Are you strapping your dog into the middle seat?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Shadowfax1, Feb 12, 2025.
  1. Feb 12, 2025 at 7:57 AM
    Shadowfax1
    Shadowfax1 [OP] New Member
    San Francisco Bay Area
    2018 Toyota Tundra 1794 Edition w/ TRD Off-Road Package
    For those of you with dogs, I would be interested in hearing from anyone who is strapping their dog into the MIDDLE seat in the back. I have tried a half dozen or more commercial dog restraints, and they all worked fine on the left or right seatbelt; not a single one works in the middle. I am surprised, but it seems the buckle in the middle of our tundras is different.
    what specific restraint device are you using with your dog? A link would be greatly appreciated as possible.
    FREEK likes this.
  2. Feb 12, 2025 at 9:24 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I usedcto have 2 GSD's in harnesses. So using left and right. Center didn't work. Have you looked at using one of the anchors behind the seat, coming from above center to prevent getting tangled up?
  3. Feb 12, 2025 at 9:31 AM
    Shadowfax1
    Problem is every solution I can find uses the seatbelt harnesses found on the left or right, or the child seat anchors in between the back and seat cushions. But nothing has worked in the middle or with the anchor on top.
  4. Feb 12, 2025 at 9:35 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
  5. Feb 12, 2025 at 9:39 AM
    Shadowfax1
    I’ve gotta roll with two kids and a Husky back there every day, so I need a middle seat solution. Doesn’t look like this harness goes in the middle…?
  6. Feb 12, 2025 at 9:41 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Ill check when I get home, but I can't see why they wouldn't. Is there debris in your middle buckle?
  7. Feb 12, 2025 at 9:42 AM
    Shadowfax1
    There is no debris and no damage. I’ve had Toyota confirm that, too. The middle buckles are NOT the same as the ones on the left/right.
    Tundra family likes this.
  8. Feb 12, 2025 at 9:52 AM
    Tundra family
    Tundra family New Member
  9. Feb 12, 2025 at 10:01 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    They make seat belts that loop around the headrest.
    But they would probably be too long for what you need.
    Amazon.com : Removable Dog Seat Belt Harness for Car, 3 in 1 Pet Dog Car Seatbelt Leash, Retractable Restraint Secures to Vehicle Headrest & Adjustable Reflective Bungee Dog Seatbelt Tether, Blue and Black : Pet Supplies
    Yes the middle buckle is a different size the side buckles.
    They do that to avoid using the wrong buckle.
