Looking for Scangauge ii trans temp xgauge code for early FGT
Discussion in '1st Gen Tundras (2000-2006)' started by Austinkordell, Feb 9, 2025.
  1. Feb 9, 2025 at 8:23 PM
    Austinkordell
    Austinkordell [OP] New Member
    Austin
    97 LX450
    Hello I am looking to see if anyone with an early FGT (01) is running a scangauge and was able to program an xgauge code that works for accurate transmission temp gauge.
    I inputted the one found on scangauge website for pre 2010 and my gauge just reads 350 degrees which I know is no way accurate and doesn’t move. From cold start to highway it stays at 350 so I’m wondering if the code is incorrect.
    If it helps any, when I click on their “1996-2002” category no trans temp codes come up, inputting the “pre 2010” trans temp codes gives me what I’m getting.
    not sure if I’m experiencing a fault within my trucks transmission temp sensor or if I’m putting in the wrong code causing what I’m seeing.
    any input would be super appreciated!
    thanks
  2. Feb 9, 2025 at 8:29 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I have it, let me find it
  3. Feb 9, 2025 at 8:39 PM
    Austinkordell
    Austin
    97 LX450
    Sweet! Thanks
  4. Feb 9, 2025 at 8:47 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    This has worked for me and many others. If If doesn't work for you, I suggest reaching out to the team, with the provided details here.
  5. Feb 9, 2025 at 8:52 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    And just for fun, here's the 05-06 xgauge for trans temp
    G_unit3000 likes this.
  6. Feb 9, 2025 at 9:00 PM
    Austinkordell
    Austin
    97 LX450
    Ayy that worked!! Thanks a ton man.
  7. Feb 9, 2025 at 9:04 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    :fistbump:
    BubbaW likes this.
  8. Feb 10, 2025 at 4:32 AM
    GXPaycheck
    GXPaycheck New Member
    Central NC
    I found the codes on their website but had to send the unit in for an update to make it work (old unit).
