TRD pro grille swap on a Platinum
Discussion in 'Sequoia 3rd Gen (2023+)' started by gnafrada, Nov 15, 2024.
  1. Nov 15, 2024 at 10:30 AM
    gnafrada
    gnafrada [OP] New Member
    Did a grille swap to a TRD pro on a Platinum trim. Light bar is not dependent on high beams which I wanted. Toughest part was removing the clips on the grille. Other than that pretty straight forward.
    Video of install https://youtu.be/G5EGf1W67E8
    Screenshot_20240923_172934_Gallery.jpg Screenshot_20240923_172959_Gallery.jpg
    asuragod likes this.
  2. Feb 11, 2025 at 8:34 PM
    TechSeq
    TechSeq New Member
    San Diego, CA
    2024 Sequoia SR5 TRD Sport
    Suspension: King 2.5 Performance Series Kit w/Remote Reservoirs Wheels: Method 312 Tires: Falken WildPeak AT4 TRD Pro Fender Flares TRD Skid Plate TRD Pro Heritage Grille AFE Tow Hooks Talons Garage Catalytic Converter Shield
    If this is your content, thanks for putting together the install video! It definitely helped me out a lot when I did the upgrade to the heritage grill along with the marker lights. Keep it up! :muscleflexing:
    gnafrada[QUOTED][OP] likes this.
  3. Feb 12, 2025 at 6:25 AM
    JooolesM
    JooolesM New Member
    Julie
    03063
    2024 Toyota Sequoia
    Removed third row seating, installed base deck.
    I did this mod (but had a local shop do the actual install) ... I really love the result.
    gnafrada[OP] and TechSeq like this.
  4. Feb 12, 2025 at 11:32 AM
    gnafrada
    Yeah. I like the Heritage grill better with the added light bar independently switched.
  5. Feb 12, 2025 at 12:51 PM
    JooolesM
    JooolesM New Member
    Julie
    03063
    2024 Toyota Sequoia
    The mod shown in the video IS independently switched (thought I'm not 100% happy where it wound up being placed).
  6. Feb 12, 2025 at 5:19 PM
    manofsteele2003
    manofsteele2003 New Member
    Grant
    24 Sequoia TRD Pro
    Westcott designs 3"/1" lift 295/70/18 Falken Wildpeak RTs Canvasback cargo liner aFe Tow hooks
    Some states, like mine (Virginia), the light bar won't pass inspection unless it's wired to the high beams
  7. Apr 23, 2025 at 7:07 PM
    JTK
    JTK New Member
    Mark
    2024 Platinum
    Looks great. Was there any issue with what Toyota calls the active front spoiler or the air dam that deploys at 30mph? I was told that the air dam was the reason that the dynamic diode ss18 light bar won’t fit on a 3rd gen platinum tundra.
    Thanks
