Would turbo problem give me parking assist malfunction error
Discussion in '3rd Gen Tundras (2022+)' started by Tundrazzz9, Feb 1, 2025.
  1. Feb 1, 2025 at 9:34 AM
    Tundrazzz9
    Tundrazzz9 [OP] New Member
    Tundra limited
    I just bought my used 2022 Toyota tundra I was made aware that one of the turbos need to be changed would this also give me a parking assist malfunction error and I can’t use adaptive cruise control
  2. Feb 1, 2025 at 9:51 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    dirty sensor, of if you are lifted, may need recalibration. Generally is sensor/recalibration. Check sensor wiring.. However, have you checked for stored error codes, there could be more going on. Need a scan tool or hit your local autozone or similar and they can scan it for you.
    more-
    https://www.tundras.com/threads/park-assist-malfuntion.129764/
    https://www.tundras.com/threads/parking-sensor-issues….120258/
    https://www.tundras.com/threads/bad-turbo-bank-1-check-engine-low-power.150510/#post-3753883
  3. Feb 1, 2025 at 10:27 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Have you tried turning parking assist off?
    I had a similar but different problem. My front camera was defective causing my truck to throw a "Front Camera Unavailable" message about every 10 minutes while driving. When the error message displayed it would disable adaptive cruise and front collision detection. A new front camera has fixed the problem, so far.
    Good luck
  4. Feb 1, 2025 at 11:45 AM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Almost anything that throws a code kills Parking Assist, Active Collision Assist, Both Cruise Controls, and Lane Trace Assist. I’ve had a loose gas cap a few times and lost all of these until I could reset with a scan tool. (Right at the beginning of a 1200 mi. trip) Stupid and maddening. (carry my scan tool fill time now)
    Hella Krusty likes this.
  5. Feb 1, 2025 at 12:58 PM
    Matt2015Tundra
    2023 1794 CrewMax
    When my front camera failed, I still had regular cruise, but not adaptive cruise. Everything else you mentioned was disabled.
    It's crazy how all these systems are linked. I got my first taste of it on my 2015 Tundra when it ate a rear wheel bearing. That caused a wheel speed sensor failure, which caused a ABS failure. That also disabled all 4WD functionality, which was a major PITA because I was on a hunt at the time, and was reliant on 4WD.
    It seems as time passes the more I enjoy the simplicity of my old 1981 Jeep CJ7.
  6. Feb 1, 2025 at 1:38 PM
    DRP
    DRP Old Member
    Dave
    Stop the presses! You had a pre - Gen 3 that had a problem? Not sure I can believe it............;)
    Raven67 and Breathing Borla like this.
  7. Feb 1, 2025 at 2:05 PM
    Matt2015Tundra
    2023 1794 CrewMax
    Yup, the wheel bearing and ABS problem at around 80K miles, and a leaking water pump at around 100K. That's all I remember. I traded it for my Gen 3 with 140k on it. Overall it was a very reliable truck, and it held its value well.
    it's been a different story with my Gen 3, so far. Is what it is...
    DRP[QUOTED] likes this.
  8. Feb 1, 2025 at 10:02 PM
    PNW Tundra Mike
    Southern Cal
    Cool! I had an ‘80 CJ7. With a built 304ci.V8. My first 4x4. Loved it and miss it. .. but not the 10mpg!!
  9. Feb 2, 2025 at 6:11 AM
    Matt2015Tundra
    2023 1794 CrewMax
    Very nice. I had a '79 CJ5 with the 304. I sold that one to buy my Father's '81 CJ7 because it was in better shape, and I liked the extra room in the CJ7. I quickly learned that the 258 I6 in Dad's Jeep was a dog compared to the 304.
    It took me 30 years to get around to restoring Dad's '81. But I finally got a V8 in her (AMC 360).
    Now, she's mostly a garage queen. I take her out on nice days for nostalgic sake. I should find some kid who would really enjoy it, but I just can't let it go, yet.
  10. Feb 13, 2025 at 6:03 AM
    JH8473
    JH8473 New Member
    2025 Tundra SR5
    None
