Read Brake Pad Wear
Discussion in '3rd Gen Tundras (2022+)' started by HoustonTaco, Dec 11, 2024.
  1. Feb 9, 2025 at 12:50 PM
    Tom976
    Tom976 New Member
    Tom
    It doesnt but how do you know that its extending or retracting when you put power to it?
    When on the truck it'll bog down that little motor on it pretty quickly when its engaging. (rotor will be lock in place too)
    When back off (retracting) it'll take a little bit.
    If you do it off the truck, you may not realize which direction things are taking until its too late
  2. Feb 9, 2025 at 12:59 PM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    Thanks Tom for posting this detailed process. You will save me a bunch of time with the voltage and method for the PBrake retract as well as the thin wrench comment on the caliper bolts. I’m not quite there yet but my date with a pad change will come.
  3. Feb 9, 2025 at 1:05 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    Here is how I did mine. No sending voltage needed. Treat it like a integrated brake caliper from a 90's Honda. I just use a Harbor Freight brake service tool.
    eddiefromcali likes this.
  4. Feb 9, 2025 at 2:22 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    You can see it extend. You won't see it retract, you'll hear the motor but the piston won't move...you have to push it in.
    It's pretty idiot proof off the truck if you're paying attention...even more, on the truck.
    Tom976[QUOTED] likes this.
  5. Feb 10, 2025 at 9:42 AM
    jtweezy
    jtweezy New Member
    Jeffrey
    Are you saying you just used a "brake service tool" to turn the brake piston, which retracts it into the caliper to clear the new, thicker pads?
  6. Feb 10, 2025 at 9:55 AM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    Yeah. The special tool is just a brake service tool. It was $67 on eBay but I already have brake service tool from harbor freight that I use for work.
    the tool I found on eBay.
  7. Feb 10, 2025 at 9:56 AM
    Tom976
    Tom976 New Member
    Tom
    I think that is one way to do it, others complained about twisting up the dust boots and didnt want to tear them.
  8. Feb 10, 2025 at 9:59 AM
    jtweezy
    jtweezy New Member
    Jeffrey
    Is this the HF one?
    Maybe. The video I watched on retracting the piston with a 12v source showed the boot twisting as well. The solution was to reverse polarity and let it "unwind" a little bit to fix the boot.
