2025 Platinum 2 inch front lift?
Discussion in 'Suspension' started by se3388, Feb 9, 2025.
  1. Feb 9, 2025 at 12:53 PM
    se3388
    se3388 [OP] New Member
    2025 Tundra I Force Max Platinum Crew Cab, 1997 Toyota T100 SR5 Ext. Cab 4x4, 2014 Tacoma Dbl Cab Short Bed 4x4 TRD Sport
    Just got a 2025 I Force Max Platinum and started looking on the Forum about front lift (Front 36.5" - Rear 39"). I have read that a 2" lift for the front will not give a true 2 inches. My T100 had a bad rake to it but looked great after I did the front lift. To get the Tundra as close as possible would I need a 2 " or 2.5" block for the front. Dumb question is will it cause a difference in the ride to level it out, the T100 did but it is a completely different suspension. Thanks for any advice.
    Steve.........
  2. Feb 9, 2025 at 2:25 PM
    Hella Krusty
    Hella Krusty New Member
    ON my 2012, I had a Ready Lift 3/1 levelling kit in . The 3 was really 2 and change , and the 1 was 3/4. It looked great I just think they should call a spade a spade
  3. Feb 9, 2025 at 4:10 PM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    I did the Rough Country 1.75" on front, it made front and rear just about dead even. I later added a 1/2 to rear for a little rake. I know it's not much, but I like it pretty level & I don't tow much.
  4. Feb 9, 2025 at 6:49 PM
    se3388
    Could you tell any difference in the ride with the lift?
    Sounds like to take care of the 2.5 inch of rake I might should go with a 2.5 inch lift to get it within 1/4 inch.
    Steve.............
