The S.S. TRDFerguson: Captain’s Log
Discussion in '2.5 Gen Builds (2014-2021)' started by TRDFerguson, Mar 25, 2021.
  1. Feb 13, 2025 at 9:13 AM
    #1921
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    You won't even JSON-spec. Your feedback cannot be trusted.
  2. Feb 13, 2025 at 9:23 AM
    #1922
    TRDFerguson
    TRDFerguson [OP] SSEM #99/RGBA #8-ish?/It’s a funny name.
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    The json-iest of json-spec options :rofl:
    BiggHertz[QUOTED] and RobertD like this.
  3. Feb 13, 2025 at 9:24 AM
    #1923
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    :fistbump:
    BiggHertz, Mater and RobertD like this.
  4. Feb 13, 2025 at 9:39 AM
    #1924
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    TRDFerguson[OP] likes this.
  5. Feb 13, 2025 at 10:14 AM
    #1925
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Did you do a backing plate or anything like that under the bed to reinforce where the l-track attaches or is it just bolted to the bed floor?
  6. Feb 13, 2025 at 10:44 AM
    #1926
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Nah, just sheetmetal screws into the bed... jk, jk. They're just through-bolted with stainless machine screws, but there are holes every 6" or so and should be good to hold things down in just about any situation. There isn't a lot of room to work between the bed and frame in a few spots.
    Mater, helidave[QUOTED] and RobertD like this.
  7. Feb 13, 2025 at 3:31 PM
    #1927
    Azblue
    The Dirty T ( ^_^)_且
    I would've just used some drywall screws. I've got a shitload of those in a old coffee can in the garage.
  8. Feb 13, 2025 at 3:32 PM
    #1928
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    you would
  9. Feb 13, 2025 at 6:20 PM
    #1929
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    That’s just lazy. At least use some of those plastic anchors that are rated for 5 lbs hanging strength.
  10. Mar 5, 2025 at 7:19 PM
    #1930
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    New box of goodies showed up today. Now I just need a local vendor to call me back on REM polish for the gears and I can get this shit moving!
    Cthulhu, 1794TX, Azblue and 4 others like this.
  11. Mar 5, 2025 at 7:51 PM
    #1931
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    you’re catching up to jimmy with your shelfware collection
  12. Mar 5, 2025 at 7:53 PM
    #1932
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Only because it all has to be installed at once… and not by me.
    Azblue, reywcms and BiggHertz[QUOTED] like this.
  13. Mar 5, 2025 at 8:00 PM
    #1933
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Just here for the reaming
  14. Mar 5, 2025 at 8:04 PM
    #1934
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  15. Apr 6, 2025 at 8:52 PM
    #1935
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Took a couple minutes to add an XLR jack to the blank parking sensor hole on the Ironman bumper, making hooking up the winch controller much easier. Still trying to source a dust cap that will actually fit, so let me know if you have any ideas there. The two I’ve tried on Amazon were a bust.
    Parts list:
    https://www.amazon.com/dp/B07V6TX284
    https://www.amazon.com/dp/B0CDNWQCCC
    I cut the cable in half and soldered the cut end to the jack, unscrewing the unused end to copy the wire positions.
    Cthulhu, RainMan_PNW, reywcms and 4 others like this.
  16. May 11, 2025 at 11:46 AM
    #1936
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    do you know what brand bumper that is? Looks great!
  17. May 11, 2025 at 11:54 AM
    #1937
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    ironman front
    Custom rear
    TRDFerguson[OP] and reywcms like this.
  18. May 11, 2025 at 12:23 PM
    #1938
    Js18tundra
    Thanks, the rear looks sweet!
  19. May 11, 2025 at 12:48 PM
    #1939
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Thanks! Like @BiggHertz said, it’s a custom rear made by LCS Fabrication in the DFW area. It’s treated me very well.
  20. May 11, 2025 at 4:46 PM
    #1940
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Yo man! Have you had a chance to use these? Are they reliable?
  21. May 11, 2025 at 5:17 PM
    #1941
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I used mine when we were up at T2S - worked great. The numbers on them aren’t exactly accurate (could also be related to the fact we were close to 6000ft elevation) but they all hit the same final number according to my TPMS readings. If a guy spent a little time testing them, I’m sure you could come up with a “dope sheet” to use.
    If I recall, I had mine set at 20psi and they actually were ~18 when I checked the dash gage. But stupid easy to use.
    BillyB, RobertD, Azblue and 2 others like this.
  22. May 11, 2025 at 5:25 PM
    #1942
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I’ve used them several times and they seem to work great. Like Casey mentioned, the actual target number is a bit of trial and error to get exactly where you want it, but all 4 do hit the same number when dialed to the same marking. Worth the money IMO and better than the Staun/Coyote ones.
  23. May 11, 2025 at 5:38 PM
    #1943
    BlueRibbon4x4
    Geno
    Thanks fellas! I’ve had the Staun ones for quite a few years now and they’ve become unreliable. I’ll reset them and one or two will keep deflating past the set point. They were $100 so I keep messing with them, hoping they’ll just work one day. I’ve resorted to just letting them deflate a certain “feel” of time and removing them in the same rotation as installed, so the tires are evenly deflated.
    Mater and TRDFerguson[OP] like this.
  24. May 11, 2025 at 5:46 PM
    #1944
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    That was my fear with my knock offs I was using. They never really stopped, just kept pissing air and I’d have to guess when they were “done”. Usually ended up with a 2-3 psi variance across the tires
    BlueRibbon4x4[QUOTED] likes this.
  25. May 14, 2025 at 11:45 AM
    #1945
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    What air-leaky thingys are those? I bought some Rhino one's that I'm too stupid to figure out how to make work.
    And did you get your gears installed? I forgot to ask you in Sedona.
  26. May 14, 2025 at 11:49 AM
    #1946
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    They're these lil guys. @crackdealer suggested them and can source them for you
    https://overlandvehiclesystems.com/tire-deflator
    And no, I haven't been able to find time to get the gears done - I need to plan a little better and figure out when I can make a couple trips to Prescott and drop things off with Zuk.
  27. May 14, 2025 at 11:59 AM
    #1947
    BillyB
    BillyB New Member
    Billy
    AZ
    Thank you! I think I'll order me a set.
    I'm tired of looking for sticks.
  28. May 14, 2025 at 12:32 PM
    #1948
    memario1214
    Colton
    Missoula, MT
    One more thing on my list of products to get uploaded... :bananadead:
    RainMan_PNW, BillyB, RobertD and 2 others like this.
  29. May 14, 2025 at 1:52 PM
    #1949
    BillyB
    BillyB New Member
    Billy
    AZ
    In that case, I'll get them from you then
    memario1214[QUOTED] likes this.
  30. May 14, 2025 at 2:06 PM
    #1950
    memario1214
    Colton
    Missoula, MT
