General Supercharger Thread
  1. Feb 12, 2025 at 6:53 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
  2. Feb 12, 2025 at 7:08 AM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    This whole thread is so dangerous... It's like I swore I would only try weed once and now I'm researching how to do heroin.
  3. Feb 12, 2025 at 7:26 AM
    jhrrld
    jhrrld ID-Ten-T
    Josh
    OK
    2021 White Platinum CrewMax 4WD
    So I think i'll order the HD valve body from cruiser parts and pass on the deep pan and plan on keeping the trans cooler pinned open 95% of the time. I'll switch to Dex III and change once a year. I'll plan on slipping under there and unpinning before i travel to colorado for ski trips.
    That sound logical? I have a magnuson 2650 with stock pulley with a YotaWerx tune. Do not want to cook my trans so I'll do my best to stay on the stock pulley for now.
    HulkSmurf14 likes this.
  4. Feb 12, 2025 at 7:39 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Are you out of powertrain warranty? I'm not trying to talk you out of using dex3 as WS type fluid has been used for years. Lots of unconventional things get posted and there are always risks.
  5. Feb 12, 2025 at 7:49 AM
    jhrrld
    jhrrld ID-Ten-T
    Josh
    OK
    I am out of factory warranty and understand there are risks, i do not like thin oils and accept i might screw it up. Sounds logical to me and i'm going to run with it!
  6. Feb 12, 2025 at 8:14 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Ok. Looks like there will be a few of us testing in "CONUS" how the dex3 does. I'm just waiting on my pan which should arrive next week. That was my thinking on the dex being a higher viscosity than WS type fluid.
  7. Feb 12, 2025 at 8:41 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  8. Feb 12, 2025 at 8:42 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Im now thinking of running brake cooling ducts from the front bumper area to the pan.. Have to look it over once I bring the truck over to the new place this weekend.
  9. Feb 12, 2025 at 8:47 AM
    bflooks
    bflooks New Member
    Metrowest MA
    HulkSmurf14 and e30cabrio like this.
  10. Feb 12, 2025 at 8:57 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  11. Feb 12, 2025 at 9:40 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Just get a bigger trans cooler :rofl: trying to cool a massive brick in the bottom would have marginal results I suspect.
  12. Feb 12, 2025 at 9:45 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Just being a smart ass with all the "improvements" we do to our trucks. :D
  13. Feb 12, 2025 at 9:45 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    WAT sells a double cooler kit for the LC200s, maybe dual coolers would be a better option. They are just sandwiched together also, so should be easy enough.
  14. Feb 12, 2025 at 9:49 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Or even triple...:rolleyes: if it gets that hot I'm in trouble. But can see it if I'm in the outback or Middle East.
  15. Feb 12, 2025 at 9:51 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
  16. Feb 12, 2025 at 10:23 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    LOL Coolers in the bed is the plan yes.
  17. Feb 12, 2025 at 10:43 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    OK...OK...lots of coolers!
    e30cabrio and reywcms[QUOTED] like this.
  18. Feb 12, 2025 at 10:54 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    This just happened.
    I can't get either AFR gauge to calibrate, both jump from 4.5-22/13. I have pulled them each 4x, swapped sensors, tried a third sensor in both. Any ideas?
  19. Feb 12, 2025 at 11:00 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    But, isn't that the worst place for airflow? I guess if the fans are on all the time it'd be good? Looks awesome though!
    e30cabrio and Mdl like this.
  20. Feb 12, 2025 at 12:03 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Very common setup on these types of rigs no issues and on race vehicles they have no windshield so that helps. Low pressure area vacuum effect is my guess
    prerunner-building-104-what-is-an-ultimate-prerunner-2021-10-11_17-59-56_570469-scaled.jpg
  21. Feb 12, 2025 at 12:59 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    its a rabbit hole for sure!
  22. Feb 12, 2025 at 1:07 PM
    NatesNightMare
    Pinetop Az
    whats a good lil larger trans cooler upgrade?
    even pinned i still run normal temps no less.
    thinking a larger cooler esp after gears would be beneficial esp when traveling with/out the trailer
  23. Feb 12, 2025 at 1:28 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    https://genuinecoolingsystems.com/
    Lots of threads on this
  24. Feb 12, 2025 at 1:43 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Man! Not sure what's up. I thought of switching from AEM but my boost/afr gauge has been working well for the past 10 years. Only changed sensor out once. Hope you get it sorted.
  25. Feb 12, 2025 at 1:48 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    And you can make your own for a lot less than genuine cooling.
    If your plumbed into the condenser you can run the outlet from condenser to inlet on stand alone cooler then out to transmission for cheap or bypass condenser to stand alone cooler. Some use the Hayden 679 or ant 15-19 row cooler or bigger if it will fit.
    HulkSmurf14 and reywcms like this.
  26. Feb 12, 2025 at 1:48 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I was just going to say this. No issues with my AEM units at all
    e30cabrio and Mdl[QUOTED] like this.
  27. Feb 12, 2025 at 2:20 PM
    NatesNightMare
    Pinetop Az
    thats what i was thinking, getting a bigger condenser as i have an 18 with stock trans cooler
  28. Feb 12, 2025 at 2:21 PM
    NatesNightMare
    Pinetop Az
    go figure my rear bearing install kit is now delayed until april :annoyed:
    trying to find a replacement near same price is like pulling teeth
  29. Feb 12, 2025 at 2:22 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Or just bypass the condenser and straight to external cooler. Could be causing excessive temps.
  30. Feb 12, 2025 at 2:24 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The lower priced kits are hard to find. Ordering from Japan should be here in about 3-4 weeks. But not complete kits.
