  1. Feb 14, 2025 at 3:09 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    @BroHon
    Come get it. Your misses is tired of you bitchin. :D:D:boink:
    BroHon likes this.
  2. Feb 14, 2025 at 4:10 PM
    Fragman
    Fragman New Member
    2006 Tundra DC SR5 2WD V8
    Man, that's just a couple of miles away.
    No, I need to look away!
    shifty`, bmf4069, BroHon and 2 others like this.
  3. Feb 14, 2025 at 5:04 PM
    Dakillacore
    Georgia
    bmf4069, BroHon and 455h0le_dachshund like this.
  4. Feb 14, 2025 at 5:11 PM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    WTF am I looking at, the Portland Riot special? Randy Rattle can had some fun though. Oh, and that wood screw in the airbag, Classy.
    It's the wrong steering wheel... It'll be fine. HardPass/or $1000, and sawsall the top off and drive it around the property under the influence.
  5. Feb 14, 2025 at 5:26 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Two trucks at the same time (insert your meme plz)
  6. Feb 14, 2025 at 5:27 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I missed all that on my phone. Were you using a computer?
  7. Feb 14, 2025 at 5:28 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    do it.
    bmf4069 and BroHon[QUOTED] like this.
  8. Feb 14, 2025 at 5:29 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Yes posting from the command center in my basement atm.
  9. Feb 14, 2025 at 5:30 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Dakillacore and BroHon[QUOTED] like this.
  10. Feb 14, 2025 at 5:31 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  11. Feb 14, 2025 at 5:33 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    1. ^That's badass.
    2. Chopped top tundra farm truck: also badass.
    BroHon[QUOTED] likes this.
  12. Feb 14, 2025 at 5:33 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    shifty`, Fragman, bmf4069 and 3 others like this.
  13. Feb 14, 2025 at 5:35 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Notice that DC with the blown motor (bet timing belt), the front fender is mismatched paint from damage from a LBJ failure, bet. That leather looks pretty dam good though ahy?
  14. Feb 14, 2025 at 5:37 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Interior is nice. But peep that AC doe bruh.... (Last pic)
  15. Feb 14, 2025 at 5:38 PM
    The frame is shot on that one.
  16. Feb 14, 2025 at 5:41 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    On both Bill, such a shame.
  17. Feb 14, 2025 at 5:45 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    In the back of my mind I keep looking for a shop/pole barn at properties with 10-12ft ceilings... and learning how to do frame swaps. For about 4k and a TON of work you could have a nice rig.
  18. Feb 14, 2025 at 5:52 PM
    I gave up on looking for something similar. I figure my best bet is to find a property with enough room to build one that complies with local ordinance. Even that’s hard to find considering you need 10 ft minimum from the property line to build.
  19. Feb 14, 2025 at 5:53 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Paging @empty_lord
  20. Feb 14, 2025 at 6:02 PM
    So let's imagine you had a beige interior. You have a choice between black flooring, or beige flooring that may not match. Let's also assume that you don't really give a fuck and your matching beige flooring is kinda wrecked. What would you choose? Just for flooring.
    Beige that may not match
    Black as the night.
  21. Feb 14, 2025 at 6:03 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Black rubber.
    Jack McCarthy likes this.
  22. Feb 14, 2025 at 6:03 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    https://www.realtor.com/realestatea...Rd_Atlanta_MI_49709_M33276-04446?from=srp-map
    If the house wasn't so run down this would be higher on my list... but its still on it. HUGE ass pole building.
    bmf4069 and Sirfive like this.
  23. Feb 14, 2025 at 6:06 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    I think you would be happier with the beige even if it didn't match. You use your truck like a truck and I'm sure vacuuming is not something you do often... black will show every spec of dirt. my 2cents
    455h0le_dachshund likes this.
  24. Feb 14, 2025 at 6:44 PM
  25. Feb 14, 2025 at 6:45 PM
    Outbound
    Aaron
    Northern Alberta
    2 mils up, 3 mils right, hold for 5mph cross wind. Send it.
    Sirfive[QUOTED], BroHon and bmf4069 like this.
  26. Feb 14, 2025 at 6:46 PM
    Casey nailed it right off the bat. I'm gonna go vinyl flooring. But you are right bro, I think the last time I vacuumed my floor was may or June of 2023, when I did my sub install and deep cleaned my interior.
  27. Feb 14, 2025 at 6:47 PM
    Canastukians don't know about guns. Pfffff.
  28. Feb 14, 2025 at 6:49 PM
    Outbound
    Aaron
    Northern Alberta
    Maybe not pistols and AR's, but we know our way around bolt guns.
  29. Feb 14, 2025 at 7:21 PM
    Imposter syndrome. Look it up. Fuck imposter syndrome. If you can do the job professionally, you can teach the job. Always have in the back of your mind the top 3-5 fundamental things you need to know, and that one thing you wish someone would've told you early on. Share it. That's what the newbies need to hear. Don't teach them the step by step guide. Teach them the fundamentals, the "why". Any monkey can repeat shit. If they don't know why, they're just following steps.
    I've wanted to teach in the technology and security realm my whole life, but the reality is, teaching anyoner under 18yo in this country you get shit on, everyone hates teachers. It's better teaching adults. I've resorted to teach customers. Under the new business, I'm teaching one of my first customers who is technically a nurse, but has a clear knack for technology. It's been fun so far. What they've created is savage, thrown together, but with some basic fundamentals and thinking about things before throwing everything and the kitchen sink into it, dude is gonna be awesome.
    Buy it for me, I need it or something. :rofl:
    Wait no don't buy it for me. I saw the screw in the mismatched airbag cover and that just about did it for me.
  30. Feb 14, 2025 at 7:35 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Hahaha that was the AC not the BigTree. But either way in that AC I would be worried if it DID go off. I'll go full cave man like that sometimes, but it's on shit you can't see typically:rofl:
    bmf4069 and shifty`[QUOTED] like this.
