Under $25k and 150k miles - 4.7 or 5.7?
Discussion in '2nd Gen Tundras (2007-2013)' started by FarmerFrederico, Feb 2, 2025.
  1. Feb 2, 2025 at 6:06 AM
    FarmerFrederico
    FarmerFrederico [OP] New Member
    Hi,
    In the market nation wide for something under $25k and 150k miles. I’d rather spend around $15k so I can add a pop-up camper shell right away. This would be my DD and recreational rig here in Colorado. The YouTube gurus are telling me the 4.7L is the one to get, so 2007-9. Trying to find a regular cab or double cab with short bed 4x4.
    Having trouble finding a 4.7L that hasn’t lived in the salt - seeing some in Iowa and Indiana but there is a super clean 2011 5.7L with no rust in the south.
    Do I really need to prioritize the 4.7L? I’d keep this at least 5-10 years and drive a good 10-12k/year.
    Thanks!
  2. Feb 2, 2025 at 6:41 AM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Welcome to the forum . There’s nothing wrong with the 5.7 .
  3. Feb 2, 2025 at 6:48 AM
    AZBoatHauler
    So.Arizona
    At altitude - I’d definitely recommend the 5.7 over 4.7.
  4. Feb 2, 2025 at 6:57 AM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    It seems you are considering not simply displacement but also engine platform/technology? So UZ vs UR?
    Either is fantastic and reliable, and in that case the 4.6 is also good as it's basically a smaller 5.7 and would open up a few more years of 2nd gen truck for you. Power wise 4.6 and 4.7 are similar, but technology wise the 4.6 and 5.7 are the same.
    Can't go wrong with any from a reliability standpoint, but the smaller V8s generally keep the price down a little where I live.
    Oh, and the 4.7 has a timing belt job that a shop would charge you 1500-2000 for incl water pump, tensioner etc. so factor that into the equation of you buy one near the service interval. No such belt on the UR engines.
  5. Feb 2, 2025 at 7:26 AM
    SharkDog
    SharkDog New Member
    Denver
    2006 Gray DC Tundra SR5
    Dobinson Twin Tubes. Stock.
    I have a 4.7 in an 06, which I assume is slightly lighter with a smaller frontal area. It is adequate. If I was shopping for a 2nd gen, I would be shopping for a 5.7.
    Lifer and FarmerFrederico[OP] like this.
  6. Feb 2, 2025 at 7:30 AM
    FarmerFrederico
    Yes, consideration is on platform.
    As I’m at altitude, maybe the 5.7 UR is the way to go. More vehicles to choose from for sure.
  7. Feb 2, 2025 at 7:41 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Altitude + pop up = 5.7
  8. Feb 2, 2025 at 7:59 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    +1 for the 5.7
    2nd gen is fairly hefty, and the power is very welcome at Colorado elevations.
    The truck definitely has to work pulling our 6500+lb travel trailer over the mountain passes. The 5.7 4x4s command a higher price in CO (and probably everywhere), but there is a reason for that. Should open up a ton of options for your search tho.
  9. Feb 2, 2025 at 8:21 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    5.7 all day everyday.
  10. Feb 2, 2025 at 10:54 AM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    My 4.7 did everything I asked it to do for the 6 years I owned it, including towing my 5,500 lb. trailer, but the 5.7 does it much much better.
    grave, Trooper2, AZBoatHauler and 2 others like this.
  11. Feb 2, 2025 at 11:36 AM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    I don't think you can go wrong with the 5.7.
    59nascar likes this.
  12. Feb 2, 2025 at 12:03 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    2021 DC SR5 4x4 (guess the color)
    I’d go with a UR just to avoid timing belts. Like stated, that one feature alone is going to add $2-4K over your projected ownership horizon. You might be able to offset that with a 4.6L to avoid the 5.7L price hikes.
    That said, there’s no replacement for displacement.
  13. Feb 2, 2025 at 5:41 PM
    Rph74
    Rph74 New Member
    Springfield,MO
    2007 Tundra Crewmax Limited Silver/Redrock
    I love the 5.7 in my 2007, but also as an owner of 2 vehicles with the 4.7 (GX470), that 4.7 is amazingly smooth, and many say is the most reliable V8 Toyota has ever made. IMO easier to work on as well compared to the 5.7.
    I take the unpopular opinion that I actually like the timing belt. As a guy that likes preventative maintenance, this forces one to get a new water pump, timing tensioner and pulleys on a prescribed schedule. Perhaps the intensive maintenance schedule is part of why it lasts so long? That being said, I’m not sure if the 4.7 would feel underpowered in the big Tundra.
    FarmerFrederico[OP] likes this.
  14. Feb 2, 2025 at 5:47 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads
    Went from 02 uz to 07 uz. Have 35s and 4.88 on the 07. It is less peppy. I don’t tow anything but a 14ft alumicraft boat; bump stops maxed out with firewood hauls; bed full of camping gear and kayaks. Don’t have a need for the 5.7 and am happy with the UZ and its bulletproof reliability. Have some gnarly hills but nothing at altitude like out west.
