  1. Feb 15, 2025 at 1:17 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    The left side block plug is a PITA when you're old and extra large :muscleflexing:
  2. Feb 15, 2025 at 1:20 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    Out with the old and in with the new... upgrade and it do make a difference.Pic is the original fan motor PXL_20250215_203930905.jpg :benchpress:
  3. Feb 15, 2025 at 2:26 PM
    yakeng
    yakeng 3URFE Apologist
    now I’m actually shocked, you didn’t clean it to make it look like that?
    Also, looks like I will be picking up another Lisle tool in the future.
    bulldog93 and OHwendTrd[QUOTED] like this.
  4. Feb 15, 2025 at 2:47 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
  5. Feb 15, 2025 at 3:00 PM
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    Changed the oil yesterday and put on the the Fumoto oil drain valve. Have to say, the attention to detail with the RCI skid plates with the filter door and the notch where the oil pan drain valve is very nice!
  6. Feb 15, 2025 at 3:07 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I read between the lines
    Good play
  7. Feb 15, 2025 at 7:37 PM
    Quicksand_Tundra
    Quicksand_Tundra New Member
    Jon
    2019 Quicksand Tundra CM 4x4
    -Color keyed grill & bumper -Diode Dynamic SAE LED Foglights -Headlight Revolution LED Light upgrade -SCS SR8 18x9 with 295/70/18 Toyo Open Country AT3 -Go Rhino Dominator D6 Steps -TRD OEM Intake & Dual exhaust -Bilstein 6112 front and 5160 in rear -JL Audio C2 6.5" speakers upgrade powered by JL Audio RD 400/4 amp -Pair of AudioFrog GS25 speakers front dash -10” Kicker Hideaway subwoofer under driver seat -All doors covered with Soundskins deadening mat (inside/outside) -Front window tinted at 35% -Paint protection film full front -30” Rigid Industries SAE light bar -Body Mount Chop -Diode Dynamics SS2 (red) setup for brake light & turn signal -Katzskin Custom leather upgrade (Black/Bamboo) -Amber led running lights (Hood bulge) -AJT Design: Black vent rings, steering wheel trim, shift gate trim, emblem overlay -AJT Design: Quicksand door handle cover -Carbon fiber wrap (silver part on door panel) -Air Design tailgate applique (Line-X in smooth gloss finish) -Air Design tailgate spoiler (Line-X in smooth gloss finish) -Smittybilt beaver step (Line-X) -Valhalla Cat Shield (Line-X) -Coachbuilder Shackles kit +2 -Coachbuilder Strut/Coilover shim (0.5" for driver side) -Sumosprings (rear bumpstop) -Meso Custom Led front and rear cab lights -Teton shop shift knob -TRD Seat belt shoulder pad -Husky floor liner front/back -LED courtesy door/step light -LED bed light kit w/ outside switch
    Still trying to rack more miles.
    NWPirate, Tunrod, ATV25 and 5 others like this.
  8. Feb 15, 2025 at 7:48 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Gas pedal on the right.
    Henry1jg and French Avocado like this.
  9. Feb 15, 2025 at 9:54 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Holy crap. I was past that the first 8 months
  10. Feb 15, 2025 at 10:41 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Transmission fluid drain and fill. Power steering fluid flush. Look pretty dark at 50k. The power steering fluid on the other hand is not the typical atf color, but more like a gold yellow like the brake fluid. Is that weird? I was expecting it to look like the stuff that came out of the transmission pan. But it’s definitely two different color.
    this is the transmission fluid.
    power steering, old with a little mix of new atf. Pretty dark.
    All new. You can actually see the color.
  11. Feb 15, 2025 at 10:43 PM
    BrandonL812
    Brandon
    Used a total of 6.5qt of Toyota ATF WS between the transmission with cooler and power steering.
    Henry1jg and bulldog93 like this.
  12. Feb 16, 2025 at 12:15 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I believe Toyota puts this in the power steering loop (the older versions just say Automatic Transmisson Fluid) this is Toyota's version of Dexron III...
    ... and this is what comes in our transmissions (ATF-WS), which may explain the color differences of the fluids.
    Henry1jg, NWPirate, ATV25 and 5 others like this.
  13. Feb 16, 2025 at 4:58 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Yeah, what @Tripleconpanna said. Not sure what your 2021 owners manual calls for, but my 2019 manual reflects the above information. WS doesn't go in the power steering. Good news is that you know how easy it is to flush that system. :)
    ATV25, HulkSmurf14 and Tripleconpanna like this.
  14. Feb 16, 2025 at 5:01 AM
    BrandonL812
    Brandon
    Well, i hope it’s ok to use ws in there. I assumed that it was ATF it was ok to use in the ps from watching all the how to YouTube videos.
    should i be concern and flush it out right away?
  15. Feb 16, 2025 at 5:58 AM
    Tripleconpanna
    It's completely your call, and I'm sure there's plenty of folks who have done the same thing...
