WHO DOES THEIR OWN BRAKE JOBS ?
Discussion in '2nd Gen Tundras (2007-2013)' started by 10 Bears, Feb 6, 2025.
  1. Feb 6, 2025 at 11:46 PM
    10 Bears
    10 Bears [OP] New Member
    11 CREW 5.7
    None at the moment
    After a year and a half with the Tundra I replaced the rear rotors & pads & adjusted slightly the parking brake...
    I measured all four replaced rotors & all in spec.. then remembered all the comments on this forum about
    " Don't even bother machining the front rotors" etc....
    What happens if you do turn them ?
    Will they ruin easily ?
    Or stay warped ??
  2. Feb 7, 2025 at 5:47 AM
    Perpendicular
    Perpendicular New Member
    Paul
    Austin, TX
    2023 Capstone
    I do, and with the costs of rotors now and how fast they warp after being turned, I replace them and never look back.
  3. Feb 7, 2025 at 6:57 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Just replace them, not worth turning considering cost/benefit and time involved.
    If you tow/haul or drive aggressive, Tundras do better with Cryo treated rotors up front.....much more resistant to warping and generally perform better and last longer.
    AZBoatHauler likes this.
  4. Feb 7, 2025 at 7:19 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    73k on my original brakes. I have fixed the shudder for free multiple times. Not every case of shuddering is indicative of warped rotors. Dropping this post here in case it helps anyone:
    Uhhhh...., Lifer, texasrho83 and 3 others like this.
  5. Feb 7, 2025 at 8:32 AM
    Retired...finally
    That is very interesting. And makes good sense too.
  6. Feb 7, 2025 at 8:53 AM
    10 Bears
    11 CREW 5.7
    None at the moment
    Well this raises a question...
    I hardly ever drive at hwy speeds but when I do there is a slight shudder from the front.
    Q. How did you resolve your shudder ?
    I was just about to get them balanced since it's been 14 months.
  7. Feb 7, 2025 at 8:56 AM
    10 Bears
    11 CREW 5.7
    None at the moment
    So is this a Tundra only thing or do y'all trash the rotors for any car i.e Corolla, Camry ??
    I do not haul or tow nothing at all.
    Simply transportation.
  8. Feb 7, 2025 at 9:16 AM
    Terndrerrr
    Music City
    6UR-FE
    I'm talking specifically about the shudder that happens when you apply the brakes.
    If you have a bit of a shimmy at 55-65mph, that is very common and could be from your tires needing to be balanced (or replaced) or needing an alignment.
    Uhhhh.... and redrdr67 like this.
  9. Feb 7, 2025 at 9:33 AM
    Mullen
    Mullen Desert Dude
    Corona, CA
    2001 Prerunner, 2014 DC 4wd
    I’ve always had my rotors turned until they’re out of spec. My 2014 has 93k miles on and I turned the stock rotors at 55k miles. They’re still running fine with minimal vibrations, even though my truck has been on 35s for the last 5 years. O’rileys even turned them for free.
  10. Feb 7, 2025 at 10:02 AM
    frichco228
    Frank
    Virginia
    then stock replacement should be fine. Tundras can be prone to front rotor warps but that is mainly with harder braking, haul/tow or installation of big and heavy tires.
    My point- if you have to do a brake job anyway, spending just a little more for Cyro rotors on our trucks is not a bad idea.
    grave, AZBoatHauler and KNABORES like this.
  11. Feb 7, 2025 at 10:18 AM
    TexasGuyTX
    TexasGuyTX New Member
    2007 SR5 Super White
    PRO BOX w/ RF Mono Amp Limited 20" Wheels HID's on Low Beams Tip Delete Before Axle
    got some powerstops on mine.. no wear after almost 30k miles on the rotors.. just got done installing them on my camaro project i am getting back on the road.. talked to a guy that sells them he said he had them on his SS camaro for alittle over 100k hard braking
  12. Feb 7, 2025 at 10:21 AM
    Terndrerrr
    Music City
    6UR-FE
    Looks like they didn’t work
    mayan, Uhhhh...., ATV25 and 7 others like this.
  13. Feb 7, 2025 at 10:42 AM
    redrdr67
    redrdr67 New Member
    2007 White Tundra RCSB 2wd
    153,000 on my '07. Have replaced front pads 4 times, the rear once. Still on original rotors front and rear(knocks on wood). Rotors never turned. Always use genuine pads. Believe driving like a grandpa helps.
    grave and AZBoatHauler like this.
  14. Feb 7, 2025 at 10:44 AM
    TexasGuyTX
    lol those literally havn't been broken in yet on the car, pic of old brembo pads/rotors
    I Got the front clip off to reclear it and put my Oracle halo's on
  15. Feb 15, 2025 at 8:06 PM
    texmln
    texmln New Member
    New rotors are dirt cheap and they drop them at my front door. I haven't turned a rotor for brake job in more than 25 years. It's not worth the cost to turn them or my time to even make the drive to drop them off to be turned and drive back to pick them up. Plus, I don't want to wait around with my truck in the air for rotors to come back. Just smack on new rotors and go.
    mtucker likes this.
