  1. Feb 8, 2025 at 9:05 AM
    #8551
    WindChillYeti75
    WindChillYeti75 New Member
    2025 WCP Limited TRD Off Road iForce Max
    Westcott Designs preload collar lift kit, 17” Method 703’s with +35 offset, and 35x12.5x17 Toyo Open Country AT3’s in E load.
    CringyDad, RatPanda, ToyoJon and 6 others like this.
  2. Feb 8, 2025 at 9:22 AM
    #8552
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    Yesterday was plus 3 degrees so I took the opportunity to lay on my back on a little piece of plywood. I found that I needed to thread the bolts in equally, that is a little on one bolt then switch to the other. From what I could tell this is needed because the bushing on the sway bar needs to be compressed slightly as you torque the bolts down. After I snugged the bolts down I started at 35 ft lbs and worked up to 55 as I read the horror story of the guy with the sequoia that had the tack welds on the nuts break off.
    Tundrastruck91 likes this.
  3. Feb 8, 2025 at 9:31 AM
    #8553
    MAC25Tundra
    MAC25Tundra New Member
    2025 Limited Crew Max 4x4
    Much appreciated!
  4. Feb 8, 2025 at 11:32 AM
    #8554
    ngoshawk
    ngoshawk New Member
    2025 Tundra Platinum 6.5' bed
    Rough Country wheel liners, mud flaps, TufSkinz gloss black tailgate lettering, JDMCAR console organizer. That’s it.
    Installed Rough Country Wheel Liners and Sunsdrew Mud Flaps. WeatherTech Mud Flaps were on back order and I decided to spend 1/3 the price to test these.
    Install including “cleaning the areas” took 57 min for all. Only hitch was the outboard bolt on LR wheel liner didn’t perfectly line up. It works, but slightly skewed. And the Phillips head screws (green in picture) on both rear flaps. Not an ideal access point with wheel on.
    But all fits as expected, and hopefully will protect the front end of the stock running boards (mud/dirt covered).
    $165 total well spent, hopefully.
  5. Feb 8, 2025 at 12:53 PM
    #8555
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    If I ever decide to install hooks, u can bet I am gonna chase the threads first. Too many people struggling with this.
    ngoshawk and Mr Rick like this.
  6. Feb 8, 2025 at 1:29 PM
    #8556
    Northern Toyota
    Tires and bilstein
    my bolts turned out (after broke loose) and tuned in by hand very easily.
  7. Feb 8, 2025 at 6:47 PM
    #8557
    ToyoJon
    ToyoJon New Member
    2025 Tundra Limited
    Installed a Toyota tonneau cover picked up today at the dealer. Really like the look.
  8. Feb 8, 2025 at 6:50 PM
    #8558
    mach1man001
    mach1man001 New Member
    Rob
    2024 Limited Crewmax
    That is on my list!
    ToyoJon[QUOTED] likes this.
  9. Feb 9, 2025 at 1:09 AM
    #8559
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    Can you do me a solid and measure from the center of your hitch to the ground?
  10. Feb 9, 2025 at 5:18 AM
    #8560
    WindChillYeti75
    Will do when I get home from work!
    Ipaddick[QUOTED] likes this.
  11. Feb 9, 2025 at 7:26 AM
    #8561
    mach1man001
    Rob
    A new name for my truck thanks to Mother Nature. Say hello to my Yundra!
  12. Feb 9, 2025 at 7:27 AM
    #8562
    SilveradoSwap
    Everything here is coated in a nice thick layer of ice.
    mach1man001 likes this.
  13. Feb 9, 2025 at 8:51 AM
    #8563
    lapoolboy
    lapoolboy New Member
    Got the tailgate spoiler installed and wired. Now the back has marker lights to match the front. I was going to have it painted to match, but honestly, the black camo pattern looks great with the gray truck so I'm going to leave as-is.PXL_20250209_164446680~2.jpg
  14. Feb 9, 2025 at 10:54 AM
    #8564
    JohnF4x4
    JohnF4x4 New Member
    US
    2025 Platinum
    Have anyone installed door edge protection and which one would you recommend?
  15. Feb 9, 2025 at 2:56 PM
    #8565
    Ipaddick
    Ipaddick New Member
    Canada
    Will be doing this hopefully this week. Just waiting for my plug to get in to wire them up.
