Suspension question for camper shell
Discussion in '2nd Gen Tundras (2007-2013)' started by FarmerFrederico, Feb 3, 2025.
  1. Feb 3, 2025 at 5:09 PM
    FarmerFrederico
    FarmerFrederico [OP] New Member
    I’m thinking about getting a regular cab short bed and putting about a 400# pop-up camper shell on the bed, and imagine I’d easily have another 250# of gear in the back at any one time.
    What do I need to know about setting up custom suspension for loads like this in the back?
  2. Feb 7, 2025 at 9:13 PM
    surffj62
    surffj62 New Member
    2011 DBL RW
    I have a super pacific camper, 200 drawers and full rear swing outs.
    Truck got weighed at 7700lbs…
    I had OME springs with an add a leaf that got flat pretty quick.
    I replaced it with heavy duty springs from Ironman 4x4 and new shackles etc. I’m pretty happy. I could see down the road maybe adding a leaf but for now it’s riding well.
    I have Bilstein 6112s / 5160 shocks
  3. Feb 7, 2025 at 9:16 PM
    surffj62
    surffj62 New Member
    2011 DBL RW
    Camper
    FarmerFrederico[OP] likes this.
  4. Feb 8, 2025 at 7:23 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Look into custom rear leafs if you have the coin. Alcan comes to mind but there are other good options.
    If your leafs are in good shape now, no sag, RAS may be enough to help with that weight, certainly would be cheaper than new leafs.
    If you search, there are Many thread on this topic, so lots of info here on Tundras about dealing with sag from bed load.
  5. Feb 13, 2025 at 4:03 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    So 750 lbs? It will sag a bit, occasional use? Or is it going to live on the truck?
  6. Feb 13, 2025 at 4:08 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Second the Ironman HD springs.
