Sway bar rub help
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mike63078, Feb 5, 2025.
  1. Feb 5, 2025 at 8:08 AM
    Mike63078
    Mike63078 [OP] New Member
    2021 SE5 Tundra
    Hi all
    I finally got new tires and now get rub on my swaybar at full look
    Below is the set up of my truck
    21 Tundra Crew Max
    Westcott preload collars with shims
    Driver side ship to fix lean
    Bilstein 5100s on all 4 corners
    Coachbuilder +3 stackels
    Wildpeak 275/85/18 tires
    is there anything i can do to stop the swaybar rub at a full turn?
  2. Feb 5, 2025 at 8:12 AM
    AZBoatHauler
    So.Arizona
    Remove it
    reywcms likes this.
  3. Feb 5, 2025 at 8:14 AM
    Mike63078
    2021 SE5 Tundra
    I would prefer to keep it. Has anyone had any luck with sway bar spacers etc?
  4. Feb 5, 2025 at 8:15 AM
    AZBoatHauler
    So.Arizona
    Never heard of that. People use wheel spacers or wheels with different backspacing.
    I removed my FSB a couple years back and haven’t missed it for a second.
  5. Feb 5, 2025 at 10:21 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I believe the 3.5" Rough Country lift comes with sway bar spacers. You could try some spacers and see if it helps. Even if you just need a half inch or an inch or so.
  6. Feb 5, 2025 at 10:31 AM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
  7. Feb 5, 2025 at 10:45 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    Unfortunately on occasion you cant have it your way. You will have to change, add or remove something.
    Stock wheels have a +60/+65 offset or something along those lines, wider and larger diameter tires will inevitably reach deeper than stock.
    IIRC, sway bar spacers make it sit lower on the chassis to accommodate for the increased angle, not the distance between the tires and bar.
    Wheel Spacers will run a heck of a lot cheaper than new wheels and you don't have to mess with the sway bar.
    For what it's worth, I too removed mine since it interfered with the coilovers
    Coachbuilder1 likes this.
  8. Feb 5, 2025 at 11:26 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    How much down travel do you have?
  9. Feb 5, 2025 at 12:05 PM
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    How much total lift in the front? What are your alignment numbers? Stock UCAs? Is it rubbing on both sides or just one?
  10. Feb 5, 2025 at 12:12 PM
    Mike63078
    2021 SE5 Tundra
    3.5 total lift
    Bilstein ucr’s
    rubs on both side about an equal amount. I took the mud flaps off
  11. Feb 5, 2025 at 2:03 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    options are new wheels with less backspace/offset or wheel spacers.
    +35 offset will have you clearing well, equal to 1 to 1.25 inch spacers. If you go with spacers, Bora or Spidertrax is what you want. Stay away from cheap wheel spacers.
    Once you address the offset issue, it could have rubs on bumper, so you may need a bumper spacer. Those are easy and cheap to do.
  12. Feb 5, 2025 at 3:06 PM
    kevine0001
    kevine0001 New Member
    Kevin
    I have same issue after doing 6112 and going to 295/70/18 tires Kumho's. Had to trim the passenger side skid plate but still rubbed sway bar. Got 1.25" spidertrax on all four, then started rubbing driver side mud flap (I have aftermarket bumper so no issue there). I had to trim mud flap but it has about 1/2" clearance on body mount, so no BMC yet
  13. Feb 5, 2025 at 3:06 PM
    kevine0001
    Kevin
    pic for reference
  14. Feb 5, 2025 at 3:16 PM
    Mike63078
    2021 SE5 Tundra
    I have a TRD skid plate so no issues there.
    sounds like I can either try wheel spacer, clearance the sway bar or deal with it.
    Thanks
