Phone charger not working?
Discussion in '3rd Gen Tundras (2022+)' started by Kozzmosis, Feb 14, 2025.
  1. Feb 14, 2025 at 3:18 AM
    Kozzmosis
    Kozzmosis [OP] New Member
    Michigan
    2024 tundra 1794 Mesquite
    Timbren
    I can't seem to get the onboard wireless phone charger to work with my Android in my 2024 tundra. Anyone have this problem?
  2. Feb 14, 2025 at 4:43 AM
    Rockpig
    Rockpig You did what?
    08 Limited
    The wireless charger is pretty much useless in my opinion. I have a Samsung S24 Ultra and it will charge for a second then won't, veru finicky. It'll constantly do this unless it's sitting perfectly without a case. It charges super slow and barely keeps up especially if you have you hotspot on.
  3. Feb 14, 2025 at 5:25 AM
    Kozzmosis
    Michigan
    Timbren
    That explains it, thanks
    Rockpig likes this.
  4. Feb 14, 2025 at 6:03 AM
    Talkin_Tundras
    Talkin_Tundras New Member
    ‘22 Tundra Limited
    Yeah, it's useless. I think there was someone here who managed to swap it out with an upgraded aftermarket version but it looked like a pain. I only use it now if I absolutely have to. I just take the case off.
  5. Feb 14, 2025 at 6:12 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
  6. Feb 14, 2025 at 6:25 AM
    Kozzmosis
    Michigan
    Timbren
    Lol, that sucks, mine doesn't even work with the case off. Thanks people!
  7. Feb 14, 2025 at 8:26 AM
    NORTHof54
    NORTHof54 New Member
    Mario
    Alberta
    ‘24 Limited Windchill TRD OR
    Sometimes I think it’s dependant on the phone. For my personal Samsung phone it never charges, but my iPhone 11 I have for work the wireless charger works pretty good
  8. Apr 4, 2025 at 8:25 PM
    ABurhans
    ABurhans New Member
    Andrew
    2025 Black Tundra Hybrid 1794
    I started digging when I found the same issue with my new 2025 1794 Hybrid and my iPhone 16 Pro Max. This dual wireless charger replacement is on my list to eventually purchase/install. There is some info in another thread here and a YouTube video on the install.
    Dual Wireless Phone Charger
    Raven67 likes this.
  9. Apr 4, 2025 at 8:44 PM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    I installed the NSV dual charger like listed in post above & it works great, even with my phone case. Easy install as well. 20250219_115900.jpg
    Blufin likes this.
  10. Apr 4, 2025 at 9:21 PM
    ABurhans
    ABurhans New Member
    Andrew
    Awesome! How well does it charge while using multiple apps in CarPlay (ex: Google Maps & Spotify)?
    Raven67[QUOTED] likes this.
  11. Apr 4, 2025 at 10:47 PM
    FleecingOilyRansomDealer
    FleecingOilyRansomDealer New Member
    2023 SR5
    Toyota released a technical service bulletin that stated that the QI chargers are only meant for Qi certified devices and said Mag safe devices are not Qi certified. It is attached below
  12. Apr 4, 2025 at 11:19 PM
    ABurhans
    ABurhans New Member
    Andrew
    Thanks for posting, but I have to laugh that Toyota issued that bulletin.
    The title contradicts the content. "Qi Wireless Charger - Incompatible with MagSafe Devices" is the title.
    The condition states "Wireless chargers on applicable vehicles are designed to work with Qi Certified devices only. MagSafe devices, that are not Qi Certified, may not charge as expected with Qi Wireless Chargers."
    Well, if you follow the rest of their guidance to lookup the iPhone certification, current iPhones (at least as far back as iPhone 11) are actually Qi certified and are listed in the Wireless Power Consortium Definitive List from that technical bulletin. Even if we remove the MagSafe cases, charging is still inadequate.
    Toyota would be better saying "We're aware that customers have expressed concerns about the performance of Qi Wireless Chargers and apologize for the inconvenience" and leave it at that.
  13. Apr 5, 2025 at 7:21 AM
    2023 SR5
    Interestingly Toyota tundra itself is not QI certified because I couldn’t find it on the database
    it does make sense that the charging does not work well because both the charger and the device have to be certified to work properly. They never certified the charger so the charger could be the problem
    ABurhans[QUOTED] likes this.
  14. Apr 5, 2025 at 7:50 AM
    Raven67
    Kentucky
    It charges while using Waze & Amazon music, even with my Otterbox case. WAY WAY better than the factory version.
  15. Apr 5, 2025 at 7:57 AM
    JayDee
    JayDee New Member
    I find that wireless charging, even when it's working its best, is problematic. I use my iPhone as a Wi-Fi hotspot at home and if the phone is left on the wireless charger it will pretty quickly stop charging because it gets too hot and the power usage will exceed the charging so the battery will discharge over time. In the summer time I've even had it stop charging without the hotspot being enabled.
    In a truck in the summer during the day when you're using CarPlay (both bluetooth and WiFi turned on) the same thing will happen. The phone will get too hot and stop charging.
    On long trips I just plug in the phone to the USB port in the center console with a cable. Not as pretty as the wireless option but the phone does not overheat.
    Maybe wireless charging vendors should start putting heatsinks and fans on those chargers!
    Malinois38 and ABurhans like this.
  16. Apr 5, 2025 at 12:18 PM
    ABurhans
    ABurhans New Member
    Andrew
    That really is much better than factory!
  17. Apr 7, 2025 at 10:20 AM
    Bigbadpoppa
    Bigbadpoppa New Member
    it's so bloody slow to a point if you are streaming music from it, it barely keeps up.
    I've decided to just go USB for charging, and have a cable dangle out my center console.
    kirkb and ABurhans like this.
  18. Apr 7, 2025 at 10:56 AM
    ABurhans
    ABurhans New Member
    Andrew
    That's exactly what I've been doing too, and I think that will continue to be my plan until I'm able to purchase & install the NSV dual charger that @Raven67 is using.
    kirkb and Raven67 like this.
  19. Apr 12, 2025 at 6:59 PM
    Spacecowboy863
    Spacecowboy863 New Member
    nope, I don't use the charger either. usually just plug in with the usb-c wire
  20. Apr 13, 2025 at 7:04 AM
    Jds685
    Jds685 2nd Tundra
    CT
    2024 Tundra i-Force Max 1794
    I have a Pixel 8 Pro with a Spigen Ruggen Armor case. The wireless charger works very well for me in my 2024. It definitely disconnects at times, but I put it on the charger last night at 30%, took a road trip, and arrived nearly full after a few hours while using Android Auto, Waze, streaming music. It is finicky at times, no doubt, but totally useful. I was just thinking last night that it is a game changer for me. Very satisfied.
    Tundrastruck91 and ScottieBones like this.