  15. Feb 2, 2025 at 6:11 PM
    mountaingroan
    mountaingroan New Member
    Frank
    North Idaho
    2020 SR5 DC VooDoo 4WD Bench!
    I've had both, the 4.7L in an '07, the 5.7L in a '20. I think that early 4.7 is the smoothest of all, the 5.7 runs out with less labor. With the newer 6s auto the mileage is as good or maybe slightly better with the 5.7.
    If you're wanting the popup camper and associated gear I'd lean 5.7.
  16. Feb 3, 2025 at 11:46 AM
    SharkDog
    SharkDog New Member
    Denver
    There is a high mileage rock warrior with a go fast and nauseating seat covers in Salida on the Denver craigslist.
    grave and FarmerFrederico[OP] like this.
  17. Feb 3, 2025 at 11:51 AM
    Lifer
    Lifer New Member
    Vince
    2000 Ltd 4x4 2008 SR5 4x4 LB 2021 SR 4x4 LB
    Fab tech on the 2000
    Exactly!!!
    Ebrperk and FarmerFrederico[OP] like this.
  18. Feb 6, 2025 at 1:00 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    sometimes I pine for the 5.7 but i can't miss what i've never known. my '07 2UZ-FE does everything I need it to with 275K on the odo. I take solace in the fact that two identically spec'd 2007 SR5 double cabs with the 4.7 have made it to 1M miles. I live in southern calif. at sea level, though.
    my buddy just scored a super clean '08 4X4 CM 5.7 with a shell, bedrug, roof racks, and 110K miles for $24K
  19. Feb 6, 2025 at 1:49 PM
    FarmerFrederico
    Thanks everyone! I settled on the 5.7. Hopefully I’ll pick up a 2011 RCSB 4x4 with 120k in a little over a week!
  20. Feb 6, 2025 at 2:05 PM
    Lifer
    Lifer New Member
    Vince
    Those are kinda rare, don't see em much. Cool truck, you will have to share pics when the time comes! Good luck with purchase.
  21. Feb 6, 2025 at 3:21 PM
    Dr_Al
    Dr_Al New Member
    Al
    I had a 2000 Tundra with the 4.7 and pushed it beyond anything Toyota designed it for. I pulled an enclosed 10,000 26' race car trailer weekly in the summer that included a pretty steep hill on an interstate. Loaded I bet it was well over 8000lbs. To hold 60 going up that hill meant pulling the foot through the floor but it did it. She's rev up to almost 4000 rpm and chuck right along. It wasn't just the weight, it was the flat front of the trailer. It was like a giant wind brake.
    I sold that truck when the cab started to rust. I wasn't using it much in the winter and let snow pile up on the sides which blocked airflow under the truck. As the snow started to melt the underside was in near 100% humidity. The truck had almost 200k on it and ran great. Didn't burn a drop of oil and sounded like the day it was new. I did replace the timing belt twice. If you're handy you can do it yourself for a few hundred and an afternoon. If I remember the hard part was getting the bolt on the pulley free. Not bad for 18 years of use. I still see it on the road today.
    I have an '07 with a 5.7 now. I don't have the race car anymore but i do occasionally pull my tractor. The 5.7 clearly has tons more power (which is why I got it). I think finding the 5.7 was harder when I was looking. Plenty of the smaller engines around. I used Carfax to find a true southern one. Carfax will tell you where it's been registered and work has been done to it. It's easy to see where any vehicle has spent it's life.
    Just remember, being a southern truck doesn't mean it's free from problems. If your plan is to hop on a plane or bus, fly down, and drive it back I would try to find someone close who can inspect it first. Maybe even a guy at a local garage you could pay. I found one that looked good but the coolant looked like pink milkshake. That's a sign that the intercooler had failed and radiator fluid and trans fluid had mixed.
  22. Feb 12, 2025 at 6:43 AM
    crustycabs
    crustycabs New Member
    I was pulling my 30' with a 5.4L F250, and it struggled mightily up the western MD hills. Hoping the 5.7 2010 I just bought does better.
    k0diak8o8 likes this.
  23. Feb 12, 2025 at 6:53 AM
    Retired...finally
    Could this be the payload unicorn? Or close to it since it's 4x4.
    grave likes this.
  24. Feb 12, 2025 at 7:25 AM
    Lifer
    Lifer New Member
    Vince
    In 4th gear in tow haul you will have a grin on your face climbing those hills
    grave likes this.
  25. Feb 12, 2025 at 9:17 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    i've always had such a soft spot but also a hard-on for regular cab toyotas. saw a pretty sweet one in south OC a few months ago; dark gray, mellow king lift, black wheels, not-35s, and a GFC camper. sweet little rig
  26. Feb 17, 2025 at 7:39 AM
    FarmerFrederico
    Drove it from California to Colorado last two days. It’s a beauty!
  27. Feb 17, 2025 at 8:41 AM
    mountaingroan
    Frank
    North Idaho
    Indeed it is! Well done!
  28. Feb 17, 2025 at 9:35 AM
    Retired...finally
    Curious to see your door sticker showing payload.
    PNW15 and OldGuy03 like this.
  29. Feb 17, 2025 at 11:44 AM
    Lifer
    Lifer New Member
    Vince
    Awesome truck Farmer!!!! Thanks for sharing. Congrats.
    OldGuy03 and FarmerFrederico[OP] like this.
  30. Feb 17, 2025 at 6:44 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Hell yeah!
