750E Transmission question
Discussion in '1st Gen Tundras (2000-2006)' started by Fragman, Feb 3, 2025.
  1. Feb 3, 2025 at 10:26 AM
    Fragman
    Fragman [OP] New Member
    2006 Tundra DC SR5 2WD V8
    It's really a simple question. Is there a thermostat?
    My 2006 2WD V8 SR5 DC has a transmission cooler. That is, it has the little mini radiator at the front.
    I want to do a drain and fill on the transmission. Most videos I see say to 'pin the thermostat if you have a transmission cooler', but I cannot find one on my transmission. The only real 'attachment' I can see on the passenger side that is anywhere near the coolant pipes is the 'neutral start switch assembly'.
    Given the age of these trucks, is it possible that it just doesn't have a thermostat and the lines to the cooler are just open all the time? I just want to make sure to do the job properly!
    ETA = When I say Coolant lines, I misspoke. I meant lines HEADED towards coolant from the transmission casing.
  2. Feb 3, 2025 at 10:31 AM
    No t stat
    Fragman[OP] likes this.
  3. Feb 3, 2025 at 10:32 AM
    Fragman
    Thank you!!!
  4. Feb 3, 2025 at 10:34 AM
    Fragman
    Well, that makes it a pretty simple exercise then. The fill plug on the 750E is much more accessible and even a 'comfortably built' person like me can easily get to the three plugs I need to get to with the wheels on the ground.
  5. Feb 3, 2025 at 10:37 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Just gonna tack this on to this thread, because i’m too lazy to check, and dont really need to know right now, but does the fluid hit the cooler before of after the radiator?
  6. Feb 5, 2025 at 12:22 PM
    ps8820
    ps8820 New Member
    joe
    06 SR5 AC 2WD V8 CaptainsSeats
    Freshly Killed Piezo Buzzr!, Re-paint 04-2025
