OEM 2018+ LED headlight pattern
Discussion in '2.5 Gen Tundras (2014-2021)' started by Swicegk, Feb 10, 2025.
  1. Feb 10, 2025 at 9:09 PM
    Swicegk
    Swicegk [OP] New Member
    North Carolina
    2015 Silver Sky XSP-X
    Could you guys post pictures of your OEM led headlights on low and high beam against a wall at the 25 ft distance? Just installed OEM LED’s in my 2015, adjusted lights at the proper level on low beam. When high beams are activated, the driver side beam is much higher than the passenger side. I feel like one of the new lights is faulty. Looking for confirmation.
  2. Feb 10, 2025 at 10:49 PM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    I'm in my jammies and it's cold outside so I ain't goin' outside, but there's a definite mismatch between the two.
    Weird that it's on only the high beam.