  16. Feb 9, 2025 at 4:14 PM
    #8566
    Keitha37
    Keitha37 New Member
    Keith
    ‘24 6.5 Platinum
    Icon stage 4 Icon rear springs Icon diff drop Custom Lumber rack
    Busy week, a few upgrades this week:
    Icon Stage 4
    Rough Country Rear Wheel Well Liners
    Toyota OEM Door Edge Guards
    Miker24, Raven67 and ngoshawk like this.
  17. Feb 9, 2025 at 5:43 PM
    #8567
    almanc
    almanc New Member
    new Rekgen mud flaps. Tires stuck out a bit so needed a little more coverage than the factory mud flaps.
  18. Feb 9, 2025 at 6:46 PM
    #8568
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Installed oem tow hooks.
    jacquesc, akira, Nm6300'asl and 7 others like this.
  19. Feb 9, 2025 at 7:57 PM
    #8569
    CajunTim
    CajunTim Original Recall Engine Going Strong
    SELA
    22 Platinum CELESTIAL SILVER METALLIC Advanced Package 4x4
    DiamondbackHD, bedrugXLT, Binize, Compustar remote start, 20% all around,
    I took my DiamondbackHD of to get this thing water tight, then caulked the top rails down and put it back on
    upload_2025-2-9_21-56-12.jpgupload_2025-2-9_21-56-12.jpgupload_2025-2-9_21-56-12.jpgupload_2025-2-9_21-56-12.jpg
    Mr Rick likes this.
  20. Feb 9, 2025 at 8:10 PM
    #8570
    Hye_Tundra
    Hye_Tundra Fortune Favors The Bold
    LEV
    Los Angeles, CA
    25’ CSM Limited TRD OR
    OEM. Its color matched and pretty cheap. Install takes minutes.
  21. Feb 10, 2025 at 7:18 AM
    #8571
    bailey bulldog
    bailey bulldog New Member
    This!
  22. Feb 10, 2025 at 11:30 AM
    #8572
    eddiefromcali
    Eddie
    100% Stock
    Oem is the way
  23. Feb 10, 2025 at 12:54 PM
    #8573
    eddiefromcali
    Eddie
    100% Stock
    Installed TRD skid plate on tip of my Talon cat plate
    22whatwedo and ngoshawk like this.
  24. Feb 10, 2025 at 1:21 PM
    #8574
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    I actually DROVE my truck today. It's been in garage since before Christmas. Weather was good so I put 100 miles on it. I know, I know...:rofl::bananadance::burnrubber:
    Mr Rick, Woodrow bangs and ngoshawk like this.
  25. Feb 10, 2025 at 3:16 PM
    #8575
    sdtundra619
    sdtundra619 New Member
    2023 Tundra 1794 TRD OR
    Bulletpoint with low profile radar detector mount
  26. Feb 10, 2025 at 3:52 PM
    #8576
    Superfishal
    Superfishal New Member
    What size tires are those? They look great!
  27. Feb 10, 2025 at 4:54 PM
    #8577
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    Back about 100 pages or so, TKTon-dra posted this:
    (Low post count and he hasn't been around since May...and I was curious myself, so I went looking.)
  28. Feb 10, 2025 at 7:41 PM
    #8578
    Jalzate44
    Jalzate44 New Member
    San Antonio TX
    2024 Tundra SR5 Crewmax 4x4
    How is this plugged in?
  29. Feb 10, 2025 at 7:56 PM
    #8579
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    There is a cigarette lighter 12 v in that nook. They covered it up nicely with that little metal grill piece, looks sharp.
  30. Feb 11, 2025 at 12:49 AM
    #8580
    JayDee
    JayDee New Member
    Do you find the radar detector useful at all? Last time I used mine on a long trip it was next to useless. There are now so many cars and trucks that have radar sensors not to mention all the hidden radar units along the interstates every few miles. My detector was constantly going off and I had to shut it off. (Even in City mode while on the highway)
    I spent several hours designing a 3D printed bracket to hold my radar detector and was excited to get to use it for the first time only to be disappointed by it's constant false alarms.
    Tundrastruck91 and kirkb like this.
