Regear
Discussion in 'Performance and Tuning' started by Lemuel1, Nov 27, 2024.
  1. Feb 7, 2025 at 11:10 AM
    #61
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    My rear are whiny at 55-65 and on coast. My fronts are noise free. I drove 510 miles in AWD and 4x4locked(sequoia t-case). Fronts had a great pattern but still went ahead and went .003 shallower. No noise. When it weather warms will be swapping out the rears and doing the same.
  2. Feb 7, 2025 at 4:34 PM
    #62
    Lemuel1
    Lemuel1 [OP] Enjoy
    Samuel
    2020 Tundra
    ToyTec Alumas 2.5,icon IT 2.5 rear,Wheelers superbumpstops, JBA UCA’s, 8 inch BA muffler kit,
    Glad to hear the whine is normal ish
    Mdl[QUOTED] likes this.
  3. Feb 7, 2025 at 6:09 PM
    #63
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    If it ever gets worse the pattern can be removed by REM polishing. And try going a little bit shallower on pinion depth. I'll update when I do the rear again. Got a spare rear set REM'd waiting for some warm weather to arrive for install.
    And I'm repeating myself from prior posts...
  4. Feb 7, 2025 at 6:55 PM
    #64
    Lemuel1
    Lemuel1 [OP] Enjoy
    Samuel
    2020 Tundra
    I paid a shop to do mine they are 4 hours away. This level of work is beyond my capabilities.
