General Supercharger Thread
  1. Feb 13, 2025 at 2:11 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Hpt support will have you try a beta editor version when your having issues.
  2. Feb 13, 2025 at 2:12 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I verified the no can bus before he tried. I'll have him shutdown firewalls. He's an apple guy using windows for first time...
    armyoffoo[QUOTED] likes this.
  3. Feb 13, 2025 at 2:43 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Found an ECB-1 on eBay, offered 150, they accepted.
    HulkSmurf14, Mdl and koditten like this.
  4. Feb 13, 2025 at 3:02 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Better than having to re-do your setup.
    Good luck!
  5. Feb 13, 2025 at 3:55 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Not sure but the ecu can be finicky or takes a few drive cycles to get settled.
  6. Feb 13, 2025 at 4:08 PM
    ARES35
    ARES35 New member for life
    Mile high
  7. Feb 13, 2025 at 4:21 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Was pulling out another Fedex truck in my neighborhood today and forgot to go into 4lo and did it in 4hi. Got the wonderful High Transmission Temp warning.
    So now get to change my transmission fluid like the rest of you guys getting new valve bodies haha. Sounds like doing the drain and fill (3ish quarts) then draining the return line for the cooler (3x 3 quarts) is the way to go?
    Mdl likes this.
  8. Feb 13, 2025 at 4:27 PM
    bflooks
    bflooks New Member
    Metrowest MA
    That gets it done in one shot, but others also do multiple drain/fills over a few weeks. I personally like seeing when the old is gone and only bright red is flowing through. Just don't run your pan dry while doing it. 4qts comes out surprisingly quick once it starts.
    HulkSmurf14, Mdl and Ponderosa_Pine like this.
  9. Feb 13, 2025 at 5:08 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    I received the HPS silicone 90* coupler and promptly cut it up to fit. Finally have the 103mm throttle body physically installed. I still need to program the D2A, and do a HP Tuners throttle relearn, and then get Sniv some logs.
  10. Feb 13, 2025 at 5:30 PM
    e30cabrio
    That looks seriously badass!
  11. Feb 13, 2025 at 5:39 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    reywcms and HulkSmurf14 like this.
  12. Feb 13, 2025 at 5:56 PM
    LILTRD
    LILTRD New Member
    East Bay, California
    2013 Tundra RCSB
    Hidden Winch Lighting Suspension/Air bags Wheels/Tires Audio Center Console swap
  13. Feb 13, 2025 at 6:27 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Welcome to the 103mm club! Haha looks awesome
  14. Feb 13, 2025 at 7:02 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    That's good to know. I wasctrying to remember from the past post if they had them in stock or waiting from Australia. I know the pans will be shipping shortly.
    Thanks
  15. Feb 13, 2025 at 7:21 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    For the 103mm TB are you still at 30% airload increase from stock? I thought of trying it again but the little 1900 only has a max snout opening of 94.5mm. Reason I went with the 95mm. But I do have to say the 103mm ripped when I had it. Not sure if it was just the newness from the 84mm RcF.
  16. Feb 13, 2025 at 8:27 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    HulkSmurf14 likes this.
  17. Feb 13, 2025 at 9:09 PM
    ARES35
    Mile high
    They are local to me so no shipping. Just waiting for word on pick-up.
  18. Feb 13, 2025 at 9:24 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    They responded to my email the next day when I asked about the lead time for the pan. They are also a phone call away...
    ARES35[QUOTED] and reywcms like this.
  19. Feb 13, 2025 at 10:09 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I believe so it’s been awhile but @snivilous would know
    Mdl[QUOTED] likes this.
  20. Feb 14, 2025 at 8:17 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Yea, I forget how high, I thought it was over 30%. 44% sticks out to me.
    HulkSmurf14, Mdl and reywcms[QUOTED] like this.
  21. Feb 14, 2025 at 8:23 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Probably right- maybe we started at 30%
  22. Feb 14, 2025 at 8:30 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Per Colton's update email, Whipple shipping ETA is 3/28.
    I guess i better start getting a gameplan for the install. I've done exactly nothing to prepare.
    I still haven't decided if i want to tackle pulling the exhaust manifold myself to install the wideband or if i want to find a shop to do it.
  23. Feb 14, 2025 at 8:56 AM
    snivilous
    SW UT
    If you have a stock downpipe it's easy, just some long extensions and it's three bolts, then two by the cats and pops right off.
  24. Feb 14, 2025 at 9:09 AM
    Danimal86
    Daniel
    Sacramento, CA
    I've got stock manifold and downpipes then the TRD exhaust.
    Is this pretty much it (Starting at 3:03)
    Edit: Passenger side better to do? (Starting at 1:47)
  25. Feb 14, 2025 at 9:24 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Thanks. I saw an email that 30% was a start but didn't know . Just wanted it for reference if I ever go big again.
  26. Feb 14, 2025 at 9:30 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    You don't need to remove the manifolds, just the downpipe connected to them, disconnect the 3 flange nuts holding the downpipe to the manifold, and 2 bolts connecting the downpipe to the catback exhaust, then drop the pipe.
  27. Feb 14, 2025 at 10:20 AM
    nags
    nags New Member
    Big news for my dude that's going on like 8 months waiting on his Whipple.
  28. Feb 14, 2025 at 10:30 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Well time for to send mine back lol
    ARES35, Mdl, e30cabrio and 1 other person like this.
  29. Feb 14, 2025 at 10:50 AM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    How did I know you would be the 1st to respond to this news, LOL
  30. Feb 14, 2025 at 10:50 AM
    Abell207
    Abell207 New Member
    Anthony
    Maine
    2020 Army Green TRD PRO
    Awe man. If they bring the gen 6 whipple to the tundra platform I’m gonna have to sell my harrop.
