Air Bag Question
Discussion in 'Suspension' started by eagleguy, Feb 2, 2025.
  1. Feb 2, 2025 at 7:38 AM
    eagleguy
    eagleguy [OP] New Member
    For camper / trailer towing do you guys air up your "Firestone Type" air bags before or after putting load on/in truck? I have been doing after but someone told me that is incorrect.
  2. Feb 2, 2025 at 9:25 AM
    bflooks
    bflooks New Member
    Metrowest MA
    I think it depends on what,.specifically, you are asking.
    If for normal use (anything adding weight without use of a WDH), it would make sense to have them inflated before so they are helping carry load straight away.
    If for towing, and assuming your WDH is all set up for whatever pressure you run, Id do it after connecting the WDH so you aren't having to fight the extra unloaded height during engagement. The order doesn't really matter, though, since they are just helpers with the WDH doing most of the work.
    *** For a WDH, the most important thing is to know your pressure and set up the WDH at that height/configuration. Over or under inflating the bags will directly impact the distribution of the hitch ***
  3. Feb 2, 2025 at 9:30 AM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    For our style with leaf springs, just air up after to get the height back.
    in the past I had the airbags that go inside coil springs (on a 4Runner). They recommended airing up before the load, probably as there was more of a chance they would get pinched.
  4. Feb 2, 2025 at 10:06 AM
    eagleguy
    Towing 20' small camper that does not seen to require a WDH as it towed rather well on the highway. Added a Sway Control and Air Bags to try and control things a bit as the wife gets Motion Sickness easily.
  5. Feb 2, 2025 at 11:03 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Read the manual and get a tongue weight. You may be good, you may be surprised. The porpoising is a sign you could use one, but the numbers always tell the truth.
    Regardless, as stated previously, if you aren't using a WDH, I'd inflate before.
  6. Feb 2, 2025 at 6:41 PM
    eagleguy
    Thanks
  7. Feb 5, 2025 at 7:15 AM
    Rattlewagon
    Rattlewagon New Member
    Caleb
    19 SR DCLB
    I have firestone bags on my 19 to tow my 20' trailer and truck around. I air them up before I load because its easier to get the truck closer to the garage without the trailer on it (no built in pump). I like to air them up first, as installing the airbag required removing the bumpstops and I *feel* better having air in them before I load them up.
    The tongue weight scales are also great. Not too expensive and provides a great piece of mind. https://irate4x4.com/threads/tongue-weight-scale.397413/
  8. Feb 5, 2025 at 7:30 AM
    Fergie
    Fergie New Member
    I do both, mainly based on when I remember to do so. I recall reading somewhere that airing them up first, and then deflating them to desired ride height/quality is the correct way to do it, but can provide no documentation for that.
  9. Feb 5, 2025 at 7:53 AM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    I always did mine after adding the weight, to get back to the desired height.
  10. Feb 6, 2025 at 3:49 PM
    eagleguy
    Well just went on a camping trip with my 1/4 ton SR5. Air bags at 40 psi with sway bar only towing around 4K. Very nice and NO need for a WDH!
  11. Feb 6, 2025 at 4:13 PM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    I'm genuinely curious, if there's no need for a WDH why would it need airbags?
    If it's working well for you that's awesome, this just seems kinda backwards to me.
    When I got my trailer (similar size but a little heavier) the first couple of trips were sans WDH and had a lot of porpoising &/or conflicting bounce between truck & trailer. Added the Andersen WDH and what was two separate objects hooked together now felt more like one cohesive unit.
    KNABORES likes this.
  12. Feb 6, 2025 at 4:48 PM
    eagleguy
    Simple. Air Bags were added just to keep things level and reduce bounce on a single axle RV, no other reason. Wife happy and that's all that counts. Worked perfectly for me and I do not have your rear end dip..
  13. Feb 6, 2025 at 5:43 PM
    Fergie
    Fergie New Member
    This was a previous iteration of camper, but towing an old Merc from Billings to Flagstaff had no issues. Bags were at 35-40 most of the time, depending on temps, and it was a nice stable tow.
    And then towing the 40 for a few hundred miles:
    eagleguy[OP] likes this.
  14. Feb 7, 2025 at 7:49 AM
    SD Surfer
    Bruce
    So Cal
    Happy Wife, Happy Life!
    Hey I'm 62, of course I have a little rear end dip. :rofl:
    Ohhh, you meant the 1st gen pic huh? Yeah that was before deciding I needed the WDH.
    Glad you guys enjoyed your camping trip, where'd ya' go?
  15. Feb 8, 2025 at 6:01 PM
    eagleguy
    500 mile trip. Air bags, sway bar and NO WDH. Was passed by and went by tractor trailers at 50-75 mph. No issues.