    However, with the cost of replacement parts and labor what they are these days in relation to a simple fluid swap (especially on a newer truck), I'd pull the WS out of the PS loop if it were me :notsure:
    Start point for PS fluid...
    https://youtu.be/TevK-u3vkx4?t=818
    Start point for Trans fluid...
    https://youtu.be/TevK-u3vkx4?t=264
  16. Feb 16, 2025 at 6:07 AM
    BrandonL812
    Brandon
    now ccn comment got me confused. He said to use any power steering fluid from the store and not aft due to each have their own detergent property for each purposed. Then the manual state to use ATF Dexron 3. The current cost i find for ATF Dexron 3 is bout $20/qt shipped. I live over an hour away from the nearest dealership, can’t just swing in and grab a bottle.
    Has anyone use other brand Power Steering fluid instead of Toyota atfdexron 3?
  17. Feb 16, 2025 at 6:21 AM
    Tripleconpanna
    There's been some debate on this... I believe the consensus and the spirit of his message was to use ATF WS in your transmission, but do NOT use ATF WS in your PS. ATF WS is NOT the same as ATF/Dexron iii....
    So, the bottom line is to use Power Steering Fluid or use ATF Dexron ii or Dexron iii equivelant...
    I've used Lucas Oil PS fluid in my 2008 in the past as an option.
  18. Feb 16, 2025 at 6:23 AM
    BrandonL812
    Brandon
    Very good. I will find some Dex3 and flush out the ws i put in there. Problem solved. Thanks for the input..
    Toyotoholic, ATV25, bflooks and 2 others like this.
  19. Feb 16, 2025 at 6:27 AM
    Tripleconpanna
    Sorry, I didn't mean to make that confusing at all...
    In fact, I went back and double checked your first post to verify if you put WS in everything or Dex III in everything; but yes, Dex 3 in the PS should serve you well :thumbsup:
    ATV25, bflooks, HulkSmurf14 and 2 others like this.
  20. Feb 16, 2025 at 6:29 AM
    BrandonL812
    Brandon
    Quite alright, you just clear it up for me actually. Im going to swing by Wally world and pick up some valvoline maxlife atf and flush it in for the time being. Next round I’ll source some oem atf and switch it out, for peace of mind..
  21. Feb 16, 2025 at 7:42 AM
    Skoden
    Skoden New Member
    Jared
    Manitoba Canada
    21 mgm pro cm
    Does that intake make any difference?
    Henry1jg and BR73[QUOTED] like this.
  22. Feb 16, 2025 at 8:07 AM
    rdiddy5
    rdiddy5 New Member
    Arizona
    2018 Crewmax 1794 4x4
    spent the afternoon tinkering and adding some more goodies.
    Kuat Ibex from Molle Panel
    Propane tank mount
    Adjusted Kuat Ibex crossbars (was slightly out of alignment (noticed cus front molle panel didnt fit)
    Auxbeam XP-Pro fog light install (already had the lights, got the brackets)
    Overland Vehicle Systems Car Shower
    full pics and deets in my build thread
  23. Feb 16, 2025 at 8:30 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    Probably no HP gains but it should breathe better utilizing a front air dam and the OEM fender location.Sounds and looks good though.....:D
    Skoden[QUOTED] likes this.
  24. Feb 16, 2025 at 8:58 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Just finished installing my AMP running boards. Love the look of not having regular running boards hanging from the truck :yay: Suspension is next on the list
    If anybody in SoCal is interested in the Toyota black running boards, I have them listed in the 2.5Gen Sale thread.
  25. Feb 16, 2025 at 9:11 AM
    Fergie
    Fergie New Member
    BBNP was my first big trip in the Tundra! Santa Elena is gorgeous. We did about 90 miles of back country camping over 4 days in the park and came out in Terlingua!
  26. Feb 16, 2025 at 9:26 AM
    jmdaniel
    jmdaniel Spending too much time here...
    Leander, TX
    2018 Tundra CrewMax SR5, 1977 FJ40
    DSI Conversion, including 6" ProComp lift, Fuel Assault Rims, ProComp tires, SunTek protective film, BAK Revolver X2 tonneau cover, Bedrug bedmat, OEM Audio+ Reference 500Q
    I get out there on my scoots from time to time. Great part of Texas.
  27. Feb 16, 2025 at 9:59 AM
    French Avocado
    Utah / Wyo
    Looks nice but I would not risk having the tank that close to my head.
  28. Feb 16, 2025 at 10:07 AM
    Yes. Watch the videos on their site.
    BR73, bulldog93 and Skoden[QUOTED] like this.
  29. Feb 16, 2025 at 2:25 PM
    VUDUBLU
    VUDUBLU New Member
    2019 TRD PRO Tundra
    Ready lift 2 inch lift with 295’s
    Installed my new front bumper today. I got the Octane series from Chassis Unlimited and had a local body shop paint the parts to match the truck. My whole build is going for the OEM+ look and I think this fits the bill!
  30. Feb 16, 2025 at 2:26 PM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Which replacement part# did you order?
    BR73[QUOTED] and rdiddy5 like this.
