Spoiler Delete Module
Discussion in '3rd Gen Tundras (2022+)' started by Philipl, Mar 29, 2024.
  1. Mar 29, 2024 at 6:46 AM
    Philipl
    Philipl [OP] New Member
    Philip
    North Mississippi
  2. Mar 29, 2024 at 7:13 AM
    DRP
    DRP Old Member
    Dave
    2023 here. I had mine unplugged for over a week and no DTCs appeared. I know others on here have had the same experience. I would definitely try to protect the connector/wires from water intrusion if I were to leave it disconnected long term.
    ryanwgregg[QUOTED] likes this.
  3. Mar 29, 2024 at 7:15 AM
    Philipl
    Philip
    North Mississippi
    Thanks I did not realize you need a $500 module to make this work
    ryanwgregg likes this.
  4. Mar 29, 2024 at 8:59 AM
    6rian
    6rian New Member
    My '24 doesn't seem to mind that I took the spoiler off.
    mve and ryanwgregg like this.
  5. Mar 29, 2024 at 10:54 AM
    Luckydwg
    Luckydwg New Member
    San Diego CA
    2024 MGM Limmited Crewmax Nightshade
    I have a 24 and disconnected it and got the error message.
  6. Mar 29, 2024 at 1:32 PM
    CORam
    CORam New Member
    Mine's a '24 SR5 and I get the error message when I disconnect the front spoiler connector. I currently have the spoiler motor sitting inside the winch cavity of the front bumper solely to keep the motor connected to avoid the error messages.
    LW442 and ryanwgregg like this.
  7. Mar 29, 2024 at 2:30 PM
    6rian
    6rian New Member
    This is probably the best option as of now if you don’t want the error. Some bumpers include a relocation solution.
    LW442 likes this.
  8. Mar 29, 2024 at 3:19 PM
    Luckydwg
    Luckydwg New Member
    San Diego CA
    Can you remove the actual spoiler while keeping the motor connected and not get an error message, or how does the TRD lift kit deal with this? Do you have the instructions for the TRD lift kit?
  9. Mar 29, 2024 at 4:28 PM
    CORam
    CORam New Member
    That's what I am currently doing. The motor is connected and I don't get the error messages. But the spoiler has been removed. I assume that the motor sits in there and actuates when it normally would, but it is not connected to the spoiler, so it is not accomplishing anything when it actuates.
    Although I will say that after I installed my front bumper and secured the spoiler in the winch cavity I tried to actuate the motor by doing the winshield wiper arm thing (or whatever it was - I can't remember now), and I couldn't get the motor to do anything. Whereas prior to removing the spoiler I was able to get the spoiler to actuate using the service over-ride. Not sure what that is about. Maybe it senses that the spoiler is not there and won't actuate?
    Luckydwg[QUOTED] likes this.
  10. Mar 29, 2024 at 4:33 PM
    Luckydwg
    Luckydwg New Member
    San Diego CA
    Perfect thank you.
    CORam[QUOTED] likes this.
  11. Apr 18, 2024 at 1:16 PM
    jhersey29
    jhersey29 New Member
    Mine is a 2024 SR5 Off-road and got the error message on the display. Boy it is very annoying and has to be constantly cleared. CBI told me they had issues with the module and are redesigning it. Not sure what the issue was/is. They likely won’t have any for months. Anyone find a solution other than putting the motor back in without the air spoiler? My dealer said they cannot reprogram it because there is no way for them to do it. Do they just not know how?
  12. Apr 19, 2024 at 9:05 AM
    NoHater
    NoHater New Member
    After my trd lift installed I noticed that motor is still there plugged in and would really like to get it out of there. Especially when I upgrade the bumber at some point. I'm hoping there is a cheap easy option to pull that junk out. I'm just assuming it will push a code when unplugged.
  13. Apr 30, 2024 at 12:13 PM
    6rian
    6rian New Member
    Weird that some experience the error while others don’t. I’ve completely removed my spoiler and motor and haven’t received any error after a couple of months. I ordered the CBI delete module but thinking I should cancel the order since it appears I don’t need it.
  14. Apr 30, 2024 at 2:12 PM
    wxman91
    wxman91 New Engine Enthusiast
    Montana
    2022 TRD Sport 4x4 Army Green / 2021 4Runner Limited
    CBI Baja Bumper / BD S2s Falken Wildpeak AT3W 315/70R17 Method 316s TRD Pro Fox Suspension w/Total Chaos UCAs TRD Dual Tip Exhaust TRD CV Axles TRD Pro Flares + Heritage Grille Alpharex Headlights Dobinson Coils RCI Skid
    I have the CBI module but plugged it in while doing the bumper install so idk if I actually needed it. No errors though.
  15. Jun 18, 2024 at 3:11 AM
    benca1
    benca1 New Member
    2023 TRD Offroad SR5 Crewmax 4x4
    295/60/20 Wildpeaks 20” limited wheels TRD running boards TRD exhaust OEM bed mat OEM bedcover OEM all weather Mats 4Knines rear seat cover
    So if you remove the spoiler is there any arms or anything that move up and down or anything to be seen from the front of the truck by just leaving the motor only plugged in? This won’t throw any codes right?
  16. Jun 18, 2024 at 5:12 AM
    reded301
    reded301 New Member
    2022 SR5 CM 5.5
    Westcott level TRD Wheels 35” Kenda Klever
    Pull the fuse and forget about it.
  17. Jun 18, 2024 at 8:01 AM
    benca1
    benca1 New Member
    Which fuse is it exactly? Doesn't through another code?
  18. Feb 10, 2025 at 7:35 PM
    bailey bulldog
    bailey bulldog New Member
    Did you try or have any luck?
  19. Feb 12, 2025 at 1:52 PM
    Observer
    Observer New Member
    Curious. As to the active spoiler. What trim level do you have for those who have disconnected the spoiler and had no error message? Such as blind spot monitor, back up sensors etc.
