I’ve only had one person flash me so that’s good. Anyway, I can see a country mile with them. I highly recommend them.
    Install wasn’t that bad either. Pretty easy.
    War_Wagon312 likes this.
  6. Oct 15, 2017 at 3:02 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
  7. Oct 15, 2017 at 3:39 PM
    Tundra701
    Any other way to replace the bulbs without taking the front grill .. ?
    CoTundra05 likes this.
  8. Oct 15, 2017 at 3:44 PM
    Tundra701
  9. Oct 15, 2017 at 4:59 PM
    Viper3G
    Viper3G Why isn't work more like this?
    Rick
    2016 Crew Max 1794 4WD Super White
    Phillips X-treme Ultinon LED H4 bulbs, 3M Color Stable 35 tint on front doors, 3M Crystalline 40 on sunroof, OEM bed liner, OEM running boards, Morimoto fog LEDs, Fold-A-Cover G4 Elite, Husky X-Act Contour floor mats
    I don't think so. Removing the grill lets you remove the panel below the headlights. The tricky part for me was figuring how the bottom latches on the grill released. If you want a pic I may have one somewhere. I got the Phillips ones. Expensive for sure, but they work well and I haven't been flashed at night.
    AxelsHumanDad likes this.
  10. Oct 15, 2017 at 5:10 PM
    ScikoticTundra
    ScikoticTundra New Member
    Cameron
    2017 Super White TRD CM
    Fox 2.5 coils w/ remote reservoir, Fox 2.0 rear shocks w/ remote reservoir, Camburg 1.5 Uniball UCA, Camburg rear shackles, Method Mesh 18x9 wheels, Nitto Ridge Grappler 35x12.5x18 tires
    When you purchase the Phillips lights, what all comes in the box??
  11. Oct 15, 2017 at 5:13 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    You get what you pay for. Philips has no fans/moving parts unlike the cheap LED's that do. Do you think all LED's are created equal? Definitely not.
    Bulb, wiring and control box. Everything is plug and play.
  12. Oct 15, 2017 at 5:25 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Nope
  13. Oct 15, 2017 at 5:26 PM
    Baja Mike
    South Bay, Ca.
    Yup. Worth it. Name brand bulb. Look at the reviews of the other brands.
    Nope. Don't worry though, a 10mm socket and a trim tool (which you should have as a Tundra owner) and you can take the front of the Tundra apart in 10 minutes. These trucks are built like LEGOs.
  14. Oct 15, 2017 at 5:36 PM
    AxelsHumanDad
    2015 CM Platinum
    ding ding! See what he said there. I wanted the Philips for the no fans.
    I'm happy as a clam in shit with mine!
    Even better that I didn't pay full price!:jellydance:
    Viper3G and BlueBottle[QUOTED] like this.
  15. Oct 15, 2017 at 5:42 PM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    I've had the Philips Ultinons for about 2 months now. They are definitely an improvement over stock and easy to install. I think the low beam pattern is pretty good on them. The high beam pattern has more noticeable scatter, but it's usable. I'm not too worried about the high beam scatter personally since I have additional LEDs cubes and bar if I need more light. I got them new on ebay for around $170, but it took over a week to get them. They shipped from Malaysia even though the seller said they'd come from NJ.
    The 8th gen JDM Astar H4's are supposed to have in improved design and might be close to the Ultinons. They run around $120 and get good reviews on Amazon, assuming the reviews are legit. Some reviews mention quality control issues, though.
  16. Oct 15, 2017 at 5:43 PM
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2016 Pro MGM CM
    Toyo MT 285/70/R18, led's all around, Baja Design squadron sport fogs, spider trax 1.5 spacers, led foot well lighting, interior chrome delete, kc hilites 40inch light bar grill mounted, 20%tint all around, color lugs black lugnut caps, 2019 pro head lights, led lights all around, spyder co tail lights, DMX1057xr, super crew box with kicker 10” sub,jbl door speakers, factory amp bypass trd air flow accelerator with drop in filter, x3 battery, Toyota bed cover, swing case,
    Gtr gen 3 leds from headlight revolution. Plug and play. Very bright with a very nice beam pattern.
  17. Oct 15, 2017 at 5:44 PM
    How bout from in cab looking out in dark area if possible highs n lows
  18. Oct 15, 2017 at 5:46 PM
    Post pics from in cab highs and lows with fogs
    AxelsHumanDad[QUOTED] likes this.
  19. Oct 15, 2017 at 5:48 PM
    Nope gotta come off fairly easy to do
  20. Oct 15, 2017 at 6:14 PM
    War_Wagon312
    Rich
    2016 Pro MGM CM
    Gimme a sec I'll go take some
  21. Oct 15, 2017 at 6:19 PM
    Viper3G
    Rick
    Like @BlueBottle said, bulbs, heat sinks, control modules and even tie wraps for the cables. The only thing I bought separately was some outdoor double sided tape to mount the control modules.
  22. Oct 15, 2017 at 6:20 PM
    Much appreciated!
  23. Oct 15, 2017 at 6:40 PM
    War_Wagon312
    Rich
    2016 Pro MGM CM
    Low, high then low with BD squadron sports in a couple different areas around town.
  24. Oct 15, 2017 at 6:42 PM
    War_Wagon312
    Rich
    2016 Pro MGM CM
    The gen 3 GTR bulbs come with adhesive for the boxes :) check them out.
  25. Oct 15, 2017 at 7:02 PM
    Hell yeah!!! Me likey! Thank you Sir!
    War_Wagon312[QUOTED] likes this.
  26. Oct 15, 2017 at 9:15 PM
    Tundra701
    I got the bi xenon 6000k really bright but after a week the harnes went so input the stock ones again but i hate them i love bright stuff . Does anybody have or has hids kit or bi-xenon kit ?
  27. Oct 15, 2017 at 9:18 PM
    War_Wagon312
    Rich
    2016 Pro MGM CM
    The bulbs above are what I have. I think they are well worth the price. The warranty is outstanding so you won't eat the price if they fail on you.
  28. Oct 16, 2017 at 6:19 AM
    SleeperTRDPro
    SleeperTRDPro The small package good things come in
    Austin, Texas
    I'm loving my 8th Gen JDM Astars. They are brighter than OEM and light color matches my Morimoto Fog Lights perfectly. Main thing for me is to have white light, my eyes see things so much clearer.
  29. Mar 5, 2018 at 5:37 AM
    ScooterInNV
    ScooterInNV New Member
    Robert
    San Antonio, TX
    2019 VooDoo Blue TRD Pro
    Lift, AMP steps
    Did you need to add resistors to keep the lights from flickering or the fogs from coming on?
  30. Mar 5, 2018 at 8:31 AM
    SleeperTRDPro
    Austin, Texas
    The bulbs come with everything needed for installation. Yes there is a ballast or resistor type device that plugs in.
    ScooterInNV[QUOTED] likes this.