  16. Feb 15, 2025 at 8:19 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads
    Have close to 100k on current rotors. Just replaced driver rear rotor and caliper cause I didn’t want to mess with freeing a frozen caliper in negative temps. I get a substantial ups discount from O’Reilly on all my bolt on parts.
    I always drive in S mode and engine brake well before using my fat pedal and never tailgate
  17. Feb 16, 2025 at 1:15 PM
    RD951
    RD951 New Member
    Ruben
    13 Tundra Crew
    Level lift on 33s
    Recently replaced front pads but didnt replace rotors. Mostly due to current funds but will be soon. Now have another problem, rear passenger caliper leaked brake fluid after test drive. Did i blow a caliper?
  18. Feb 16, 2025 at 3:05 PM
    10 Bears
    11 CREW 5.7
    None at the moment
    Old or damaged caliper seal.
    Replace it.
    RD951[QUOTED] likes this.
  19. Feb 16, 2025 at 3:12 PM
    yakeng
    yakeng 3URFE Apologist
    Last time I turned rotors was in 1998. I didn’t know places even do it anymore.
    Rotors are so cheap now that I don’t bother.
    mtucker likes this.
  20. Feb 16, 2025 at 3:15 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I used to turn all my rotors (and drums) until I started getting newer vehicles. Now it seems that turning them is an outdated way to deal with warpage. That or the cost of replacements have significantly dropped so ppl just replace them.
    I have a new set of OEM rotors I'm about to install but there's a weird rust coating on one of them. Thinking I'll hit it with a die grinder disc before I slap it on.
  21. Feb 16, 2025 at 3:44 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    I have some Cryo rotors that were over $200 each 5 years ago. After around 50k miles, my pads were almost dead and they made concentric grooves in the rotors.
    So while I have never had rotors resurfaced before, I had these done at $17 each. So I spent $34 instead of shelling out over $400 for a new pair of cryo rotors.
    ATV25 likes this.
  22. Feb 16, 2025 at 3:44 PM
    ZPhilip
    Philip
    West Chester, PA
    No coating of oil on them?
  23. Feb 16, 2025 at 3:51 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Nope
  24. Feb 16, 2025 at 4:27 PM
    BeauDacious
    BeauDacious 040 > all other colors
    14 DC 4x
    I just picked up new OEM rotors all around, none of them had an oil or other coating on them. I thought it was kind of odd.
  25. Feb 16, 2025 at 4:37 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yeah raw metal you'd think would have some sort of coating to keep from rusting.
    ATV25 and BeauDacious[QUOTED] like this.
  26. Feb 16, 2025 at 4:51 PM
    Just spray them with brake cleaner and wipe them down. Install and let the brake pads eat the rusties away. Unless they are obviously pitted.
  27. Feb 19, 2025 at 9:17 PM
    10 Bears
    11 CREW 5.7
    None at the moment
    I'm keeping all 4 of mine their still in spec.
    And unless the difference is within 20$ I'm turning my front rotors just like I always have. Never had issue before, though this is the heaviest vehicle I've ever owned albeit Like mentioned It's a like big Camry for us....simply transportation.
    I don't haul or tow nothing never.
    Never will less it's a water heater or refrigerator etc household appliances.
    So I can see the rate / & type of wear on mine and a Tundra used like a workhorse in industry or towing a vehicle or camper.
    I can see those front rotors warping from the extra weight.
  28. Feb 25, 2025 at 4:56 PM
    shoot-staight
    shoot-staight New Member
    Brett
    2007 SR5 double cab, 2020 SR5 double cab
    I'm kinda new here, and new to diy car stuff too. Well, I did My first brake job on my beater equinox, bought a kit from a company that makes pretty great you tube videos. Did that without an issue.
    My old Rusty 2007 sr5 double cab with 160k at the time has had mushy brakes for a while. I went Ahead and ordered a kit for new rotors, pads and calipers for the front, and new pads for the back. Also a new brake master cylinder. Never monkeyed with those either.
    suprisingly it went ok! Until I snapped both bleeder screws on the rear calipers.
    So my couple night job got extended a bit. Getting those lines lined up and screwed in straight in to the master was a pain as well. But I got It done and the mushiness was 100% gone. Very satisfying.
    parts and videos from A1 auto.
    just did the bearings on my beater equinox! That was fun.. but again, satisfying.
    Perpendicular and 10 Bears[OP] like this.
  29. Feb 27, 2025 at 8:46 AM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    1A / TRQ has the best DIY videos
    Thumper_6119 likes this.
  30. Feb 27, 2025 at 1:06 PM
    Thumper_6119
    Thumper_6119 I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
    I have referenced several TRQ videos on Youtube for doing maintenance/repair tasks on my Tundra. They are very well done and have excellent content and explanations/tutorials.
    grave[QUOTED] likes this.
